Everything posted by grsjax
This 1/48 model of a British ceremonial barge used to be on the CAF website but I can not find it now. Has it been discontinued?
Nice looking boat. Would be an interesting kit in wood and 1:48 scale.
- 54 replies
- BlueJacket Shipcrafters
- wendameen
(and 3 more)
3 kits for sale. HMS Endeavour, Whaling brig Kate Cory and Schooner Lynx. Drop me a PM if you are interested. Shipping is from zip 96720. 1. Artesania Latina HMS Endeavour 1:60 scale. Box is a bit beat up but all there and in good condition. $150 + shipping In the last Endeavour pic the sewn sails don't show up very well. 2. Model Shipways Kate Cory. White box. Box is a bit soiled but kit is complete and in good condition. $150 + shipping 3. Panart Lynx Schooner. Box worn but contents are complete and in good condition. $100 + shipping
While visiting family in Oregon recently I stopped in at Woodcrafts of Portland. They had a bin of Brazilian Ebony on sale. Anyone ever used this wood? Price was a fraction of Gabon Ebony. The wood is very hard, fine grained and black. Not as fine and black as true ebony but very close. It does have a visible grain when you look closely at it and the color is not as black as ebony. However after smoothing up a small piece and finishing it with a clear coat it looks good.
New Workshop Bench Height ??
grsjax replied to PeteB's topic in Modeling tools and Workshop Equipment
I am one of the height challenged at 5'7". I find a bench height of 30" works well for sitting and one 36" for standing. Your mileage may vary. -
You might want to back track a bit and get the Model shipways Lowell Dory Kit as a place to start. It is the first model in their Ship Wright series and guides you step by step thorough the process. The Norwegian Pram is the next in the series. It will take you further along the path to mastering wooden model building.
Thank you all for the good wishes. The surgery went well and I am almost pain free now. Got the first panel on the underside of the boat in place. The instructions say to very carefully line everything up to avoid twisting the frame. I was very careful but when I finished gluing the veneer to the frame sure enough the frame was slightly twisted. Looking at that very thin veneer and the very delicate frame stringers I was thinking that it was going to be impossible to get that panel unglued. I came up with a solution that actually worked and didn't destroy the boat. Lucky I used PVA glue to attach the veneer. Instead of trying to remove it I ran isopropyl alcohol along the glue line, let it sit for a few minutes and then put the boat upright on a flat surface and weighted it down all around and crossed my fingers. I seems the alcohol softened the glue enough that the parts could shift a little bit under pressure. After a full day I removed the weights and checked the alinement and everything was good.
- 14 replies
- Osborn Models
- Sea Flea
Sorry about the long delay getting back to my build log. Had problems with my back and ended up in the hospital. Recovery from the surgery took longer than expected. Almost back to normal now and will start posting some pics soon.
- 14 replies
- Osborn Models
- Sea Flea
Justifying the purchase of a mill
grsjax replied to Captain T's topic in Modeling tools and Workshop Equipment
If you have a lathe you can use it to mill parts. A milling attachment for a lathe is a lot cheaper than a mill and can do most of the milling necessary on a model. Here is a link to one for a Taig lathe sold by Little Machine Shop https://littlemachineshop.com/products/product_view.php?ProductID=1956 There are milling attachments for most lathes on the market so you shouldn't have a problem finding one to fit yours. -
Micro Mark Bending Machine 81356
grsjax replied to Railcardownunder's topic in Modeling tools and Workshop Equipment
This is called a slip roller or rolling mill. The MicroMark item looks pretty cheaply made from aluminum. For a few dollars more you can buy one on amazon that will be much stronger and produce better results. Some of them have rollers that can be changed for use with different size tubes. One thing to think about is that the rollers will flatten wood strips to some extent. one example https://www.amazon.com/Rolling-Machine-Combination-Jewelry-Tabletting/dp/B07G7ZCCSZ/ref=pd_di_sccai_6/143-4564824-7564258?pd_rd_w=ORekI&pf_rd_p=c9443270-b914-4430-a90b-72e3e7e784e0&pf_rd_r=DVFFA5K61C6HG1PNPCA5&pd_rd_r=1679c72e-430e-4e18-8f4c-0b448bac5f51&pd_rd_wg=t3d30&pd_rd_i=B07G7ZCCSZ&psc=1 -
I needed some small turnbuckles for a model and ran across a vendor called Harbor Models https://www.harbormodels.com/ . They mostly sell parts for RC ships but they had just what I needed, 5/16" long working turnbuckles in brass. Dimensions: M=M1 O=8mm (5/16") L-min=13mm (1/2") L-Max=18mm (23/32") D=1.8mm (1/16") f=.7mm (1/32") Price seems pretty reasonable at $2.75 for one or $26.90 for 10. Shipping was fast.
The Bitumen Experiment
grsjax replied to ChrisLBren's topic in Painting, finishing and weathering products and techniques
Depends on the scale. For small scales I go down to 320. Larger scales I use 240. -
Taking a short break to do my taxes. Uncle Sam gets testy if I am late with my tribute.
- 14 replies
- Osborn Models
- Sea Flea
Rotary tools - Proxxon and Dremel
grsjax replied to vaddoc's topic in Modeling tools and Workshop Equipment
I have never had a problem with the Dremel locking pin. I have a couple of older model tools and perhaps they were built better than the newer ones. I also have a Dremel cordless 7.2 volt tool that works very well. I like the adjustable speed of the Dremel. Mine goes from 5000 to 35000rpm giving a good working range for different uses.
