Richmond
Everything posted by Richmond
  1. Interesting to see your mix proportions. I had been sticking to a 50/50 Tamiya / levelling thiner when painting the hull on my fishing trawler. However I was not happy with the results and actually reverted to a 40/60 with superior results albeit it takes time to get coverage. I find the levelling thinner to be superior to other products.
  2. For those interested here is a link with some photographs of a demo model of the forthcoming 1/200 Titanic from Trumpeter (approx 5th row of photos down) I believe it is about 1.35m in length. http://www.ipmsdeutschland.de/Ausstellungen/Nuernberg2019/Bilder_VH/index.html Freeze your budgets!
  3. Looks great. It would be interesting to hear about your paint choices and weathering methods as you go through the build. Are you using pigments as well?
  4. Welcome from Darwin
  5. Welcome from Darwin
  6. Welcome from hot and humid Darwin
  7. Here are some youtube links on 'home made' PE The first by PLASMO and the second by Luke Towan
  8. Anna Re Nautical terminology here are a few links I use https://en.wikipedia.org/wiki/Glossary_of_nautical_terms https://www.macmillandictionary.com/thesaurus-category/british/parts-of-boats-and-ships Maybe if you utilise Google translate you could convert to Dutch. An interesting page on how the English took a lot of their nautical terms from the Dutch language! http://www.antimoon.com/forum/t1475.htm Further an English to Dutch translator for nautical terms https://www.4sailors.nl/en/dutch-sailing-terminology/ I am sure other members, specifically the Dutch contingent, will be able to help you more than I ever could. Regards Richmond
  9. Welcome from hot and humid Darwin!
  10. Welcome Anna - You will find a great deal of help on the site - if you check the build log database you should be able to locate other build logs for the King of Mississippi to help you on your way. In addition by posting your build log other members of the community will comment on your build and assist you by answering any questions you may have. I am a member of a few model forums, https://www.scalemates.com and http://www.die-kartonmodellbauer.de -amongst them however I feel MSW is the best of them especially for ship building whether in wood, plastic or card. Regards Richmond
  11. Slog - thank you I will have a look - however with all things GPM I expect the PP to Australia will be extortionate! Wefalck - the scale is 1/150 and the opening size, I would estimate, is a shade under 2mm - I plan to use them on the Revell Gorch Foch Regards Richmond
  12. Can anyone help with outlets for generic photo etch parts specifically, in this case, portholes? I have located one outlet in Germany http://www.saemann-aetztechnik.de They have a lots of ladders, stairs, railings winches and the like but they do not appear to have portholes. Regards Richmond
  13. I agree with Etubino - this is a very detailed and interesting log, thank you Adrie. Even more worrying is that we didn't get any rain either!
  14. Dan Those tank tracks put my whinge about the difficulties of skinning of a hull into perspective Nice work Richmond
  15. Firstly I must state that I am finding this model extremely difficult and it has required some rework however I have, at last, made some 'significant' progress. So what has been achieved, well I have fitted the first layer of decks and I have completed the lower level skin. I must say I found the skinning to be the greatest challenge so far - how they expect you to align and abut two skins on 1.5mm of bulkheads and decks manufactured in card I do not know. Luckily I thought ahead and 'thickened' the bulkheads and decks with balsa - I know this is against the 'rules of card modelling' but it suited me at the time - the same effect could have been achieved in card but it would have been more difficult to sand. When gluing I switched halfway through from PVA to UHU multi purpose glue as I found I needed greater grab, however this is because I had got the basics incorrect! I was gluing each skin in one go which leads to 'glue disasters' and dents as you try and hold the skin all together with your hands as you wrap it around the hull until grab is achieved. However whilst work was in progress I received some great advice from Slog who recommended that each skin should be fitted in stages working from one side to the other. Glue at the deck the top (or the bottom as the ship is upside down whilst you glue it!) , set along the glue line with a plastic spatula or such, let it dry and then move upwards slowly to the keel, then around and up again around to the opposite deck, always gluing gradually. This produced far better results as I didn't need to handle the whole skin just the part I was gluing. By the way I also adopted the edge colouring methods in water colours (refer the video I posted in the painting section) and this makes a massive difference to the visuals on abutting skins removing the white edges of the card. Anyway after some rework the results, other than the glue marks which being UHU cannot be cleaned off, are, I believe, passable given this is my first ever card model. I will replace some individual skins I am not entirely happy with and there will be some tidy up especially for those skins that end at the keel rather than wrap around and also for the few times I didn't get 'true' abutment between skins - maybe some GSI Creos Mr Surfacer and then paint. However I will leave it for you to decide from the photographs. By the way I will edit this log later to change all the photographs to landscape (apologies just noticed how visually wrong this all looks)
  16. Great update Slog such fiddly work with fine neat results. I really like the way you switch materials and designs to find the neatest solution - it works really well visually. I think the white works really well on the treads and more importantly our HSE colleagues would love it I really like the effect with the sailor (assume its 1:200) as it gives a great visual perspective of the individual components - I wouldn't mind copying this on my build logs. Anyway I have just set the timer for December 2019 to see deck install
  17. Thank you Doris - Happy New Year The links to your Czech forum work well now I know how to use Google Translate. Richmond
  18. Doris If I am not mistaken that Atlantic kit is over 50 years old and the Corsair is not exactly a new model, how difficult were these to find? By the way your finished models look better than the ones printed on the boxes. Richmond
  19. Slog Fantastic work .... everything looks magnificent ...... the work you have done is the few days you have been back in Perth puts my deliberations on the Mauritania skinning to shame. Do the decks edges remain as are or will /do they get the edge treatment as well? I only ask as I am looking at my unpainted deck edges and wishing they had been given some form of edge treatment (black?) before I glued them in position. Richmond
