GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
- 355 replies
- prince de neufchatel
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
Aft deck pieces are now doubled.
- 355 replies
- schooner
(and 3 more)
Due to a minor issue resulting from the placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”. I have the forward deck pieces and bulkheads permanently installed. As soon as they finish drying I will pull the aft deck pieces and double them.
- 355 replies
- schooner
(and 3 more)
HMS VICTORY 1765 by albert - 1/48
GrandpaPhil replied to albert's topic in - Build logs for subjects built 1751 - 1800
Very cool! -
Patrick, Thank you and welcome aboard! Have a Merry Christmas and a Happy New Year! Phil
- 355 replies
- schooner
(and 3 more)
Thank you! Much appreciated! I’ve definitely been learning a lot with this project! I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
- 355 replies
- schooner
(and 3 more)
I doubled the forward deck pieces, which should remove the waviness. I will double the aft deck pieces after I install the forward frames permanently.
- 355 replies
- schooner
(and 3 more)
Amazing work on both the Sovereign Of The Seas and the Royal Katherine!
- 1,035 replies
- royal katherine
- ship of the line
I also need to double the deck pieces
- 355 replies
- schooner
(and 3 more)
It needs some (read a lot of) adjustments to bring everything into line, but I’ve made it to the initial dry fit point.
- 355 replies
- schooner
(and 3 more)
Quick question, what’s the best way to install a transom on a card model? Should I just build up the stern frames like any other model, or just glue it to the stern after installing the deck and covering the hull?
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
Thank you for the information. I’ll remember that for next time. There are several ships in his books that I would like to build. Buying the plans in sheets would be very convenient. I never actually scanned these, I just traced them and enlarged the tracings. This has been a highly educational project. I’ve been learning a lot. It’s been a lot of fun too, I’ve never built from scratch before.
- 355 replies
- schooner
(and 3 more)
The only drawback to the posterboard is that I am having to double it in order to build up to the 1mm thickness that Ab mentioned in his tutorial. But, so far so good. I traced the deck camber from Zu Monfeld and enlarged it to make a template which I transferred to the bulkheads. I’m currently in the process of doubling the bulkheads below the main deck to gain more area to glue to.
- 355 replies
- schooner
(and 3 more)
Note, this is being mostly built from posterboard.
- 355 replies
- schooner
(and 3 more)
Next, I’m going to trace the deck lines, including camber from Wolfram Zu Mondfeld’s Historic Ship Models, apply it to the model and cut the deck plates before dry assembling the frame.
- 355 replies
- schooner
(and 3 more)
23 bulkheads, 1 transom and a keel-plate with built in rabbets. Note, they are all currently being flattened under a good part of my reference library.
- 355 replies
- schooner
(and 3 more)
Mark, Thank you, much appreciated.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
