Mirabell61
Everything posted by Mirabell61
  1. update... been building the two bases for the machine-room skylights, above the engine room shaft, that bear each six ventilation skylight housings with again each 6 panel flaps. So that will be in total 36 opening flaps with each 4 round light openings ( 36 flaps x 4 = 144 "portholes") This surely will take some time from now on. The flaps will be made from 8 mm wide brass strip, and the "portholes" like I usualy do it... Nils sample of this detail borrowed of a card build model from the web..... trying for the right hole pattern (4 holes) per panel. The upper 4 ones look OK. The hole-frames are made from shortend hollow rivets and soldered on to the panel The green tape is for preventing the bottom ventshaft rings to slip off and get lost
  2. Thanks Ed, for your feedback and input, love those little episodes, wish I had some more historic pictures (old photographs or so...) Nils
  3. Hi Rpeteru, thanks for looking in again and hope you liked the progress inbetween. Also thanks for your nice compliment, you`re very welcome.... Nils
  4. Thank you Druxey, the fact that there are 7 sizes of vents and individual numbers that provide a little variation in the mass production...., but still in total 87 vents Nils
  5. Hervie, thank you for your interest in the KWdG, and for your compliment. As I mentioned in the introduction to this build, I was also fascinated by this liner built way back in 1897, and somewhat amazed to see one day that there was a card model for experienced model card-builders. I unfortunately do`nt have the steady hands and the patience to build a card model myself in this category, but one day had the idea to see if it would be possible, (amoungst other information) to scratch-build a model in a larger scale, and then the project was born and under steam. Problem was that the card model set for comparism was completely sold out, and it took me some months to finaly search and detect an used (but unbuilt) edition via Ebay Nils
  6. Many thanks Nenad and Carl, and all the "likes", very much appreciated Nenad, I`ll be very pleased if there is something wich may be motivating for your CS model fitting out, but you do have so many own good idias I like very much..... Carl, exactly, the footring will prevent the slipping down of the tube, after adjusting the hight, the close fitting ring will be secured with a small drop of thin viscos CA. Upwards it needs no limitation, and still the scoops can be turned to the wind, or out of the wind in "suction mode".... Nils
  7. Hi Lawrence, thank you for your nice words, I`m meanwhile still at the boats deck and doing the coamings for the superstructure it`s planking with pencil caulking at the edges, on 2 mm wide 0.6 mm thick srtips Nils The hights of the vents, above deck, still need to be adjusted later on The three aft winches will be in approximately these positions here planking of the aft boats deck has taken place ( no fairing done to it yet )
  8. Hi Hamilton, very nice model and sails of the "America" Nils
  9. A facinating build Chris, I love your color scheme, it looks great Nils
  10. Hi Mmdd and Gary, and thanks very much for your nice compliments, very much appreciated ! I`m concentrating on the boats-deck now and its fitting out Nils
  11. nice progress Denis, looks very good with the canvas at the railing.... Nils
