HardeeHarHar
Everything posted by HardeeHarHar
  1. Long term Durham resident with increasing time spent at our place on Roanoke Island.
  2. Welcome aboard Papa, Looking forward to watching your build. We might be neighbors, as I am in NC as well. Cheers! Brian
  3. Welcome on board, and good luck with the RC job. It looks like FUN and a CHALLENGE, which will be interesting for all of us. Please make a build log and keep us all up to date on your voyage!
  4. Andrew, glad that you found the forum and welcome aboard. Hopefully you will find the crew and contents increasingly helpful and enjoyable over time. Thanks for sharing the history of your interest in model ships, and I am looking forward to seeing pictures of your Albatross. Please do consider starting a build log to document your work!
  5. Gday Alex, glad to have another OZie on board! Sydney is a beautiful place.
  6. A very wise man (Ron @hollowneck) once taught me that if you throw all the receipts away, this hobby is not expensive at all!
  7. Are you using nails only when you need them? Also, did you leave all the char on and remove it once the keel and its parts were complete? I have the Sphinx on my table and am watching your build with great interest 😃
  8. Our latest (2nd) addition in framed artwork using images from @Ab Hoving and Son. It is an image of a pinas, the standard ship of the Dutch merchant fleet in the 17th century, and is cropped from the image entitled "A Ship Off the Coast". The pinas was the standard ship of the Dutch merchant fleet in the 17th century, and the plate is inspired by a painting by Willem van de Velde the Younger. I apologize that there is a reflection of a light fixture in the image, I will take better pictures as time permits, but I think it looks pretty nice and will look great hanging on the wall across from our other masterpiece from Ab and Son.
  9. Interesting approach! Just wondering: how did you attach your jig to the side of the ship? Awesome build log, I will have to go read from start to finish 😃
  10. Welcome to Model Ship World Al, the virtual motherlode of knowledge and guidance with respect to ship models. That is one interesting project you have on hand. It sounds like some reference material is available for you to mine for information. Please start a build log if you endeavor to proceed with the restoration so we can learn more about the history of this interesting vessel. Best regards!
  11. It’s more to stop breaking bits in the wood when doing it by hand. My Dremel starts at a high speed at first and wobbles to much to be of much use…
  12. I was considering using it to drill holes for sweep port lids, channels, maybe chainplates but there isn’t sufficient X-Y movement I guess…. I could probably use it for the sweep port hinges.
  13. I was wondering if that was an option on the Proxxon.
  14. Words of wisdom there @VTHokiEE. Thanks again!!! 😀
  15. Thanks to everyone for the advice and comments!! I *REALLY* appreciate all the sage input I have received. I originally purchased my pin vise and drill bits from Amazon (see link below). They say the PCB bits are tungstun carbide, which might explain the high failure rate leaving the bit embedded in the wood and resulting in shooting pain in temples and emission of random swear words. I must note that the pinvise holds the broken end quite securely. I will listen to the suggestion of @VTHokiEE and try the McMaster-Carr bits. I just put in an order for a range of bit sizes, with several of each side just in case. Fingers crossed these uncoated HSS do the trick, I have so many holes to drill. One other note, I will also likely buy the drill press, but it does seem like there is not sufficient room provided on the Proxxon drill press to slide the hull of the Granado into place. What do all you kind people think? Am I correct in this conclusion? Thanks again for all the assistance! https://www.amazon.com/Pieces-Polymer-Jewelry-0-1-1mm-Random/dp/B084T4PB1K/ref=sr_1_2_sspa?crid=2FSKVBXUIOUQO&keywords=micro+drill+bits&qid=1677160965&sprefix=micro+drill+bits%2Caps%2C101&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRlZPQzZOWkpGSlFRJmVuY3J5cHRlZElkPUEwOTMyOTg5MUdZQlRGWjNGWVVQUyZlbmNyeXB0ZWRBZElkPUEwNTk4NzM2MUlDU1Y0VDhCUkJFTCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
  16. Hey Gang, Sorry to shout out "HELP!", but I am going through micro drill bits at an alarming pace, and when they break in the wood, it is often a minor disaster. I have questioned whether there are just a lot of cheap drill bits out there, and that I have inadvertently purchased poor quality bits. I haven't really shopped around, and I don't know that much about what makes a high quality, durable drill bit. However, I just was looking on Amazon at 0.5 mm drill bits, and saw that GUHRING sells some kind of special 0.5 mm drill bits at a cost of $305/ for a pack of 10 ( https://www.amazon.com/GUHRING-9006600005000-Precision-Reinforced-Diameter/dp/B0102UZVUQ ). That made me think perhaps that these bits are somehow better than the ones I have been using, but spending $300 dollars on a pack of 10 0.5 mm bits seems a wee bit excessive. So, here are some specific questions: 1) How are most people making lots of 0.5 mm holes? 2) What drill bit manufacturers sell quality bits? 3) Is a drill press the solution, and if so, isn't the Proxxon drill press to limited in space to be able to slide a ship into place? It says the column is only 11 inches long! 4) Am i breaking a lot of bits because I am using a pin-vise by hand, and should I try an electric cordless drill like a dremel. I already have a dremel, but when you turn it on, it starts at a medium speed which makes it an engraver, and not a drill (if you know what I mean). It also has a lot of wobble/precision that makes it fairly hard to use. 5. What in your expert opinion is the best solution for my drilling needs, as I need to drill holes for channels and chain plates in my boxwood framed, and danish oil finished, hull of the Granado? Any assistance would be greatly appreciated, and would save me a lot of frustration and swearing. If I could pay you for consultation services I would consider it. Best regards, Brian
  17. I’ve been listening to the series, almost done with the fourth book, The Mauritius Command. Really enjoying them all.
  18. Rail and stern looks great!! Nice work. I see you put the lids on your sweep ports too!
  19. Did you elect not to mount all the swivel guns. I just noticed some appear to be missing…I need to do those too, so I think I’ll be doing some of that work today….
  20. Hey Kev et al., I made an executive decision, and I am going to delay installation of sweep port lids until I have finished everything else. I made one sweep port lid to the best of my ability, and it came out perfectly fine (see below) But drilling 36 0.5mm holes in the side to firmly install them is toooooo much and tooooo many holes in my opinion. I don’t have a drill press (yet), and the Dremel wobbles, etc. I will hand drill 0.7 mm holes for the pins on the channels and see how that goes, because I HAVE TO DO THAT. But I like the look of the open sweep ports, so when all is done, I will simply glue the sweep port lids in the open position, without drilling any holes, and handle with extreme care. Or not attach them. I don’t want to close all those sweep ports I so carefully cut out of the boxwood hull planking. Had I thought of it when I was cutting them out, I would have drilled the holes then, before doing all the installation of deck pumps, quarterdeck rails, cannons, etc. For perspective: hinge side Eye bolt on other side… And a picture or two of the Secret Vessel in its berth on Roanoke Island.
