Posts posted by Mirabell61
Paul,
thanks for sharing your soldering excellent tutorial
Nils
Danny
I`m absolutely with Adam...
As you probably recognized, I`m taking a Little pause on my own P.Sue build, but seeing your fabulous work in process really encourages me....to get further going on it again
Nils
Hi S. Coleman, Tom and Daniel,
thank you for your appreciative words, I`m preparing to post Log parts 9 + 10 tomorrow morning, stay tuned
Nils
Michiel
your build is a delight to follow, I had an eye on the "Prins Willem" plan before I decided to go for the Pegasus.
Neat and tidy build, as well as splendid Quality, and handcraftship, shall follow this one further on
Nils
Build log part 8
template topview for boatdeck
checking Position of midship stairs down to Forward working deck
deckhouse stairs to boatstations
aftstair from boatdeck to working poopdeck
view backwards at this building stage
wooden planking of boatsdeck, here also the bearing Support-sleeves for taking up the Davits already mounted
main wheelhouse, Navigation room and officers duty station
freshwater storage tank with vent on top
Build log part 9 to follow....
- The Sailor, Elia, Captain Slog and 8 others
11
well done Bob !
beautiful work, a pleasure to look at
Nils
Build log part 7
ship is now tugged out alongside the Fitting out quay of the yard
etched brass stairs
check, fit to scale approved OK
brass rim fitted to lower deckhousing, all around the boatsdeck
self explaining
in opposite to the workdecks the forecastle deck is Wood planked
the soldering Task gets a Little tricky here (too much heat in one place loostens the already tight neighbour ones again)
checking with plan, space requirements for boats, Davits and boat Access platforms
cardboard template for complete boat deck base
stanchions for upper Bridge fixed and soldered
note the workdecks are painted tan, "earthbrown"
self explaining...
Build log part 8 to follow....
Build log part 6
hold rim with removable hatchcovers
raw Forward mast
crows nest, the Access ladder from deck not fixed yet
take up Points for swivel loadbeams
after some paint touchups ...
plymsol marking at waterline
marking of Name and Registration port
These 3 pics..., quite pleased with the results so far
Build log part 7 to follow
- Elia, EricWilliamMarshall, druxey and 9 others
12
Nils, I assume you made the rivet wheel (picture 2), can you tell us more about it? OOPS I found it!, Thanks
I also like the aluminum tape use for the riveted metal plates, Great start!
Hi Guy,
the toothwheel Comes from an old mantelclock-clockwork, obtained from a fleamarket, and so providing many individual brass toothwheels with different toothsizes.
thin wheels for single row riveting broader ones for Multi row riveting, etc...
From twinrow on upwards the toothbreadth would Need to be reduced by binging circular groves in like the Picture Shows. Provided you own a Hobby lathe and appropriate cutting chissels, no Problem..., if not, span the wheel on a Center fixed screw
span into your Drilling machine and tangentially (sturdy Hand!!) bring cutting side tooth-direction of your metalblade small handsaw into Operation, with running Drilling machine. Some Trials should be done with scrap- wheels before, to get the Feeling. The saw toothdirection must be in the "pushing mode" as if it were a chissel. Remove grit care fully and brush over with brass-brush, to slight break the sharp edges carefully.
Hope this is of help...
Cheers
Nils
Thank
Thank you so much for going to the trouble of making this log and sharing your incredible skills, this wonderful model, but most importantly bringing to life the history of the very real people and the ship itself!
For all of these reasons I can't wait to see the rest
Thank you Bindy for you nice words
It all was due to the nowdays possibilities via web for doing all this Research, for instance in gathering all available to myself historic US newspaper clippings, state archives, etc...
Nils
Hi Creackers,
this I have also asked myself many times, but it is also fact that from radiocalls received, the stearing rudderchain had broken in a full gale, making the vessel unmanouverable and probably immediately going square to the huge waves the hull rolling heavily, and fact is that the hatchcovers had been destroyed, this causing the uncontrolled take of water, until the ships superstructures could not withstand the stresses anymore. She may have sunk or suddely have broken through. We shall never really know what hapened in the last minutes
Nils
Richard
thanks for your word. Regarding to the plan I received it upon Special request from the birth shipyard (which does not actually sell plans of their builds), but I told about my personal relation to the ship because of a Research of the fate of itt foundering and the fate of my grandfather.
Nils
Bob,
thank you, I`m glad you like it
there is more to come soon
Nils
Build log part 5
for making the stand Posts I use brass candle holders (found on flee-markets)
the anchorchain port reinforcements are fitted
begin... rivited structure to deckhouses and hatch rims
further Fitting out
midship deckhouses, on deck inbetween the coal bunker hatchcovers
forecastle compartments
so far well under way...
workdecks ready for priming, painting
the figures are scale 1:100
the portside depth indications are in Roman figures
Build log part 6 to follow....
- avsjerome2003, dgbot, gieb8688 and 14 others
17
Build log part 4
characteristic for These old steamships are the large vents, necessary more than ever when going through hot,tropical zones of calm sea...
Here is to give my Version of the vent Hood making..., and the main masts, and crows nest
sizes and types of vents
an Arrangement of inlet and outlet vents
prefit check with the decks
application of primer after soldering and cleaning the brass surfaces
was quite a bunch of individual parts
inner Hood surfaces have their own color
as well as the outside surfaces
Forward and aft mast
do not throw away your old dome-nuts, they serve for exellent venthoods
especially those where the dome Shell is made and brased on of thin pressed sheet
Build log part 5 to follow.....
Hello Nils,
I am really overwhelmed by your build... This is modelling on its top-level. I will follow your log and I am very very curious to see the progress.
Good luck and a lot of fun
Max aus Hof in Oberfranken
Hello Max,
what a cute member Icon you have, gives me a smile on monday morning. Thanks for your words, and enjoy the further parts of the Heinrich Kayser build log
Nils
Building log part 3
brought on White primer coating and Sub waterline red
the last Picture where the hull is still fixed to the baseplate. The upper hull portions shall be plated and painted when the decks have been permanently mounted
hull seperated from baseplate, all went well, no Twist, no destortions
extreme lightweight hull, prop- and ruddershaft already mounted, superstructure for deck Support can be seen
riged structure in forecastle area
decks made from 1,5 mm thick 4-layer Aeroplywood
the Forward maindeck, 3 hatches, and the quite Long poopdeck, 2 hatches,(working decks) are going to be metal plated. These decks were of steel plating due to rough cargo handlingand overcoming heavy seas. The cardboard template behind hatch #4 Shows the riviting pattern for deck plating
hatch # 1 behind the forecastle bulkhead
bow section before finalizing the decks and the final plating
raw workdecks mounted, midship deckhouses started, hull painting done and forecastle bulleyes mounted. It`s now slowly looking like a ship should be...
Build log part 4 to follow.....
- LEFEBVRE, harvey1847, archjofo and 14 others
17
The anchors are made of brass.
to be continued ...
Congrats Johann,
you have delivered first class work in admirable Performance and Quality, also the photos are great, in all a delight to see
Nils
Well, I was hoping to see this section. Great work on metal plates Nils.
I'm curious about the tool that you used for marking plates. Can you show us ?
Thanks, Bugra.
Bugra,
upon your request, here a short intercourse and self explaining use of the plate marking tool.
By the way, I use this method on all model hulls that are of rivited structure, only the tooth modul sizes differ acc. to the appr. scale Chosen. The holders for the toothwheels are made from old paintbrushes that would go to the bin otherwise.
Cheers
Nils
different wheel (toothsizes, and toothnumbers, also requires a semi soft rubber plate underneath and of course the precut plate
(turn around the plate, so the protection foil is up....
use a metal ruler, or like here a masons tool, leave plate edge free
the roller tool, use Dremel with circle sawblade to cut in the two circular grooves for obtaining 3 toothrows instead of one
press tight down the roller tool and move swiftly Forward in one move. Same time press down the ruler
looking at the marked edge from the rear side
looking at the result of the rivit resembling, (here 3-row riviting)
remove the protection foil, Keep the gluefilm side free from dust and debris
Happy exercising and good success
Nils
- Lou van Wijhe, cog, Captain Slog and 8 others
11
Very nice mate real nice.
:D
Thank you rpeteru
Nils
Build log part 2
planking completed, rudder and sternpost reinforcement mounted, minimized Polyesterfiller where necassary, and poopquarter knee-whale attached
impressions of rudder making components
the five blade prop is only an interim solution, a four blade historic prop with blades bolted-on the central hub is to follow later
here first time experience Begins with metal plating for hull
The hull wooden surface is sanded smooth and fixed with quick dying transperant liquid filler, which drys off quickly leaving a real smooth and shiny surface on which the self-adhesive Aluminium foil sticks like hell. No Problem with roll-embossing the foil plates from the rear plate side, because the rivit immitations are roolled-in before the protection foil on the plate rearside is removed, giving free the glue film.
Workstation for making the plates
leave a gap between first and second plating line, the third plating line is set by overlapping the edges of first and second line
Note : vertical rivit Joints have 4 rows of rivits, horizontal Joints have 2 rivit rows
plating nearly done, the whole hull is still mounted to the shipyard baseplate
Mounted into the keel are two reinforced M5 female threads for the later to be mounted stand-bolts
the upper hull portions have not been plated yet
soldered, full functional mounted rudder before plating, shaft going through to poop deck
here the upside down 135 cm Long hull is nearly ready for seperating from the baseplate, it is very stiff, riged and of lightweight
Thanks for the build log Nils. I'm really surprised about the sails on the plan...
Thanks for looking in Richard,
the sails were quite common to the steamships builds around the turn of the century, ( remember the plan Shows the 1898 Version),you can see this on many oilpaintings of that time. They had been removed on most Steamers as the engines became more reliable.
Nils
Nils,
Thanks for sharing build log with us. You did great, she's great and looks powerful. Already viewed final but this is the behind the scene of 1800 hours of work
Bugra.
Hi Bugra
Thank you for looking in, and I`m glad you like this old Steamer
Nils
Heinrich Kayser 1898 by Nils Langemann - FINISHED - scale 1:96 - as she appeared in 1922
Crackers,
that idea is not completely out of this world, because I`m running out of space in my Hobby Office right now, I am 66 years old and I hope that they might find an honorable anchoring place in my childrens homes one day. Right now I have 2 steamships, two Tallships, and the uncompleted scratchbuilt 18th century Pegasus in Progress.
Besides that you might know or have experienced yourself, that the modelers fingers start itching when one gets mind-pregnant with the next "Project", at least the ideas Keep on sparkling...
It is since I had retired from my work that I again have time to go after this Hobby.
Cheers
Nils
