Everything posted by Knocklouder
Change of course. I finished the cannon carriages and I am awaiting the new scale correct cannons. So I made a jig up and glued the carriages together, this is my jig, it worked for me lol. Here is how I paint the wheels all at once, lined them up on a wire rod and sprayed a couple of coats of flat black. I was going to airbrush the carriages but decidd it was going to be faster just to hand paint them. Today I was going to do the gun strips, but changed course and decided to follow the instructions , lol. So it's on to page two lol. My first capstan and main pump cistern and two bits. That's the fun stuff, things I never tried before . Ok that's it for today, happy modeling Bob M.
- 255 replies
- Victory Models
- Pegasus
(and 3 more)
Ahoy AdrIan, this is the place to be. You will find many people here who will go out of their way to help you. Good luck on your journey . Best of luck
135241 lol in my sleep, the deck planking went well, I am 98% happy with it, I used a dry erase marker, the kind they use on white boards. I usually use a sharpie marker but thought I give this a go. At first I like it, if you got some on the front of the plank it was guickly sanded of, so away I went. I used a shelac sealer and it started to bleed a bit. Dang. I sanded it all of and stared drilling the nail holes. After that a good sanding followed by a guick coat of flat clear coat. So this is what it looks like, once it's all done you won't see much floor. And were the floor show, it looks good, most of the bleed happen under the aft deck so you won't see it. So I am going to make up the cannon carriages then tomorrow I am going to put the gun strips on, hopefully lol. Thank you everyone for the likes and comments, I am having so much fun putting my ships together, they may not be the best built models but they look good to me, and it's all about having FUN. Lol Bob M.
- 255 replies
- Victory Models
- Pegasus
(and 3 more)
Are you fixen to declare this a Penguin free zone, good luck , lol.
- 290 replies
- Quinquereme
- Finished
The other day I went to the wood shed and cut up some wood for in between the bulk heads. I used my table saw to cut up some right width pieces, then used my scroll saw to get them closer to want I wanted. Even so there was an awful amount of sanding, but I think I did all right. I ran a plank over it and it seems good to go. Then I plaked the stair wells on the lower deck and blacked out were the grate goes. On to the gun deck. It went on really easy, time to start decking. I only have done a two but patterns on all my other ships. This calls for a 5 butt patten. I was lost, had to give a shout out to @Landlubber Mike to ask for help. He directed me to a thread and the light switch went on. Thank you so much Mike. Peice of cake, 1,3,5,2,4 That all all I got to rember lol. I drew it out on the deck ,adjusting for errors and making sure I started right I started Then I made up a cannon carriage, painted it and put the kit supplied cannon on. Way to big. So I am getting new one's. As far as the carriage goes I think they will be OK, if I can put them together with out breaking them, they are very tiny. So This is how far I got on the deck, I gave it a quick coat of shellac, it will look better when it's all done I think I will do as much decking as I can, then put the gunstrips on, and move on to the frist planking before I do any more to the deck. We will see. That it for now. Bob M.
- 255 replies
- Victory Models
- Pegasus
(and 3 more)
Congratulations, well done. You really put a lot of amazing details on this ship, a pleasure to look at. Thanks for posting it.
- 756 replies
- galleon
- golden hind
Yet another amazing display of talent. Nicey done, and we get to watch the insertion on ytube, I watch every one lol. Great work my, Two adult size beavages of your choice are in order, amazing.
- 290 replies
- Quinquereme
- Finished
Wow your over half done the planks. If it's coming away from the strong back, that means it's not sticking to it, which is a good sign I think . Keep the rope handy lol. A couple more planks , then they get tricky, lol
- 134 replies
- sea of galilee boat
- SE Miller
This is Pegasus all put away in the top 3 shelfs , all the planks are on the rack behind the super D cup, ready for planking lol. Yes most diffinly going to order new cannons but what size is right. This is a cannon from the kit on a carriage, it does look to big, the bottom one is from an Astrolabe model that I have but can't tell you what size it is. More research lol. Well I glued the bulk heads and the plank termination patterns on the bow, it went together well. Now just going to let it dry over night , then bevel the bulk heads. After all the sanding is done I will attach the keel parts, then move on to planking the main deck. If anyone could tell me what size of cannons, I should order that would be great. Thanks PS. Don't forget to donate to MSW.
