realworkingsailor
Everything posted by realworkingsailor
  1. Sjors: She's a very traditional laker. The forward house has the wheelhouse (pilot house) on top, the captain's and officer's quarters just below and the deck crew's quarters just below that. The after house has the engineer's quarters, the galley (and galley staff quarters) and, of course, the engine room. Hope that helps Andy
  2. Sjors, to chafe means to cause damage by rubbing against something. Andy
  3. From what I've read, the shrouds are served down to the level of the hounds (basically the level of the futtock staves). Also the leading shroud should be served its full length to prevent chaffing from the sails. Andy
  4. Well... I admit, I didn't quite stick to the plan as I had laid out earlier. I did get one section of the hull added on.... but....that large-ish hole in the fo'c'sle deck kept calling to me and I couldn't ignore it any longer. Starting yesterday I've been busy building a new forward house from sctatch. All styrene, of course. It's what you would call a "selectively compressed" version of the real thing. Taking the key elements, such as the shape and general arrangement, some compromise (reduce the number of portholes and doors), and you get something believeable, that anyone who knows the real ship, would recognize. Admitedly there should be a tad more curve in the front of the house, but I'm happy with what I've got. There's still a lot more to do... like the sub-deck framing, the upper bulwark framing, doors and other odds and ends, and eventually the pilot house. The large square holes in the aft end are ladderways. I figured them out when I took a good look at the second prototype photo I posted. I noticed a jumble of railings just inside the aft corner that could only come from a ladderway. You can see the difference when you compare the kit supplied version. There is fundamentally nothing wrong with it.... it's just not really proportionally correct for this build. I'll be away for a couple days, I have to take a ship up the river and I fly to Montreal late tonight. I should be back late Monday, early Tuesday. Andy
  5. Gee..... That serving machine looks awful familiar......
  6. And no warping either! These guys: http://www.imaginethatlaserart.com/ , make a full line of laser cut architectural and railway models out of mdf. Amazingly well done. Andy
  7. Very nice. But then again.... You should have some practice with that sort of thing by now Andy
  8. Very well done Congratulations on completing her. Good Luck on you other unfinished ship(s). Andy
  9. Glad you guys are getting something out of all this. What's nice, at select places there are great viewing platforms and interpretive centres that allow people to get up close with the history of the region, and the ships that still ply these waters. Andy
  10. I do enjoy working with styrene plastic. There is such a nice variety of structural and dimensional shapes on the market, if you can imagine it, you can build it. The fun part comes when grafting styrene to polyurethane resin... CA can really test your patience at times (the infamous "why the heck are my fingers stuck yet part "a" has not bonded to part "b"?!?!? Ratzafratz!!!" statement springs to mind ) Andy
  11. It may seem strange, but at one time the vessels plying the inland Great Lakes were some of the largest in the world. Even in the mid 20th century, most ocean going freighters settled comfortable around the 500 foot mark, lakers were already into the 700 foot range. Thanks to the opening of the 4th Welland Canal in 1932, ships of up to 730 feet could make the transit down from the upper lakes (Superior, Huron, Michigan and Erie) to Lake Ontario. At that time, the largest ocean going vessel that could reach the lakes was limited by the locks and canals of the pre-modern seaway. Smaller vessles, known as canallers, would tranship from lakes ports to ports on the lower St. Lawrence river. They were limited to a mere 261 feet long by 40 feet wide and a maximum draft of around 8 or 9 feet. These were small ships, but there were LOTS of them. In 1959 the current Seaway was opened. This allowed passage of the largest lake vessels (at that time) to the lower river, it also reduced the total number of locks from 28 to 7, between Montreal and Lake Ontario. The old time canaller sailors used to joke, that they would litterally walk from Cornwall to Montreal. This also meant the end of "Canal" sized vessels, as they were no longer efficient in the face of the larger vessels. Aside from specialty ships (cement carriers or package freighters), most canalers were gone by the end of the 1960s. The last unaltered canaller currently sits at Industrial Marine and Salvage in Port Colborne Ontario. The crane ship "D.C. Everest" (1953) was last used as a barge. She now sits awaiting her eventual fate. Another small update. Have completed the fo'c'sle bulwarks. Made of styrene sheet and strip. Each frame, and the bulwark was made from 0.030" styrene. The flanges and cap rail are all 0.015" x 0.080" styrene strip. I used the moulded on rivets on the hull as a reference for spacing the frames correctly. It will need a little touch up with filler along the bottome outside edge to fill any remaining small gaps and inconsistencies. But otherwise, I'm pleased with the result. Now it's time to get serious tackling the stern and mid sections and get that hull put together. Andy
