AJohnson
Everything posted by AJohnson
  1. Looking great Will, what paints are you using for the anti fouling and green? Like you I like to get all the painting done in one go, or in quick succession, so I can keep on top of the airbrush cleaning. I got some tape from Chris, so I'll be using it on my 'Nisha' hopefully in the not too distant future.
  2. Chris, this looks so good, I still struggle to believe these are made with card, they look that good. Love a Spitfire and extra excited today, just learned (and pre-ordered! 😆) that Airfix are releasing a 1/24 Spitfire Mr.IXc 😍 - yeah that Airfix 1970's Mk.1a mould can finally be retired! 🥳
  3. Brilliant Chris, once my wallet recovers from Christmas I will be getting a set of fishermen and clutter! Any news on the sail sets?
  4. Really neat finish Bug, that cap rail worth the effort I think, finishes it off well. 👍
  5. This batch of pictures brings my log up to date with the planking progress, overall fairly happy with it, with the ever present "wish I had done that better" bits. As mentioned on todays earlier post, I am going to need some primer coats to reveal the way my little modifications have turned out, but there are many obvious flaws in the finish that don't require primer that can be attended to first. Out of interest to those who are following my log, the attached picture of the "Pilgrim" being painted shows the look I am after. The 'bilge' planking is visible, the 'topside' planking less so, the subtle but still visible differences in thickness of planking are what I am aiming to replicate. In fact the paint scheme is pretty much what I have settled on for my build, black sides, anti fouling (but no boot topping in white) only difference is the deck edge band will be in white. As a side note I have replaced parts #39 (Stern frame surround) and #42 (bulwark lower rail patterns) with thin strip from the Pear second planking that I cut to suit. Nothing wrong with the kit parts, just a consequence of going down the route of following the Edgar Marsh plans of a thicker 'topside' planking means bulwark lower rail pattern would not sit flat and as a result the stern frame surround also needed reducing in thickness to match. Next update will be me filling / sanding / priming (repeated x number of times) until I am happy or have pile of sawdust to show for my efforts....
  6. Looking good Andy, glad you got that stern counter on without mishap, think I was guilty of not making sure the clamps were not going to move overnight and think one slipped and dragged my counter sideways, which caused the split in the softened wood. You are making excellent progress and will soon be catching me up! I see from your penultimate picture you are thinking of doing a bit of "kit bashing" with the fitment of an Ejector Seat? 🤣 Assume this is for when the skipper thinks the weather is getting too rough? 🆘 Good work. 👍
  7. Thanks all for the likes and kind comments, hopefully later today I'll get chance to upload the latest pictures to show the current status. @DaveBaxt 'Nisha' is a two layered kit, second layer is 4mm wide Pear (much easier to work with than Walnut I have used so far in kits.), I just did the thicker 'topside' and 'bilge' planking first so that I could get each side symmetrical, once the second layer of Pear went in-between those they were far less pronounced, still a bit of work to make them look "scale", but as mentioned above I think I will need the assistance of some primer coats to reveal the overall effect. Also when I said "dry" plank bending I did mean Chuck's method of just a dab of water on the top of the plank and let the steam do the work rather than soaking the planks proper. Thanks again all for following.
  8. Few more updates on the planking phase on the little 'Nisha' that I have been doing in the last week or so. This is one of the areas I mentioned earlier where my copy of "Sailing Trawlers" by Edgar J. March has come in useful and led me down an uncertain path, resulting in a little bit of 'kit bashing'! 😮 Pages 325 - 327 of March provide elevations, plans and sections of the 'Nisha' and the section intriguingly showed thicker 'topside' and 'bilge' planking. So I have had a go at representing this on my build. The actual difference in thickness at 1/64 is very small, but I thought enough that it might add a bit of interest if I got it at least partially right, I'm not really going to know how it looks until I have a coat or two of primer on the hull, at which point it all might get sanded flat again 😆, but worth a go. I followed the level of the platform Chris provides in the kit for the bilge planking and the topside planking I simply started at the underside of the bulwark parts #43 & #44. I cut some strip I had into thinner widths to get as near I could to scale of the original 6" wide planks, then using Chuck's dry heat method bent them before gluing in place to avoid the edges turning over along the plank lengths. This batch of pictures show the process and the March cross section I referenced. I have just completed the second planking and initial results look okay I think, I will upload these next. Thanks for looking in.
