Mirabell61
Everything posted by Mirabell61
  1. Many thanks Druxey, I`m following a certain pattern of sequences but now and then there are some slight necessary changes depending on how the progress works out, as this is completely a scratch build Nils
  2. Dear fellow builders, I`m pleased to find all this nice response with my Ergenstrasse introduction, and shall be posting the first available pics of the log herewith....... Gary the Kaiser Wilhelm der Grosse was my most detailed model to date, I`m pleased that you liked it Mark thanks for looking in and further enjoy the build Paul I`m very pleased you like it Roger thanks very much for your kind and interesting to read input on this behalf Andy Yes, I remember it was a waterline-model kit from the webs homepage of Sylvan models. The pic in my introduction was just to give an idea what a Laker steamer would look like Nils dimensions / data hull, frameplan and lines taken from wooden Ferris design steamer (Emergancy Fleet) frames adopted to transparent paper glued onto 3 layer birch plywood frame set up on the base building board a lot of jigsaw work..... the raw cut tiles for better handling the hull shape is coming on with every frame, the edge outcuts are for placing the stringers here to be seen, the square bar "backbone" of the hull. This will also take up the mounting spindles for the stand pedetals an additional keel bar is placed underneath the square bar next in progress will be the mounting of the stringers and check of the lines staking
  3. I`ve just kicked off my new project, It`s a tramp Laker Steamship based on an 3 island superstructure and on a real appr. 2150 tonnage freighter built in 1918, now in (H0) scale 1: 87. Who still remembers the Warner Bros movie "The Sea Chase" of 1955 staring John Wayne in the roll of capt. Ehrlich of the ERGENSTRASSE and Lana Turner as an attractive female agent as the only passenger. I investigated and found out that the Laker ship "Corsicana" aka "Margaret Shafer" had been engaged for the movie in 1955, hereby renamed to ERGENSTRASSE. For my model I used the Corsicana`s data for the Ergenstrasse rating and for hull, frameplan and general shapes those of a wooden Ferris-Ship of the American emergency fleet, being round about the length, width and depth an tonnage of the Laker Corsicana . The movie ship was fitted with the following changes compared to the Corsicana : - Masts changed from four to two, these placed in the forward and aft welldeck areas - Outer bridge ends fitted with wing cabs My model will be performed completely from scratch and in the same way as my previous models and bearing a rivited metal plating skin Data for model ERGENSTRASSE scale 1:87 (H0) Length 87 cm width 15 cm depth 7 cm I decided to fit 23 plywood frames, and to provide stringers and pine plank strips beneath the metal plating The model will set up on 2 brass pedestals and wooden stand baseplate Nils This is the Corsicana, built 1918 This is the steamship ERGENSTRASSE aka Corsicana aka margaret Schafer Captain Ehrlich aka John Wayne This is a pic from the web representing a laker steam freighter, not my model
  4. A beautiful Model Daniel, congrats, well done Nils
  5. congratulations to the excellent scratch-build completion of your ship Svein Erik, I like the rivet plating giving that special nostalgik appeal, well done !! Nils
  6. Thank you Stephane, for your words, I have a great problem in finding additional display space in my home. For instance the #5 Elbe schooner will have no own case, and will have to share the case of the Zeesboot from time to time, as both models (one at a time) can fit in it. As this is an English speaking forum, please would it be possible for you to correspond in english rather that in French language, so that other members can also follow, thank you regards Nils
  7. Hi Rob, I used 4 mm thick glass panes for all my 9 display cases to date. It is a bit tricky in preventing the panes to tilt during assembly, before the frame can secure, but meantime I gained some experience in handling that quite well. The handicap is that the glass cases are rather heavy, and I finaly need two helping hands from my wife to put and lower down the glass bonnet over the model and on to the case base-plate. Nils
  8. Peter, many thanks for kind words, much appriciated. I was looking for how to issue an album all the time and finaly solved it. So not only the #5 Elbe Pilot Schoner but also the Zeesboot got their own album. I hope that I do`nt forget again how I did it Nils
  9. Gary, thank you for your kind words, much appreciated, and I´m very pleased that you like the boat.... Nils
  10. Many thanks Keith, it is already displayed in my little private museum together with 8 other models... The Gorch Fock model had (in lack of place) to be moved upstairs to my attic office Nils
  11. The casing the casing is now finished the model set inside and this closes the build log Nils
  12. thank you for following the build Johann, I`m pleased you like it. The case for the model is nearly finished
  13. Here some pics of the case building progress.... As my recent 5 Elbe provides nearly the same length and height as the Zeesboot, this case will alternatively suit both models well Nils Glass panes ready for being fitted all corners will be reinforced with brass fittings the bottom frame corners are fitted with ply corners the mid frame gets supports as well. The brass pins fit into all six sleeve sockets to seccure for no movement of the bonnet Zeesboot trial fit standing on the base also the 5 Elbe model will fit into the case this is what the case is actualy made for
  14. Many thanks Keith, I`ve just started to make the glass casing..... Nils it satrts with the base plate and the sides profile the glasser did a good job, the cuts are very precise and the edges well debured the last side to be fitted I saw this little side table offered by Aldi this week. The glass case will stand on it later on
