GrandpaPhil
Everything posted by GrandpaPhil
  1. @king derelict and @Old Collingwood Thank you both very much! The first one is mostly done and just needs the base finished and the final highlight coat after the last ink layer dries. The toothpick is keeping the mammoth properly balanced while the glue dries.
  2. The mammoths are now shaggy and brown looking, with more drybrushing for the near future. The webbing and the satchels are probably going to get repainted a different color to avoid having an overwhelming amount of brown.
  3. Thank you all very much for the comments and the likes! I ended up prepping a bunch of other miniatures in addition to the mammoths. I got most of these a long while ago and had them shelved. The mammoths themselves are primed black now. The six legged cat looking thing with tentacles is a displacer beast from the DnD universe. It is done now because it was very simple to paint. Most organics (monsters, creatures and the like) are very easy to paint. It just involves a lot of dry brushing. Here is the finished displacer beast which is off to my curio cabinet:
  4. It is repetitive and tedious but worth it to me. I usually make what I need at a given time to avoid overwhelming myself with as many at one time.
  5. Tichy makes really nice eyebolts for HO scale models (1/87) that correspond to about the right size at 1/98 scale, but they are plastic. I usually make my own eyebolts from annealed steel wire that I got at Lowes.
  6. I am painting a box of two War Mammoths in 28mm from the game A Song of Fire and Ice (Game of Thrones) by Cool Mini Or Not (CMON). I learned to paint by painting miniatures belonging to the Imperial Guard from Warhammer 40K many years ago. I have not gamed in well over twenty years but I still thoroughly enjoy miniature painting, including an army or two (or three) every now and again. The miniatures are resin and of pretty good quality (most of CMON’s miniatures are of incredible quality). I cut the mammoths off their bases (these are ready to field if you don’t want to paint them). I am currently in the process of cleaning them up and filling gaps. They may go back on their bases with some extras added (like rocks and logs, read twigs), or they may get fancy wooden bases since these are destined for my curio cabinet. I haven’t decided yet.
  7. I’m trying it with printer thickness card, the 110 lb sort from Walmart for the upper deck of the bow tower on the superstructure. It worked well for the railings for the railings around the ladder well on the upper deck. It gave them more rigidity and made the first railings easier to install. I have used steel pins for railing posts, with string tied for the railings themselves. 1/200 railings in photo etch are available on EBay too for reasonable prices. I just like to make parts myself. That’s the fun part for me. It’s why I tend to predominantly build card kits or build from plans. Speaking of which, here is my progress for the day, with the next railing awaiting the second coat of sealant prior to shaping. The forward tower is almost complete.
  8. I would go with plywood bulkheads and use basswood for the rest. I go through a lot of basswood. If you’re painting anyways, the type of wood used is less critical from a visual standpoint. Bass is relatively easy to work, cheap, and holds a fair amount of detail. For carvings I have been using cedar grilling planks and old Jenga blocks due to their ability to hold details. I used them both on my model of the Revenge.
  9. Mark, Thank you very much! I am going to adjust my methodology and try to use my basic printer card stock and make the next set of railings from that, and make them a little more durable. Glen, Thank you very much! I’m learning quickly on this one! Steve, Thank you very much! To tell the truth, this hobby is how I learned and developed patience over the years. Hopefully those 200 belaying pins will become thousands as the years progress and I build more ships. The top deck of the forward tower is on: This one just has a ladder to the next deck down, a couple winches, a couple of what I assume are deck lockers and a bunch of railings. That is except for the 47mm guns and search lights that I will make in mass once the rest of the superstructure is built up.
  10. Roel, Thank you very much! The railings and the support structure for the top decks are now in place and awaiting some paint work:
  11. Here is a current picture of my Prince de Neufchatel along with the type of sealant used (or equivalent). I built it six years ago. The hull has aged well.
  12. I used my standard sealer, a basic acrylic sealant for my last two coppered hulls. It works beautifully and both hulls have aged well and developed a patina.
  13. Thank you both very much for the comments! Thank you everyone for the likes and for stopping by! The railings are very time consuming, but definitely worth it! Speaking of which: After several hours of cutting, this one is ready for installation!
  14. Mark, Thank you very much! I have been enjoying this one quite a lot! This is only my second predreadnought, the first was an Encore Olympia, and has been a learning curve. Thank you very much! Cutting out more railings:
