Posts posted by realworkingsailor
5 hours ago, Egilman said:
These were built well into the Seaplane era, but were considered flying boats by most... The difference was in the eye of the beholder type thing... The closest technical delineation I can find is a Flying Boat was one that was not designed to land on the open ocean, where a Seaplane was.... The Navy had a lot of both types.... Especially in the yellow wing era...
The JRS-1 was one of the last Flying Boats.... They were mainly used as station craft, (base to base transports where they had a relatively smooth place to land like a bay) and as early warning patrol craft, no active combat role...
Seaplanes could land on the open ocean....
Don’t quote me on this as I’m really no expert, but I don’t know of any amphibious aircraft that are fully capable of landing on the open ocean in anything more than almost calm conditions.From what I’ve read, a seaplane is a catch all term for any type of water capable airplane. A flying boat is a seaplane in which the fuselage is boat shaped and provides the primary floatation. A float plane being the other option.
Andy
- Roger Pellett, mtaylor, Canute and 6 others
- 9
29 minutes ago, Kevin said:
I have to laugh, you can just hear the Newfanese:
"A lot of people's concern is we don't want it to go back out to sea," he told the Canadian news outlet. "If it goes back out to sea, we're not going to know nothing."I wonder what the editors at the BBC thought of that sentence….
Andy
29 minutes ago, Rik Thistle said:
Andy,
2nd and 3rd....yes, a typo is most likely. Just had a re-read of your Churchill links - very useful. But the downloadable .pdfs do take a while - however , I'm not going anywhere so time is not an issue.
I kinda guessed the British Army uniform colours may have been different from the Canadian ones. But I'll figure out a way how their paths crossed in the Archer scenario 😉
Richard
From what I’ve been able to dig up, the 3rd Anti Tank didn’t receive their Archers until much later in the War. Photos of them after D-day show them using American M-10s or Universal (Bren) Carriers towing 6 pounders.
As for when they may have crossed paths, the most plausible would be Operation Totalize, Aug 7 - 10 1944. In that operation 2nd Can Infantry Div And British 51st H Infantry Div broke out over Verrieres ridge along the Caen-Falaise highway.And from the looks of it, Tamiya really botched the instructions as 2nd Anti Tank RCA was attached to 2nd Can Infantry Div, not 3rd. So far all that means that the Division identifier on the Archer should be a gold maple leaf on a blue background as opposed to a gold maple leaf on a grey background.
Andy
- mtaylor, Rik Thistle, Egilman and 3 others
- 6
1 hour ago, Rik Thistle said:
Strangely enough, the Tamiya blurb inside the box says the Archer was used by the 1st Canadian Infantry Division's 3rd Anti-tank Regiment....rather than the 3rd Canadian Infantry Division's 2nd Anti-Tank Regiment? Any thoughts anyone?
Over the past couple of weeks I have also built 5 British Infantry figures...I'll try to use them in any scenario I come up with plus, perhaps, some German road signs (probably made by MiniArt).
Regarding the 2nd or 3rd Anti-tank, it’s possible that an earlier issue of the kit contained markings for the latter, they just neglected to update that part of the instructions.And just to note regarding your figures, the Canadian uniforms, while they followed the same pattern as the British ones, the material was more of a greenish colour. If you do a couple of google searches for Canadian or British battledress there are lots of colour photo examples.
Anyway, can’t wait to see this build!Andy
Thanks Alan, it’s a useful technique any time you need to leave an impression in plaster without messing up that which you are using to impress. Footprints, tire tracks, or even the keel imprint from a boat on a muddy riverbank.
I had hoped to be able to do further work on my diorama this weekend, I had ordered the scenery supplies for the first layers, however it appears that someone in the postal service put my parcel on the wrong truck:
Feb. 2
11:09 am
Item re-routed due to processing error; Possible delay😡😡
So I shall now have to find something else to do this weekend…. I was so hoping to turn that white plaster field into various shades of fuzzy green ground foam…Andy- Egilman, druxey, popeye the sailor and 4 others
- 7
Thanks for the likes and kind comments!
As predicted, adding the spackling compound took a good portion of the weekend. First step was to add another layer to the raised "runway" area:
I did get a little bit of cracking, I suspect this was partly due to the underlying layer absorbing some of the moisture from the top layer, causing it to cure too quickly. Not a big deal as I just went over with a small amount to fill in any blemishes afterwards. I then put on a skim coat over the entire board. This was a very thin layer that will provide a nice base to which paint and scenery can adhere. Unfortunately, the only photo I have of this step turned out blurry and dark. Too much of a rush with the camera (the dog wanted to go walkies... right now!).
Anyway, once that was dry I needed to take care of the "muddy" areas.
I first applied a dollop of spackling compound into the recessed areas and smoothed it out with my putty knife. I wanted to create some wheel ruts and signs of travel. To do this I first covered the area with a layer of cling film (Saran Wrap). I then took a couple of "spare tires" from the Airfix kit that I hadn't yet glued to their respective vehicles (planning ahead here!), and stuck them on the end of a bamboo skewer with a bit of blue tack. Using the matching vehicle to gauge track width, I rolled the wheel through the wet blob of spackling compound. The cling film kept the compound from adhering to the wheels. By applying a bit of pressure as I rolled the wheels along, I could accurately reproduce the effects of a wheel, or a few wheels passing through mud:
After leaving my impressions, I carefully lifted off the Saran Wrap to allow the spackling to dry.
