Mirabell61
Everything posted by Mirabell61
  1. Hi Rob, the davits will be those old fashioned "lantern masts" swing out davits, if you wish, pls. refer to the pics in my post #1325 on page 45.... For the clinker-appeal boats I really have`nt made the final decision yet, but I am "going pregnant" with the cast resin methode, preferably by making each boat in two halves from moulds and plugs, including the seating interior, and alternatively closed boats with canvas cover. Because the boats are only 60 mm long, it neads some special treatment. I`ll look into that when the bridge work is completed Nils
  2. Update : starting with the bridge front, with card templates for making the brass pannels, all the braces and supports are on and the bridge-plattform is in place Nils
  3. I very much like that base plate B.E. choosing oak give a nice warm tone, am now looking forward to your casing..... Nils
  4. Bob and Greg, thanks for your nice words, and as already mentioned earlier, there are cabins booked for my freinds at MSW for the maidenvoyage... Now its not so far more to go... Nils
  5. little update : made and attached two deck lights (one one the midships plattform, one under the bridge deck) and made braces for supporting the bridge wing cabs from underneath..... Nils did`nt apply filler here yet in the background, the plastic foil that covers the model when not working on it
  6. Keith, excellent work, your fittings, that schooner deck has a real classic appeal, well done .... Nils
  7. Wow !! Kees, wunderbare Arbeit, it looks like the real thing after an overhaul in the dock... Nils
  8. Hi Greg, the braces worked out fine, it was a bit tricky to get the fastening pins align to the small holes in the lower bridge, so that all of the braces find their correct place.... Nils the pins on the upper side will be cut flush with the deck surface before planking this.... priming and painting from the underside
  9. nice progress Dan, the propshaft arrangement looks nice, quite a task at that small scale, well done ! nils
  10. Thank you very much Pete and Michael, for your words... Pete, glad you looked in and like the build, you`re always wellcome... Michael, Thanks for your put in here... I`m not familiar with the term "drape", but think you probably mean thermo-forming over a wooden mould or so.... I have`nt thought it through completely, but there are several alternative ways of production. What I`ll probably go for at first trial is to resin cast a left and a right half into a mould (horizontal and laying on its side), made from a suitable material and two different detailed wooden plugs that can be hung into the mould from above. This way I can produce either boat-halves closed with canvas, or open boats with view to interior fitting out. Each boat half shall require post and individual treatment. Nils
  11. Hi Bob, great progress on the aft deck house.... Nils
  12. Update : starting with the upper bridge. Made new stairs for replacement with 135 ° angle in the railing. There will be several Y- shaped supports from the upper to the lower bridge...., made one as prototype in brass to see if it works... Nils these tiny buggers (stairs, supports) are quite tricky for soldering but look nice, when done... the supports have to be integrated when the upper bridge is mounted, Here an example pic from a nice built card model I found on the web