  12. Resin can be quite fickle to work with. Although you can take great pains with making a master, sometimes things go a bit sideways. As I pointed out earlier, inconsistent wall thickness is frequently one problem. Warping of not fully cured pieces is another frequent issue..... I have to straighten out a few pieces with this kit. Other inconsistencies can be attributed to the moulds. A good analogy would be the degradation you get when you make a photocopy of a photocopy of a photocopy. Don't get me wrong, small detailed pieces can be replicated quite successfully, the same doesn't always hold true for large kits. You just have to be ready with a good file, plenty of filler, and a good sense of humour. Andy
  13. A small update to report. I've made the fillers for the open hatches on the main deck forward. Simply 0.030" styrene with some styrene re-enforcement underneath. I've also fitted the forward bulkhead and fo'c'sle deck. You can see I've also made good use of green putty. This stuff (Squadron Green Putty), although incredibly smelly (toluene....bleh), is another must-have for a build like this. Resin kits are notoriously imprecise in their construction, in order to have an acceptable finish, filler is needed. I've also cut down the forward bulwark to the stem. The prototype had the bulwark running much further back. I debated grafing an extension onto the existing part, but decided that it would be easier and neater to do it this way. Besides, I can now add all the structural framing. After I finish the bulwarks, I've got the stern to consider, then I'll move on to the main deck and start adding some length to this monster. Andy
  14. Actually, now that I look back, there's one nice photo you have of the sub surfacing, you can see the fairlead(s), and even you can see it also had a sheave in the middle too... Andy
  15. If you look back at some of your prototype photos, you can see them in use. Yes,, they are simply smooth guides for passing mooring lines through to the bitts. The open top just makes it easier to place or remove a line, rather than having to run the whole of the line through. You see that style more on smaller vessels with lighter mooring lines. Large ships with heavy lines need full fairleads with no open tops (generally speaking, a stronger fairlead). Andy
  16. As far as the bulker trade goes, the unloading gear is set up for it, remember the picture I posted of the grain leg? Hullet unloaders for iron ore are also quite narrow. http://m.youtube.com/watch?v=JErREoMOdDc&desktop_uri=%2Fwatch%3Fv%3DJErREoMOdDc Self unloading gear, although sometimes added as a later conversion, made the need for shore unloading gear completely obsolete. Andy
  17. Hi John, This is quite a normal setup for lakes vessels up until the later half of the 20th century. In salt water vessels, heavy transverse bulkheads between cargo holds add lateral strength to the vessel's structure. In lakers, the transverse bulkheads are little more than screen bulkheads and contribute little to the structure. Consequently the ships are fitted with numerous transverse deck beams. In order to open up as much of the holds as possible for loading, multiple small hatches are used. This is also another reflection on the nature of the cargos carried, primarily bulk ore, coal, stone, salt, grain and cement. Theses products do not need large hatch openings for loading. Andy
  18. Continuing on this morning with the completion of the port anchor pocket. I then moved to dry fitting the next hull section as well as the first two sections of the main deck. All of this involves much fitting, filing and fitting again... to be followed by more filing. This will continue for some time yet, until I can manage to get things fitting as closely and squarely as possible. Only then, will glue be applied. If you look closely, I've also removed the hatch coaming for the first two hatches. This area will largely be taken up by the above deck portion of the self unloading equipment, namely the top of the loop belt casing, the A-frame support for the unloading boom and finaly the pivot, trunion and heel of the unloading boom itself. I've saved the coamings for later use, as I mentioned before, this ship would count as a "hatch farm" and the number of hatches will need to be almost doubled. Most coamings will need to be scratch built, and these two will serve as patterns for them. Eventually, they too will find a home on the deck. Andy
