BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. I can only reiterate earlier comments that hopefully your run of bad luck is well and truly behind you. It is a testament to your attitude to life that all of this has not brought you down and that you maintain a positive outlook. Good luck with the article. cheers Pat
  2. Great to see the use of modern technologies in improving our hobby Ian. Looking very good. cheers Pat
  3. Very nice work Steven, that very much looks like salt water bleached wood. cheers Pat
  4. She's looking good Keith; and looking forward to seeing the corrections/improvements. cheers Pat
  5. Hi Keith. It maybe one of those 'colour shifting' paints, depending on the ambient light and viewing aspect? I know there are several model paint suppliers such as SMS, now providing these. You sometimes have to put down a series of coats to get the right effect. A chap that goes by an avatar of "Barbados Rex' on you tube has rune some extensive tests of these paints for several suppliers. May be worth investigating? cheers Pat
  6. The model is looking good Ian, some great progress. You need a Roman Centurian guard? They must be pretty good clamps BTW that figurine looks great. cheers Pat
  7. The joys and adventures of experimentation Glad things worked out Glen, that is a great base for your waterfall. cheers Pat
  8. Congratulations Vladimir. I have very much enjoyed following your build, especially watching you overcome the hurdles you met along the way. That is a very nicely detailed, cleanly finished model. You should be proud of your efforts on this one. cheers Pat
  9. Oh you are so naughty (or should I say mischievous) Keith cheers Pat
  10. Nice work Kieth, she is already showing her wonderful lines. That tab system looks a great way to maintain alignment of the frames. I have used such as system on solid bulkheads, but this takes it up several notches. cheers Pat
  11. That is an interesting detail. They would also provide the additional advantage as working as small anti-roll hull strakes, thus helping to stabilise the vessel. BTW, nice work on your hull, looks good even before your final sanding. cheers Pat
  12. Great to hear the quarantine period is ending and to see the progress Keith. cheers Pat
  13. Great to see the update Keith, take as long as you like mate. Merry Christmas to you and your family Pat
  14. Your model is looking great Ian; and if I may use a superlative in the most sincere way 'outstanding'. Have a great Christmas and looking forward to her progress in the new year. cheers Pat
  15. This will make another fine display Greg; looking forward to seeing it. Happy Christmas Pat
  16. Hi HOF, great to find another member of the Endeavour club - and many thanks for the accolades, I hope my build lives up to your expectations. It looks like you have a very nicely faired hull, and the deck planking looks great. Looking forward to seeing her come along. Just holler across the ditch if you have any questions mate, I still have many of the photos I posted so just let me know if you need any, or need any clarifications on why I did anything, especially the rigging. cheers Pat
  17. Good luck Greg, that will be a difficult pattern to mimic. Certainly looks effective. Merry Christmas Pat
  18. Easy for you to say Glen, me thinks this is more experience and good skills coming to the fore. You will really have to look outside-the-box to find a real challenge for your next hull build ... and BTW, the craft looks great in its setting - very nice work indeed. cheers Pat
  19. Hi all, the method I use is based on the 'square' idea but utilises a jig. I make the jig as a triangle with a flat base that sits on the deck. I then cut the leading edge to the correct angle have set that up with a protractor; the angle (or straightness of the trailing edge does not matter. I glue/tack a small slat on either side of the leading edge forming a channel within which the mast sits - but I also do not glue the mast in. This cradle of sorts holds the mast in the correct alignment while I place the major standing rigging that stabilises the mast. The jig is as thick, or slightly thicker, as the mast itself. I usually make this from scrap wood (preferable something stable such as MDF) but it does not have to be very large; typically, a base of 2-3", and about 4-6" high I find is more than enough, and it remains small enough to extract it though the gaps in the rigging - note that I have usually fitted the upper masts off the model before this. I tack-glue a bit of scrap material (usually plastic) to the base that has been shaped to conform with the side of the inside of the bulwarks, or other fittings keep the whole assembly centred on the centre-line and aligned correctly. This done of thin material and tacked only so that it can easily be removed/separated from the jig for its removal. I hope this all makes sense? I then level the model in my building base (if not done earlier) by placing small bubble levels on the deck and adjust as required. Once level, I secure the hull in the building base. This method allows me to have the mast at the correct rake and also minimizing the chances of it being moved too far to port or stbd. Just an idea for an alternate solution.