  9. Hi Will, it does look different in daylight, you certainly have got me thinking about the colour scheme for these trawler’s. I think most of them would have been quite plain looking as they were hard worked and possibly a bit scruffy. From consulting Edgar March’s “Sailing Trawlers” I think my ‘Nisha’ might be finished in plain black sides with no white ‘booting topping’ at the waterline. I do have a build log, link on my signature, or look under the ‘1900 to now’ build log category. kind regards, Andrew
  10. Hi Will, lovely looking build! 👍 Have you stained the deck? It looks darker in the last few pictures and looks darker than the 'Nisha' deck I have, just asking as I like the look of it a bit darker. 😀
  11. And 'most' of the time for many of us! 😆 Keep plugging away Dave, I had similar issues with my first build (Caldercraft's HMS 'Sherbourne') a very similar Cutter to 'Lady Nelson' but what everyone is kindly saying is true, we've all done it, I have ripped planking up and copper plating before, very frustrating initially, but in the long run worth it. 👍
  12. Very nice looking boat there, love the contrast between the deck and inner bulwarks, gives me something to think on with my “Nisha” 👍
  13. Hello James, welcome to MSW from N. Yorks.
  14. Although I have not seen them in person I think the Amati and Vanguard copper plates have a far more refined appearance than the Caldercraft “dimples” which I have used and won’t be using again. Hopefully someone on MSW has samples of them to show compared to other makes mentioned.
  15. Oh, I wish I had known these were coming as I only last week got a 14ft. one from a company you know well where you need to use black card for ribs... yours look beautiful!
  16. Btw. sorry for the picture order, still getting "Error 200" on some pictures, so by time they upload, they are out of sync!
  17. Hello all, Hope you are all having a great Christmas holidays, I have been indulging in too much food and drink with family and friends to do much on the little Nisha, but a few updates below. Completed the first planking and added the keel/stem/stern rabbet patterns and also the stern counter, which I managed not to split this time! (Though I didn't soak it this time just glued and clamped for 24hrs.) Also completed a few little assemblies along the way (fish hatches, companionway and steam winch) These are very delicate parts and glad Chris includes some spares!
  18. I Don't know but I'm currently reading about the sailing trawlers out of Grimsby and other stations during the 1800's up to WW1, as background to my latest build. Interesting to learn how much the railways and Grimsby port authorities built the town to to service the fishing industry for getting fresh fish to London.
  19. Welcome to MSW Shane, from not that far in N Yorkshire 👋
  20. Hope no teeth marks! Could always be a talking point referencing Jaws, "I think we are going to need a bigger boat!"
  21. I've been getting that error just now with an update to my log. Sheer bloody mindedness and repeating the same procedure over and over (a sign of madness I believe?) and most of the pictures did go on. They were all resized and small, but the server was not having a couple of them? 🤔
  22. Moved onto the first layer of planking after finishing fairing the bulkheads more on advice of James H. Trying out pre-bending and shaping the planks before fitting to the hull, going okay so far taking it steady, but as the Nisha is small, an evening can see a few planks done in a sitting. While waiting for those to dry, I have cleaned and primed the PE ready for painting and also done a few of the later deck fitting sub-assemblies, I'll get some pictures of those uploaded soon. Also enjoying reading "Sailing Trawlers" by Edgar J. March, this has given me loads of ideas for adding little bits to my version of Nisha (many of these ideas beyond my abilities probably, but I can dream! 😆) Thanks for looking in.