Resulting in a couple of rather stark looking mud holes!
As things stand now, I have a nice white base ready for an undercoat of paint:
I was able to get things fairly smooth with the putting knife as I applied the spackling, there were only a couple of spots where I needed to go over with a little bit of sand paper. I'm not fussed about having it completely flat. Even the most "level" ground has subtle undulations and bumps. Most of the ones noticeable on my board will disappear under the scenery anyway.
Time to get an order in for some scenery supplies!
Andy
- king derelict, druxey, Egilman and 10 others
- 13
4 minutes ago, chris watton said:
James asked me reply, to test the lag.
Hmm… there was no lag for this post, but I haven’t received any notification for your earlier replies.
7 minutes ago, chris watton said:
Testing 2
Hi Chris, are you also getting delayed notifications too?@James H I’ve gone through and thinned down the number of topics I follow, but I don’t think that helped.
Andy -
11 minutes ago, James H said:
Please can you reply again to this?
Sure. It’s been 11 minutes and no notification.
Andy
@James H i am starting this post 7 minutes after you posted your reply. Still no notification (I manually opted to follow this topic when I first posted).
Maybe it is the second issue you mentioned. (I’m only randomly guessing).
Andy
Edit: notification arrived at 13:01 EST, 13 minutes after your post, advising that you had replied “Just Now”
I’ve noticed over the last few days that my notifications are lagging. Alerts for responses to threads I follow don’t show up immediately after a new post has been added (as had been the norm).
For example I am set to follow King Derelict’s Loarre Castle build and a post was made 26 minutes ago.
As you can see here, no notification alert is indicated, yet (?). The last notification being issued an hour ago.
Anyone else having this problem? Any thing I can do on my end to fix it?
Andy
Edit at 9:17 the notification arrived saying the post was added “6 minutes ago”, which still means a considerable time lag.
Thanks for the comments and likes, everyone! 😀
@yvesvidal Almost every dio I've seen online has either a B-17 or a Lanc (or a bunch of Spits), Wellington dios are about as rare as hen's teeth!
Work has begun on the scenery base. I first plotted out where I wanted my terrain features to go with a sharpie on the foam board. I did this with the models in place to ensure the features would fit alongside them:
Apologies for the soft focus on this first picture. In order to differentiate certain aspects, I decided to create a slightly raised "runway" area in the bottom left. Any pictures I've seen of Wellington bases all seemed to have grass runways, so by adding some subtle elevation it would help to differentiate this from the rest of the base. I also wanted to include the effects of less than ideal weather by having a good sized mud puddle. All these other dios seem to depict operations as they would have appeared on a sunny early summer morning. I want to show the effects of a recent run of wet weather. I will also mix in some areas of static grass to detect some less travelled areas, where the grass hasn't been compacted by the comings and goings of heavy airplanes and other vehicles.
To add some depth to the terrain, I "excavated" the muddy areas with a rasp. A nice feature of working with foam is the ability to create below grade features. A good tip is to excavate these features a little deeper than you anticipate needing!
My personal preference for a base material is DAP DryDex spackling compound. It comes ready to use and spreads reasonably well with a putty knife. It handles Woodland Scenics scenery paint just as well as any other type of plaster, and any other products typically used for scenery, and it is less messy to apply and has a decent working time and once dry, it sands well. I should mention too, it's about half the price of WS hydrocal plaster!
The first area I applied the DryDex is the "raised" area. This will take a couple of thin layers as thick coats will be prone to cracking! As you can see the compound goes on pink, but it will turn white as it dries (you can see this transition just starting along the upper edge). The sub scenery should take me most of the weekend, a lot of time will be spent waiting for the DAP to dry.
Not much of an update, seems like an awful lot of words to say "Hey look, I made a pink triangle!" 🤪
Andy
2 hours ago, Rik Thistle said:
Edit: Yes, it looks like the Zuehkle books are available in Kindle format on Amazon UK .... I had a quick listen to the 'Breakout from Juno' Audio snippet .... it sounds detailed and not at all 'dry'....however, the carnage sounds brutal.
Nice! Glad you can find them!
Yeah, the Canadians had a very rough go in Normandy. While the Americans and British garner the lion’s share of attention from most historians, the Canadians have been largely forgotten.
And, yeah, the fighting was brutal. The Canadians suffered a higher casualty rate than either the British or the Americans (while the Americans did suffer a higher absolute number of casualties, in terms of casualties as a percentage of the attacking force, the Canadians had it much worse).
The text in the books is well supported by fairly detailed maps. I have the paperback editions and I had to keep a separate bookmark for the maps section as I kept flipping back and forth to follow along with the narrative.
Andy- Jack12477, mtaylor, Old Collingwood and 2 others
- 5
15 hours ago, Rik Thistle said:
Andy,
Good stuff and thanks.
I'll study all that as I start my preps for the Archer...there is a lot to learn and understand.
