BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Glen, my best wishes to your friend for a fast and full recovery. cheers Pat
  2. Wow, you are certainly not shy of undertaking a complex project Glen; good luck mate. I look forward to following this one also. cheers Pat
  3. Quick work Rob but looking really good. I don't envy you doing the bow mods, that will test your skills/patience. cheers Pat
  4. Hi Steven, the club built a model of Cerberus which is in the HMAS Castlemaine Museum now; I think this was as delivered. I have a few images and I am sure you are aware of the 'Save the Cerberus' web page which has a wealth of info? Looking forward to seeing your build. cheers Pat
  5. Great progress and looking good Rob; up to your usual very high standards. Kudos for working around the rigging, you really like a challenge don't you cheers Pat
  6. Ditto Steven - how did I miss this. A very interesting subject to model, and very well executed. cheers Pat
  7. Some interesting conundrums you are dealing with here Rob, I follow with interest. cheers Pat
  8. Perhaps also worth considering this design for 'rocking' the vessel of sandbars or the mud in ports? (Many ships in shallow ports sat on the mud when the tide went out.) By shifting weight/cargo fore or aft would perhaps raise the keel sufficiently to get her off? But, I think this would have been an addition or complimentary outcome, rather than a design feature? cheers Pat
  9. That's a ripper find Keith. Thanks for sharing these photos which proved a great insight as to how these lamps were made and assembled. cheers Pat
  10. This is one very nice model Eberhard, especially at the scale you are working. Kudos! cheers Pat
  11. A very different subject for your next effort Greg; did all that rust attract you I have seen some info that suggested both guns may be removed to make-way for the installation of four 87-inch missile launcher modules, carrying up to 12 missiles. Which version are you building? cheers Pat
  12. Some great research and discussion here - following with interest. Thanks guys. cheers Pat
  13. Interesting videos and info; thanks Isaiah. cheers Pat
  14. It may be slow (but not as slow as my build ) but it is worth waiting for Vlad. Looks great! cheers Pat
  15. You have certainly mastered the art of planking Chuck; such clean, crisp joints and edges - a delight to see. cheers Pat
  16. Can't wait to see the planking going on this beauty; nice work Ian. cheers Pat
  17. You don't muck around once you commit do you Rob? Nice clean removal. cheers Pat
  18. Hi Rick, I am sorry that I have not looked into your build before this - my loss as you are producing a very nice model. I have had a quick look through but will go back and read-in more carefully. Quite the task you have set yourself for a first model. That said, you appear to be well and truly up to the challenge. If you had not mentioned your issues with hull symmetry I would have never known, it looks fine in most photographs. I too like your shackles, they are very effective especially at scale 1/96. The deck furniture is coming along very well and looks great. For someone who claims they are not very good at joinery, you seem to be doing a very creditable job of it. You asked about sealing your deck? Once I have completed my deck planking, I mask/tape off the known deck furniture areas (outer boundary to allow glue to take) and give it as coat of Testors 'Dull Cote' which is a flat/matt varnish. I find this helps to protect the deck planking (especially as they are much lighter coloured planks), and should I accidently mark the planks doing other work, I can simply give it a light scrape to remove the marking and recoat the area. I use small scrapers made from old scalpel or similar blades for this. Being matt finish small touch-pups do not show. I am very much looking forward to your further updates. cheers Pat
  19. This will be interesting; I will be interested to see how you go about this Rob. cheers Pat
  20. That great that Mike and his daughter were able to come and personally view your excellent work Rob; I'll bet they were as thrilled as you. cheers Pat
  21. Thanks Steve, much appreciated. cheers Pat
