Mirabell61
Posts posted by Mirabell61
  1. Setting the tiller for steering either for Manual direct, or for steering with tackle rope and wheel. In raw shaped condition, Needs to be fine tuned...
    here the tiller parts
    tiller mounted to the Fitting socket
    tiller upwards curve for Manual steering
    or in downwards mode for rope steering (via blocks and wheel)
    Nils
  2. Build log part 34
    concentrating on the Quarterdeck
    the deckbeams arecready to take on the deck
    the uncolored figure is 25 mm hight...
    the painted figure is 28mm hight
    the cutaway of the Quarterdeck allows sight to the inside
    gratings, capstan, Skylight housing and deckframe for ladder added
    Build log part 35 to follow...
    Nils
  3. Hi Nils, according to the ffm the capstan bars were 8' long = 38mm at scale, and when in use gratings would cover the hatchways. I think the Quarterdeck ladder would be removed when the capstan was in operation, I doubt there was room to swing it up beneath the deck beams.
    B.E.
    Thank you B.E.
    for your explain on ladder a capstan. I was a Little bit between the Options of putting on the Quarterdeck ladder, or Fitting the gundeck capstan spars, so theat These could be visible through the Quarterdeck outcuts from above.
    Nils
  4. Who knows ?
    here rises the question...
    the downleading stairway (not shown here yet) from the Quarterdeck will be landing between capstan and the next downward starcase, interferes full with the gundeck capstan, if it should be operated with 360 ° turn.
    does the Quarterdeck stair have to be fitted moveable with hinges, for instance to be hauled up against the Quarterdeck from beneath, to allow full capstan operation ?
    Nils
    The downward stairs from the Quarterdeck interferes full with the capstan Operation....
  5. Thank you B.E.
    I`m hesitating for putting on the quarter deck and the forcastle deck because the guns underneath, as well as the anchor rigging would have to be installed permanently before. I think I`ll do the anchor- messenger rigging next, when I get the appropriate ordered ropes. Also the upper bulwark portions of the welldeck and the swivel gunposts Need some attention
    Nils
  6. Thank you very much Jason,
    I like your comments and thanks for following this build. I have`nt looked into the Amati plan for some time now, because I get so much Inspiration from builds of other members, and then there are so many ideas I would like to intigrate and that are not shown on the plan. I wish you much pleausure with your own HMS Snake model, it is a fine built vessel
    Nils
  7. Having just logged the 500th hour in the build log, it's time for a small update.
    A portion of the photoetched parts for the outer hull have been added.  The first photo shows them blackened and ready to deploy:
    For the blackening, I use the process described throughout MSW.  Specifically, the trimmed parts are degreased by bathing in acetone for about 10 minutes followed by an 'etching' in a household vinegar bath for about the same time.  They are then soaked in a bath of 50% 'Blacken-it' for 5-15 minutes, rinsed thoroughly then dried.  Before gluing (using either CA or epoxy), the surface to be glued is roughened with a 150 grit sanding block.  After the part is applied to the ship, a coat of Testors Flat Acrylic lacquer is applied.  This protects the coating and (I think) gives a nice appearance.
    Stern gun port hinges and rings, keel fastener:
    Bilge port and sweep port hinges:
    Bridle port and forward keel fastener:
    Finally, just an overview of where she stands:
    It is now time to bid a fond farewell to the outer hull for the time being.  There is still much to be done but we will now turn our attention to the innermost details of the ship.  But first, a short break in the shipyard to acknowledge the arrival of good weather, tend to the garden and (long delayed) Spring cleaning.
    Everyone stay the course and be well!
    Looking fine Augie,
    very nicely built, natural Wood Colors, in contrast to the metal Fittings, accurate clean planking,
    in all very well done !
    Nils