Richard
Not sure if you’ve ever delved into a regimental war diary before, but they contain a lot of information. My great-uncle was in the 2nd Medium Regiment, RCA. I went through their war diary last fall (over 8000 pages of records). An incredible amount of raw data, but I found it very much lacking in context.
To paraphrase a sample entry: “Morning, guns deployed at position XYZ, zero lines established. Early afternoon, fired X rounds HE at target ###. Late afternoon X battery shelled by enemy, one OR sustained minor injuries”All great information…but what exactly just happened?? In my case I’ve been reading a series of books about the Canadian actions in the Italian campaign (where my great-uncle was deployed), finally I’ve been able to establish the “why” and the “what”, the context that was sorely lacking.
If you’re interested, and if you can get them, there’s a series of books by Mark Zuehlke that details the Canadian army campaign(s) in Europe. Three of them (Juno Beach, Holding Juno, Breakout From Juno), would cover the period you’re looking at. They’re quite detailed, but a reasonably easy to follow narrative (and, critically, no editorializing, save maybe a reflexive epilogue).
Andy
- Canute, mtaylor, king derelict and 2 others
- 5
Then on to the Tamiya Archer self propelled gun. That will take a good bit of reading up on the Canadian Divison that used them in Normanday - that will be interesting.
Richard
From what I’ve been able to dig up, the 2nd Anti-Tank Regiment, Royal Canadian Artillery, was equipped with Archers from Normandy through to the end of the war. If you scroll down through here:https://www.silverhawkauthor.com/post/royal-canadian-artillery-rca-first-canadian-army-north-west-europe-1944-1945 there are a few photos of the 2nd in action with their Archers in the Rhineland in early ‘45.
The regiment’s war diary is available online: https://recherche-collection-search.bac-lac.gc.ca/eng/home/record?app=fonandcol&IdNumber=926793
They had an interesting day outside of Caen in July 1944:
https://www.wartimes.ca/forums/viewtopic.php?t=1401
Hope that helps!
Andy
- Old Collingwood, Jack12477, Baker and 3 others
- 6
Really looking great! Your experience with the WS coarse turf is typical, not much you could have done differently, larger scale or otherwise. Not sure why they insist on selling it in shaker bottles, I guess it stores better on a shelf! You’re working at a scale where it best represents scrubby bushes, so placing down one small clump at a time is very effective. Model scenery is, at best, an illusion meant to fool the eye when viewed from a typical distance.
Keep up the great work!
Andy -
What you may wish to consider, is before adding your top fixative, spray a mist of water mixed with isopropyl alcohol to wet the surface of the WS ground foam. This will help the glue (or acrylic medium) to wick into the foam. Otherwise you run the risk of having the ground foam forming a hard shell, top and bottom, with an unglued middle. Long term this will be prone to cracking.
Wetting the ground foam also has the added benefits of keeping it in place when you drizzle on the top coat of glue, as well as helping the glue cover a greater surface area (meaning you’ll need less glue).
Otherwise, it’s looking very good!
Andy
One thing is for certain, when you have momentum, things can happen quickly! I stopped by my local hardware store this morning and picked up a piece of foam insulation board. It's not pink, or white, or green, but a neutral grey colour.... anyway, it's the good high density foam board perfect for my needs. It's a 2" thick board so it is more than rigid enough for my purposes.
Of course, I couldn't wait to cut off a chunk of that 2' x 8' board and try out some ideas on how I want to see everything arranged.
I started off with a piece 18" x 24", which worked out to be about the same size as my cutting mat. I am a big fan of empty space in a scene. I think a subject needs space to breathe in its surroundings, and the more things that are "happening" in a scene, the more space it should have. Rest assured the "empty" space won't be entirely empty, nor will the ground be a generic green carpet of "grass". I will endeavour to make the landscape look suitably trodden and driven over, maybe even a mud puddle or two (England is stereotypically known for being a damp country, accurate or not).
To bring the viewers attention to the exposed engine, I figured this "maintenance" scene would be enough to draw people in.
While on the other wing, refuelling is underway.
Out in front a bomb train with the night's payload is getting into position while some other airfield traffic is passing by on the verge of the grass runway/taxiway. Realistically, if you follow the film I previously posted, the incendiary bombs would travel, and be loaded separately from the conventional bombs, but I've only enough parts for one bomb train. The figures will loose their bases when it comes time to place them about the finished scene, so they will shrink by about a scale foot.
Time to make a shopping list for the scenery items!
Andy
11 minutes ago, Egilman said:
Make sure it's the high density stuff, (I prefer the blue) the lower density stuff (pink & white) is too fragile....
Oh yes, not to worry! 😁Any of the pellet-y stuff (white or whatever colour) is only good for coffee cups. I’ve been around the pink board in a model railway situation and it seemed to work well enough (but yeah, it didn’t take impacts very well). A layer of hydrocal plaster on top can hide a lot of incidental divots.
Andy
1966 Buick Riviera by CDW - FINISHED - AMT - 1:25 Scale
in Non-ship/categorised builds
Nicely done! The paint job and the chrome work turned out amazing!
Andy