  19. First steps of this build involve the creation of anchor pockets in the bow casting. If you look at the prototype photo, you'll see the original had the anchors recessed into pockets. The model lacks these and shows simply an embossed ring where the hawse pipe penetrates the hull. Using a waterline marking tool, I marked out the top and bottom of the pocket (hopefully symetrical on each side), and then marked the sides. I drilled the four corners and then cut out the rough dimensions of the pocket with an x-acto saw. Cleaned and squared up, the inside top, and outside bottom edges where beveled. Using 0.030" styrene I then created a basic pocket. A simple prismatic structure. This was then glued to the inside of the hull. I had a spare anchor from a previous build that I used for testing and reference for size. There is still a bit of refinment left to be done, mostly with some styrene shapes (1/4 round on each side and 1/2 round just below) as well as some putty work to smooth everything out. It's important to do these kinds of modifications now, before hull assembly, as things get a little difficult to manipulate later on. Doing this you can get a sense of some of the drawbacks of a resin kit. Very quickly on I noticed the wall thickness of the casting differed by quite a bit from side to side. Normally this wouldn't be a problem, since the kit was never designed to be treated in the manner to which I am subjecting it. This should be the last time I have to do any major modification through the lower hull. When the fo'c'sle deck goes on, I will use a piece of aluminum tubing to complete the hawse pipe connection. Although this detail can't be seen, leaving it off would leave odd holes in the deck that would not look right, and could potentially spill light where I don't want it. (Yes I am planing on illuminating some parts of the model). Andy
  20. Hi Lawrence, I am home. Still trying to get back into ship building mode. I'm picking a little bit at my other build, as well as tying the odd ratline here and there on the Pegasus. Andy
  21. Hello everyone. Glad to see such positive responses. I'll probably be starting some of the actual construction tomorrow. Or at least, the first preparations. JP, I did a quick query on polyurethane plastics, I've used them before with no ill effects, and my research seems to back this up, at least as far as fully cured polyurethane polymers are concerned. My biggest issue will be with the CA necessary for assembly. I've used epoxy in the past on resin, and aside from being a bit more of a pain having to mix batches of it, I also found it very finicky in bonding with the resin.... Things had to be just right every single time... Otherwise I'd be flicking cured epoxy off with my fingernails. John, yes the extra midship sections are fully equipped. One issue I will have to deal with, I need to add more hatches. Lakers of this era were known as "hatch farms" due to the sheer numbers of hatches. All manual, telescoping, tarp and wedge work for the crew. I'll keep you all informed as I progress on this one. Andy
  22. The basic kit is 3 feet long. I've added two extra midsections (at 10" each) for a total length of 56". Make no mistake, this thing will be huge. I will need a long rigid building board for this beastie. Just for good measure, in the last photo, I've included my Pegasus in the background for comparison. I will be picking at this build from time to time. I don't expect hull construction to take very long, the fun will be in the painting and detailling. I've got a lot of work ahead of me. This has to be a showpiece model, given it's location. For more information on the club check out: http://www.railviewmrc.ca/ For any of you who might be intrigued enough to try a large resin kit, have a look here: http://www.sylvanscalemodels.com/ Andy
  23. The instructions that come with the kit are familiar to anyone who's built a model railroad resin kit before. Somewhat basic, but they cover everything. As is typical with railway kits, they come with an exploded isometric drawing of the whole kit. This has it's uses, and since most of the details are somewhat molded on, accurately locating pieces is not much of a concern. The back page(s) include detail drawings of various pieces like the wheelhouse interior, winch and windlass construction etc. Andy
