Everything posted by Mirabell61
Patrick, thank you very much, your kind compliment is well appreciated... Nils
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Thank you so much Denis, David and Piet for your kind words.... Also thanks to all the "likes" Denis, there have been no additional fitting out details to the forcastle-deck, its about complete as is.... David, I`m very pleased you like the model, still quite a way to go... Piet, hope you had no hurricane related damages.... and thanks for your nice words, I saw you had a good catch up on the model`s progress Nils
- 2,625 replies
- passenger steamer
thank you very much Jeff, I also love visible figurines on deck for the same reason as you do. For this project I have been collecting over weeks and months crew members, officers, and (seated, standing, walking) passengers in period fashions, these will be placed in the appropriate decks and places on board. Nils
- 2,625 replies
- passenger steamer
Hi B.E. many thanks for your kind compliment..., in the moment its taking quite some time to get these little things together, but in the meantime..... If you wish, and for those who are also interested in the present status, so to say what has been done since keellaying in June last year, here some illustrations I picked out.... Nils
- 2,625 replies
- passenger steamer
Bob, thank you very much.... I did a fiddely little cabin today which is situated right in the middle on the aft structure`s roof, still need to do four lights on that area as well... Nils
- 2,625 replies
- passenger steamer
nice detailwork Denis, do you have a fish-load for the boxes ?, also need some hoses and appropriat connections for flush cleaning boxes and deck afterwards... Nils
Denis, thank you for your words....., very much appreciated.. Nils
- 2,625 replies
- passenger steamer
Good fix of the stairway parts and positioning for soldering. Are you going to going to torch solder ? Nils
- 749 replies
- albertic
- ocean liner
- 2,625 replies
- passenger steamer
Hi Steve and Bob, thanks for your nice comments, Steve, yes, by concentrating on little sections it provides rusher results, and a better feeling that something got done, and so by and by the total progress can be seen Bob, in opposite to the forecastledeck the railings were not soldered on, but only fastened per CA, because I remember having trouble with the elonggation of copper versa brass when soldering the railings to the bottom base rail. I first tried to bend a L-profile to the curve pattern but gave this up very quickly and used solid brass bar 1 x 1,5 mm. thanks also to all the "likes" for clicking on... Nils
- 2,625 replies
- passenger steamer
Update, aft deck housing roof (planked deck) with docking bridge and railing. Access will be from aft over a stairway Nils
- 2,625 replies
- passenger steamer
ancre La Salamandre by tadheus - 1:24
Mirabell61 replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Pawel, that "Totem Pole looking ladder" is great, simple and effective... Nils -
those storage lockers on the foredeck look great Steve, Nils
- 208 replies
- john cudahy
- finished
Both are looking good Bob, so the decision to build both is just right. Wish you all the best for Keellaying these days.... Nils
Hi Michael, sounds awfull with your shin wound, at least no fracture, wish you a speedy healing process........ Nils
- 749 replies
- albertic
- ocean liner
thank you for your appreciations Keith, Hartmut and Denis, and those who hit the "likes" button I`m very pleased you like it..... Nils
- 2,625 replies
- passenger steamer
Hi Denis, thats the spaces for air collection- and distribution boxes.... below the deck are situated Pantry (kitchen) and smoker`s lounge Nils 4 skylights and 7 vents on this little platform
- 2,625 replies
- passenger steamer
Thank you very much Albert and Carl, for your nice compliments Nils
- 2,625 replies
- passenger steamer
Hi Michael, perhaps, if of use for you, here two suggestions..... cable cord: I use very flexible control wire for flying wire control model aircraft in two different diam. one line is 0,3 mm OD and consisting of 7 strands ( each 0,1 mm) of tin galvanized steel wire. this can be easy and durable soft soldered and secured with mini metal beads The other line is 0,5 mm OD and consisting of 19 strands ( each 0,1 mm) of tin galvanized steel wire. this can be easy and durable soft soldered and secured with mini metal beads Lifeboats: here is a sample in scale 1:100 appr. 86 mm long, for an open lifeboat with rimm and seats, its plastic, but when painted has a good appeal.... (they come 5 a pack for a very reasonable price) Nils
- 749 replies
- albertic
- ocean liner
Hi Michael, I`m following your restoration with great interest, for its not only showing your progress in work, but here and there also a little glimpse at how the builders made it. I wish you that you keep up with the drive and pace and turn the "Albertic" to new blossom for display again. I also have many over 10 years old Humbrol paints, but most of them have dried out although the cans were closed..... Nils
- 749 replies
- albertic
- ocean liner
thats going tobe a very fine boat Mike, love the shape. I would also arrange for holes and secure fastening points for the pedestals at this stage... Nils
- 129 replies
- finished
- model shipways
