Everything posted by rookie
Interesting topic. I remember reading the Hornblower books as a kid. they were an entertaining romp. I do have the A-M series and read the whole thing every couple of years. Patrick O'Brian was an extremely well educated person and that is apparent in the books with things that go over my head. However, I find the dialogue and the funny asides of Maturin which shows what he really thinks of a situation give me a chuckle. My wife will say 'are you reading those again? I thought so since it is the only time you laugh when you are reading.' (that actually is not true , I do laugh sometimes at other books - Outlander for example)
74-Gun Ship Gun Deck by Jeronimo - FINISHED
rookie replied to Jeronimo's topic in - Build logs for subjects built 1801 - 1850
exceptional work love the details with nails and bolts -
Exquisite work! I really like the base
- 1,784 replies
- winchelsea
- Syren Ship Model Company
thanks Ian I am working on the shelters at the stern and the wheel/tiller the wheel that came with the kit looks like a "Lego" wheel so I am thinking of making one 🤔 Or I may get a wheel kit from Syren ..... Speaking of which I bought the Syren ropewalk and got it but have not assembled it yet Probably do the tiller ropes to practice with it
Wow thanks will your model looks great i have been adding the lash rail , top rail and finishing my fore and main tops also trying to get the anchor hawse and the decorative bits at the bow there Is nothing in the instructions so using photos of shup tryworks is something I have not done yet - I thought about buying scale bricks on Etsy Colin
Well some minor progress to report did build the fore top and maintop seen here in photos dry fit to masts that are sitting in holes in hull next up is to finishh the channels I plan to use a shroud on each mast to determine the chain plate angles and get those set up i am also planning a stand but not sure how I want to do it the keel seems too thin for screws I may just sit it on a cradle
Thanks Wintergreen Speaking of doing my own thing I decided to build the tops rather than use the stamped out parts in kit (plus one of them broke while removing it) I will plank it using the kit piece. As a template In the picture I may cut out thin piece and use .5 mm strips on both sides then cross supports to keep it solid
just saw your copper post. I got my copper tape in mail last week The riveted look is not correct since this is not a 20th century battleship the copper was nailed on with copper nails flush with the surface not rivetted I prefer your subtle approach I may dispense with anything and just have the plates; not sure yet
great work DJC! I also am in a "long build" of Charles Morgan (Artesania Latina) with a decade-long hiatus after assembling the frame I like your deck. I f I could do it again I would not use the AL wood as it is too wide but live and learn And I have posted old photos as a bit of a catch-up also. keep up the good work.
I thought I would make a few comments about the Artesania Latina Morgan model itself As I was going to start planking I found that the stern was way too small compared to the big wide stern on the actual ship. I cut out a slightly larger transom and "padded" the planking on the last one or two frames to build it up a little. I also found the wide piece of wood for the bulwarks problematic to try to bend at t he bow and install. I have a feeling mine is not correct as I ended up not able to add the extra piece below the cap rail as it would have been too high. I had seen the Model Shipways build and I preferred actually building the bulwarks up properly. That model also forces you to build the deck structures whereas the AL model has blocks for hatches and companionways and tryworks. The AL instructions just say to score brick pattern into the block provided. (yikes!) I embellished the hatches etc and have not begun the tryworks yet. Still wondering about actually using tiny bricks to make it. In general, now that I have gone through the planking I have realized the next time there are things I would do differently. I will definitely install the keel first and create a rabbet for the planks rather than sticking the keel on top of first layer. I think I will also try to only do one layer of planks; it is tough enough doing it once without having to shape tiny veneer bits and do it again. I will also follow advice I saw in various places about marking the run of the planks out in sections and shaping each plank accordingly. In mine I tried to calculate the width at each frame and shape it but that does not work when doing the entire side of hull in one "section' Anyway, my Billings Bounty will be better for this experience (fingers crossed)
thanks Ian I have to check on the wood - I discovered the clamps a little while ago that are not painted black so they wont leave the black marks on the wood when contacting the glue I plan to use those from now on I have not noticed the saw wearing out , good question though. is there a small mitre box that is wood? will post more recent pictures shortly
Bought this decades ago and many years ago I assembled the frames left on the shelf and started again a couple years ago i am ar the point where the second planking is down to waterline I plan to copper with tape so I will post some current photos and pictures of the plans as I saw an ask for plan photos
I have artesania Latina Charles Morgan I will likely start build log soon and can post photos of plans there
I have been building this same kit for many years i built the frame and then it sat for decade or more continuing now and have just completed second plank down to the waterline where I will put copper tape likely start a build log soon just joined so need to figure that out
- 6 replies
- charles w morgan
- artesania latina
