Posts posted by Mirabell61
Thank you for looking in and your comments, Amfibius.
I think I have finally finished !!!
Have made up a deck pump from a combination of one from Caldercraft and an Amati one. Although I still have another one to do I may not fit them on the ship as there is really no space - gets a bit tight. The handle had a bit of walnut strip added both sides and sanded round otherwise it would have been flat brass.
Anchors fitted.
Rounded lump added for the sling to sit on - plus having been very impressed by Beef Wellington's (Jason) serving thought I'd have an attempt on the slings.
Final photo
Thank you for looking and and all the comments and those on the old site whose build of the Supply helped me get started. Hopefully I may have helped someone in return.
Again thank you
Regards
Doug
Beautiful build Doug,
a wonderfull sight your Brigg Supply
Nils
Build log part 9
this is the last part of this build,
although the are some Little things I would like to add, or to Change next time I open the glass case
I was quite happy that the glass case fitted exactly on the wardrobe it is Standing on
the brass data plate is fitted within the case
Impression of the plating bow area
and Stern area
this Position is concentrating, nearly interfearing on railing, funnel stay, steering chain, Davit tackle, but all is properly fastend to it own tackle point
foredeck is a nice Meeting place for Young couples
foreseen anchoring place
the depth marking is made with regular Mirosoft Excel and to be printed out on one side adhesive transparent foil, or on Photopaper. Shall save this up to the next opening of the glass case, when the sternlight is also to be changed from green to White.
I hope the presentation of my Bohuslän build log was liked, even though the framing, planking and hull building was not shown in this case due to lack of photos
Auf wiedersehen
Nils
- Aussie048, chevygrunt, IgorSky and 20 others
23
thank you Bob,
I got her out of the dark when I was looking for an object to do Trial metal plating on. I was satisfied with the result and transfered the technique to the other follow builds. At that time I recognized what a gem that old Lady was, and I decided, it was definately worth finalising her. Many of the original kit parts had gone lost, the Panels for cutting out the small parts were wavy, but the lifeboats I built in the early beginning, and they were carefully wrapped and secured in a drawer in my bedroom, and I still had the overview drawing
Nils
Nery nice build Ships88,
your Peregrine Looks great
thanks for reposting and for sharing These Pictures
Nils
Druxey There ya go
Kieth I am glad that you can use the saw blade trick.
Mark Thanks
And than you all for the likes.
Michael,
what lovely hinges together with the woodwork, it must be real pleasure for you to do These Details in such a fine precision
Well done !
Nils
I was not very happy actually with the set of four new hinges so today I began a third set, this time I did not anneal the brass but bent it cold, and scaled up just a little by using a 1/16th end mill. The picture shows a steel rod acting as a bit of a drill to clean up the holes after the milling
The next picture shows the new hinge made today next to the slightly smaller earlier one. the new one looks a lot tidier to me
Set up in the companionway.
I added some small bevels to the door frame. tomorrow I will finish the second set for the other door.
Michael
Thank you for your words Joe,
I am glad you like this old Steamer, it is quite a rare kit...
Nils
Bob,
well done painting on the Stern decoration, precise and accurate !
Nils
Build log part 8
the horizontal steering Segment is made from a clockwheel of on old mantel clock. Belaying clamps on lower deck railing fitted
Sven is just inspecting the starboard inflatable liferaft Containment. Here for Popeye..., slotted turnbuckles for the aft mast shrouds
Davit and lifeboat rigging, wooden oar sets to the boats
Position of the stairway from lower deck to bridgedeck. Right bottom Corner... the drainpipe opening on deck
here the steering chain leaving the wheelhouse can be better seen
the upper deck was designed in the way that the stair and its rail as well as the entrance (door and its Frame stay Standing when the comlpete upperdeck is removed. Because I made a static model of it the upper deck is now fixed on with two small hidden screws
the riveting gives the real 1914 look... to the hull
Build log part 9 (last part) tofollow with next post....