- 255 replies
- Victory Models
- Pegasus
(and 3 more)
Thank you very much everyone 😊. I took my Nina upstairs to join the fleet, wow I was overwhelmed. I looked at those 3 ships and said to myself "thank you MSN and NRG". I am still having the time of my life with this hobby. The Nina was a fun model to put together, and easier to put together. I know it's because of MSW, it's here where we learn to build. So many talented people and amazing build. Some last pictures of the fleet, then @Landlubber Mike dust off the your Pegasus and let the good times roll lol 😆. I started my Pegasus log today lol. So we put the case back on for now , the next time I will take it off is for the Mayflower, and who knows when I will finish her. The Pegasus will get it's own special case. So long my friends and thanks again. Sea you soon lol 😆
Today I was supposed to go to work but it was raining, so I decided to do a kit opening page for my new log, the Pegasus. The contents of the kit look really good, as I put things away , and get ready to build. My keel is made of plywood, not mdf. Must be an older kit, I assume. I dont know much about the Pegasus, but she sank in Canada in 1777, a little over a year after she was launched. So putting things away, the keel fell out of the box, lol, so I decided to make the temporary stand, and dry fit everything. It went together really well. It does come with a lot of plans and books of understandable instructions. I dry fitted all the bulkheads and got all the keel parts ready. So tomorrow, I will start glueing and beveling the bulkheads, and also the four pairs of plank termination patterns. Then I will see what I need to do next. It is so helpful to know that if I run into problems, this is the place to be to get all the help I need here. Thanks so much for watching. Take care my friends. Bob M.
- 255 replies
- Victory Models
- Pegasus
(and 3 more)
That looks like a lot of fun time, nicely done, and amazing work. Congratulations .
- 118 replies
- sanson
- artesania latina
Yes my friends, I am going to mark this one Finished . It was lots of fun. I made the sail and curved them , the main sail had a bit to much curve but it straighten out once hung. The rigging went well, I still need to learn how to tie Knotts but I am getting there. So here is my Nina, all done ready for the display case. But I will take some more pictures for the gallery, later. So I guess that's all folks, thank you for looking, commenting and likes. Time to thank MSW and the NRG for letting me hang around, while I try to learn how to build ship. This, for me is a valuable asset, worth donating to. I don't think there is a better place to be than right here, so many people to thank, I think I am a modeler forever lol. I can't belive how much fun this is So with my 3 Columbus ships Finished, it's time for me to build my big one, Pegasus, I had it for awhile but was afraid to start it. But now I am not. It will be my next build, but I have some other work I need to catch up on. Then I will start the Pegasus. Wish me luck lol 😆 Some final pictures, stay safe my friends. Bob M.
Hello from lake constance, Germany
Knocklouder replied to Boerscht's topic in New member Introductions
Building is coming along nicely. Had to make 35 eye hooks and rings , and installed most of them. Then it was on to the deadeyes and shrouds, I have 6 left to do for the main sail but tomorrow is another day. I measured and set the thrid hand and threaded them on. Then snuged up the lines and installed them on the ship. A thank you to @mrcc for his suggesting GAC400, for stiffing the sails . Easy to use, just brush it on, shape it to the way you want, add a little heat with a hair dryer and done. Going to let everything dry up , and wait for the main sail to dry overnight. Then she has 6 more shrouds, hang the sails, tighten the lines and the FLAGS. Got a big grin on my face tonight, maybe two more days. Then I should be able to rap this one up. Then I have a lot of studying to do lol. Something tells me my next build might take awhile lol. Comes with 14 rolls of thread I am told lol.I got so excited that I bought another model. The Pegasus was the last one in the closet, and I needed a back up for my stash lol. Got a good deal on a King of the Mississippi made by Artesania Latina. But that won't be for a while. Talk soon my friends, I am sure Lol.
That is some awesome building. The painting is very well done and the copper is awesome
- 233 replies
- Indefatigable
- Vanguard Models
Inching along, I have finished the masts and yards. Just have to tie them on the sails. Mounted the masts. They lined up. I brought my next build down to the ship yard for a little inspiration . Man I can't wait. The Pegasus was my last model in my stach in the closet. So I paniced and bought another one today. It's an Artesani Latinia, King of the Mississippi. Should be here by the end of the week lol got to have a back up lol. That's all full steam ahead .
