GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
I broke my boat davits. I made new ones out of heavy gauge steel wire.
- 355 replies
- prince de neufchatel
- schooner
(and 3 more)
Davits are done and installed. Ship’s boats are mostly done. Still need to paint the two larger boats. I made four double blocks to hang the little cutter from the stern. I put some belaying pins in two of the pin rails. They are made from sewing pins. This is how I’m leaving the Prince de Neufchatel for the night.
- 355 replies
- schooner
(and 3 more)
I have three ship’s boats planked. The two smaller boats are clinker planked, the launch is carvel planked. I believe that that would have been typical of the time period. I cut out the shape of the wales and installed the rudder on one. I am going to let them dry overnight.
- 355 replies
- schooner
(and 3 more)
I have the ribs in place for the ship’s boats. I glued them to the templates. Their keels and rudders are drying (pressed under heavy books). After they dry I will fit them to the bottoms of their respective boats and install the cant frames of the launch (the biggest of the three). After everything dries, I will plank them. I have included pictures of the pin rails and boat davits (neither of which are completed).
- 355 replies
- schooner
(and 3 more)
L'Etoile by mhkash - FINISHED
GrandpaPhil replied to mhkash's topic in - Build logs for subjects built 1901 - Present Day
Nice work! -
As stated before, I am using Zu Monfeld’s method of building ship’s boats. I have made the molds and the templates of the gunwales. Next I need to make some frames and then the keels/rudders, before I plank the boats with 3mm (1/8”) wide strips of card.
- 355 replies
- schooner
(and 3 more)
I cut out and fitted my pin rails. I double layered them, since they are card, and set them aside to dry.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
It’s been a very educational evening. I learned how to make a hull using the bread and butter technique. I layered the hulls (the male molds anyways) for three ship’s boats. I carved them to their final shapes before sanding them smooth and labeling them to put in my bits bins for later reuse, after I am done with them. I am confident that I could scratch build a ship’s hull with the bread and butter method. I took pictures of the hull blanks in the positions of the ship’s boats, which I will begin tomorrow. They will be made IAW Zu Monfeld (just out of card). The stern boat will hang by davits, which I will also begin tomorrow.
- 355 replies
- schooner
(and 3 more)
Anchors are rigged and finished: On to the boats. I’m going to make male molds for the 3 different types of boats that the Prince de Neufchatel carried, and build the boat’s frames, keel and planking upside down. The molds will be made bread and butter fashion. I’m using the AOTS for the Victory, due to the time period and similarity between American and British Naval equipment, as my source.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
My next iteration of rigging blocks (for the anchors): I was inspired to reshape them after seeing the work of others on this site.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
