Mirabell61
Posts posted by Mirabell61
  1. Hi von Kossa,
    I just had a look into your viking boat...
    It Looks fantastic eapecially in Details like sail, clinker planking, bow decoration, all Framework, bow decoration, rudder, mastfoot, and , and..
    It is amazing how much love and authentic Fitting out you are putting on top of what the kit provides, a real Little treasure, love it..
    Nils
  2. the first of the four gunport doors is attached, functional with hinges
    I let the Pivot rod go through both hinges, this gives more stability to the function, although I was intending to cutawy the rod in the middle space
    here open...
    In one of Danny`s last Posts (Vulture 1:48) he mentioned the scuppers for the Manager pit. I had not been Aware that there had to be some although it`s quite Logical to catch the dirt and mud on the anchor cable behind the hawse hole, and for rinsing reasons.
    I set the brass tube scuppers in about 5 degree declining downward from Managing pit (deck) to the upper Portion of the wale, above that Little decor
    Nils
  3. Have to do the first two and the last two gunport doors, will try to get the hinges functional working...., here first try (the 1 mm round bar shall be cut to fit later on)
    the small parts from the etched sheet are soldered to the 1 x 2 mm Tube, then cut off...
    here also the Counter hinge part that goes to the hull above the gunport, the small Pivot rod is 1 mm
    will AC glue the Long hinge parts to the gunport door (have to do the doors first and fit them in...)
    Nils
  4. Build log part 32
    Today I started a Little bit on the anchor System, fitted two rollers under the forecastle deck, to return the Messenger cable without much friction (will Show later on when the cables get rigged)
    I am planing for the anchor cables to go right down through the gundeck main hatch, and to the cargo floor, to be coiled and tied on top of the cargo Barrels. There is not much hight left but I think it will do for several rounds of coiled (tied) cable
    this is the smaller anchor behind the main one,
    in the foreground the larger anchor (6 raps around the stick)
    the gundeck capstan with 2 stopper clinks, (simple Version)
    the foreward riding bitts
    Build log part 33 to follow....
    Nils
  5. Nils, thank you.  I'm really enjoying this and I need to thank my wife in part for finally starting.  We have recently become empty nesters as my youngest daughter is now a freshmen in college.  My wife told me to stop bothering her and get a hobby, so here I am.
    You have a wise wife Sal,
    and you made a good and right decision..
    Have fun with this Hobby, it keeps those old brain cells on challenge mode
    Nils
  6. The stove looks pretty rugged, and the distiller is a neat idea, I suppose they thought about Rum too?
    Michael
    Thank you for your words Micheal,
    I have several ideas up the sleeve as well, but do`nt know yet if they can be realized in that way...
    since B.E. told me about the what all devices are involved in moving, stowing the anchor cables, I Keep on thinking how possibly this can be done best on my model
    Nils
  7. I like the distiller. To answer the question, distilled water would be salt free and mineral free, for that matter.
    It would be a not very efficient way to make water, but in emergency its would do. Basically due to what Jason mentioned of the fuel required to boil the water, but if the stove is going anyway the excess heat might as well be used to get as much out of the fuel as possible and distilling water or spirits would be a good use for this.
    Kind of like cooking a big pan of soup in the winter to help warm up the house, which is efficient unlike cooking it in the summer and having to use A/C to remove the heat from the house. Sailors were masters of efficiency as it tended to help extend the length of life in an environment that could be hazardous and unpredictable.
    Anyway, nice stove Nils, I like the rivets. Its added a nice touch.
    Thank you Keith,
    I`ve learnt quite a lot in the last days for anchor cable rigging, for condenser devices, distilled water, etc all from fellow members, this is great Input...
    Nils
  8. Galley stove continued.... and ending
    spit roast supports and crank handle
    here for Crackers and B.E.
    Making of drinking water for the Crew from distilled seawater
    condensate collector Barrel with drain tap
    also hinges to the stove doors and to the chimney flap
    The place between stove side and Barrel is for the cheeks of the riding bitt supports
    all at ist place on board for fit check
    Nils
  9. Thanks Terry. I'm afraid that the only thing I could teach is to grow older, have more time for modeling and substitute more patience and perseverance for diminishing physical capabilities.
    Sam, it's good to hear from you. It's been a while and I was getting a little concerned about you.
    I've now made and installed the chain pumps, their aft cranks and crank supports and the pump dales. The pumps were made using the kit laser cut pieces as forms for boxwood planking. The cranks are blackened brass wire and are simplified due to their small size. The forward cranks and supports will be added as I move forward on the gun deck. I am in the process of making the remaining quarterdeck framing and the main jeer bitts.
    Bob
    lovely work Bob,
    especialy in the scale you are doing it...
    Nils
  10. Thanks Crackers,
    again I learn something new,..... I saw that funny looking horizontal turret on stove Pictures before, and not knowing what it was for, I did`nt do it, guess they did`nt have cans of cooled Coke for the Crew on board, and the rum would`nt last for ever.
    In this case there would Need to be another collector-barrel for condensated water at best near the stove..
    Nils
  11. Build log part 30
    next will be the galley stove I did yesterday, but I still Need to fit the spit roast with its Elevation devices
    this is the stove raw material, 20mm square bar
    cutting into shape, and an Adapter for the chimney pipe
    cutting out the fireing and baking space
    drip pan for the spit roast side, Support logs and baseplate
    further Fitting out....
    riveting the corners
    to be continued....
    Nils