Nils
I've gotten some in a few of my Billing kits. did you slot them like that? I noticed the way you did them....very nice
Popeye,
I get These functional turnbuckles in different sizes, lengths, from M1 thread onwards from my Hobby shop and in two Versions (slotted and with eyes)
Nils
Nils, Ah yes, why? I could have bought them off the web for a lot less than the time I spent making them. I guess there are two reasons. First I didn’t have any the right size and didn’t want to wait to receive them in the mail. And secondly it was just to see if I could.
Paul, glad I can be of help.
Bob
Nice answer Bob,
that ist he true model builder speaking...
well done !
Nils
Build log part 23
I would so much like to carry on with the bow area, but realize that there is a lot to still be done underneath the forecastle deck first. Think I will have do the stove and other Details in near future
the portside guns will be rigged Standing on the Support rails under the carriage wheels
all te svivel gunposts are only in "raw" condition, may want to get them 8-sided in upper portions
Status overview
just Setting the new guns in place for Dimension checking
I tryed to get the rudder coppering only, shiny again, used Lemon concentrate Juice, it works very easy
but I don`t know if I should have done that. I love the greenish Patina look like some others have tryed already
Nils
- Elmer Cornish, maurino, Dubz and 11 others
14
Build log part 7
here the baseplate for the casing, the standplate and the two pedestals have been made (pedestals again made from old candleholders)
foredeck completed together with the selfmade anchor winch
the steering chain leaves the wheelhouse, is turned 90° over a block, under the Little bench, and heads under the lifeboat towards Stern over the boats deck in guided stanchions
Stern flagpost and capstan added, and two life-raft Containments in their launching racks on the boatsdeck. The ruddershaft in its sleeve-tube goes through all decks
anchor winch
who saw the mistake ? (Sternlight should be White instead of green)
Build log part 8 to follow....
(part 8 + 9) shall be the last two intended parts for this build
Nils
- avsjerome2003, captainbob, NMBROOK and 8 others
11
Doing the guns in repeatable mode saves some time, once the method is on track...
My work desk is quite a mess, since I have my own room and do`nt have to clean up during the day, and I still have 4 more to do.
Am thinking of adding small wooden splints to the axis close to the wheels, but shall do that as last Action
Nils
Trial #1, small wire Pins secure wheels on axis
Trial #2, small wooden splints hold back the wheels (I prefer this Version)
Gun builders desk
have 10 done so far, 4 more to go..
- mtaylor, Barbossa, marktiedens and 9 others
12
Popeye,
a very nice looking build your Gothenburg. I`m not up to date with Billing Boats.... is this an older model ?
The kit Looks to be quite precise and comprising Details to the score
Thanks for sharing this one, shall stay tuned for more
Nils
Bob,
nice method of doing the deadeyes, respect, but lots of spanning, drilling and Fixing work....
Question, why do These yourself, is it because of "throughout scratch build" ?
Nils
Congrats to your completed build Peter,
the Irene is a wonderful built Little gem
Nils
nice use of the turnbuckles and cabling, as I mentioned, your metal work is amazing
Thank you Popeye,
The use of These turnbuckles is a great help to strumm set the cables and stays
Nils
The lower hull has been sanded and treenails drilled and filled with plastic wood. So I am definitely not painting the hull. Also, since I did a bad job on the rudder, I made a replacement out of spare wood from one of the pieces that contained the frames. The new rudder is visible in the first photo.
Well done planking Ken,
your neat built model in all is looking wonderful
Nils
David,
thank you for your comment
Nils
Build log part 6
wheelhouse with hinged door, Bridge grating, port nav. light, bell and 90° Lever for operating the steam whistle (per wire Connection to the funnel)
starboard side with lifevest chest
here a nice brass anchor, modified a bit, will be blackened later on
here again one of These Little benches on Bridge deck
Crew and Gothenburg passengers boarded for a next roundtrip, lifeboats rigged up
Build log 7 to follow....
Nils
SS Bohuslän 1914 by Mirabell61 - FINISHED - Billing Boats - scale 1:50 - Swedish museum steamer
Thank you Nigel,
for you nice and appreciative words
I will now concentrate on my Pegasus again...
Nils
