Everything posted by DonSangria
You can mark the waterline without a special waterline marker. Just fix the pencil on the rigth hight for example on a box or sanding block...
- 26 replies
- Solid hull
- Bregante
Maybe you could paint over the (sanded) red and give the cabin a color? Something white/gray/blue, as Blue Ensign did on his Indy?
- 422 replies
- Vanguard Models
- Sphinx
I know what you mean, but I don't know the answer. I think it depends on the relative positions of the block to the rail. Maybe also just the preference of the crew or the officers in charge? I would go with the left version of your drawing.
Who uses nails?
DonSangria replied to bigcreekdad's topic in Building, Framing, Planking and plating a ships hull and deck
I used temporary nails to hold the planks of the first layer of planking. After the glue dried, i removed the nails. The resulting hole is afterwards covered by the second planking. For me it was a good solution and easy to acomplish. -
Question about Symbol on building mast
DonSangria replied to ChuckP's topic in Masting, rigging and sails
I think the letters refer to another view of the mast. Figute A should be a depiction of the mast vrom the front and figure B the view of the mast on the indicated hight form above. -
I hope we will! And it will make us happy from what I see so far 😃 Great work, enjoying to watch the rigging process!
- 443 replies
- Indefatigable
- Vanguard Models
Maybe you can slide the topmast through the hole from below?
- 426 replies
- Vanguard Models
- Sphinx
I think whitout a sail, the tack and sheets would not be rigged. Maybe this helps:
I think i varnished the hull at the step where you are now without any problems later on. Your build looks really nice so far! :)
Yes, the hammocks... I don't like them in this kit. Since it is my first build, I realized too late, that these should depict hammocks. For me it was just a decoration of the bulwarks. It is too late to change, since I'm in the process of rigging.
The Kit shows the Ship after the 1831 refit for Darwins voyage. In 1820 she was launched 2-masted and later refitted with a third mast.
