Everything posted by Edwardkenway
Thank you very much for this very timely post! I'm just starting to make some the many eyebolts and split rings.
- 840 replies
- winchelsea
- Syren Ship Model Company
Michael, welcome to MSW
and welcome to MSW
and welcome to MSW
Good to be aboard. Greetings from Alberta, Canada.
Edwardkenway replied to Al Litchfield's topic in New member Introductions
and welcome to MSW. It would be nice to see what you do with the model. -
Ralph, welcome to MSW Your Bellona model looks great!!
Very, very nice, a superbly planked deck Glenn.
- 840 replies
- winchelsea
Stefano, welcome to MSW
With the remove and replace work done, I gave the whole deck another good sanding. and a coat of WOP As can be seen (or not, as intended) the remedial planking worked. No unsightly overly dark planks😊 I still need to do the detailing of the patners and the waterway. I yet to find a satisfactory method of shaping the waterway. I shall try and get these jobs started over the weekend, then onwards to Chapter 5. Thanks once again to all who gave advice and removal methods, all of which helped enormously. Also for the likes, comments and popping in. Cheers
Superb work with the PE Rob! It's looks great! Again there is that Steampunk look of the array while unpainted, very HG Wells
I got several hours on Winnie, and removed the darker planks. I gave a few of the suggestions a try, but in the end the last plank was taken out by running a brand new no.11 blade carefully down the seams and drilling two holes large enough to take my needle nosed pliers, carefully applied gentle pressure and the whole plank came out albeit with the attached false deck. I have some ply of the same thickness to replace that. I'd not edge glued the planks, so they came out easier and didn't damage any of the adjoining planks The planks were cut, shaped and dry fitted glued in and given an initial sanding I'm happier with the result. Thank you to everyone who commented or gave some advice on how to remove the offending planks, I much appreciate the help and encouragement. Also thanks for all the likes and for looking in. Cheers
Wow! As all the previous posts have said, well done for a beautiful model.
- 607 replies
- winchelsea
@FrankWouts @James G @jfhealey Yes, it's the 3 darker planks, they've been cut for over a year and just sitting on a shelf, so I think they've just mellowed. That said, I have decided to remove them and replace them with newly ripped stock. I just hope I can get them out without doing damage to the surrounding decking! Frank, it shows in your hull planking that you have been diligent and patient, as it looks absolutely beautiful. Between you and Glenn(glbarlow), you are setting a standard 😊
Another round of planking finished. the two hook planks went a lot easier this time around. I'm entirely sure wether I'm going to leave those darker planks in or change them. They were a few of the original strips I cut for the hull, They don't look that dark after sanding. so a coat of WOP was applied and I really don't like them, next time I've got time on Winnie I shall remove and replace with newer stock. Thanks for all the likes and comments, and for calling in. Cheers
