Wreck1919
Posts posted by Wreck1919
Thanks for the nice words guys.
Hi Martin, am trying to copy your technique for the deck (and some others 😬). It is indeed a puzzle, and with a steep learning curve 😎.
Also now wrestling with a problem with bridge complex, as the plan i have shows - i think - partly a different ship and then the plan author invented a bit. Photos i have look different. Will keep looking for answers (which is how i came to find this forum). -
- GrandpaPhil, ccoyle, druxey and 13 others
- 16
Thanks for your thumbs up gentlemen. Further catch-up.
the next pieces were the boat racks (sorry dont know the english word). There‘s quite a few to make and most are slightly different. On top comes the consideration of how/where to attach as the middle section (superstructure deck with funnels 2 and 3) is removable to get some access to rc. I‘ve tried brass and wood and settled for „brass reinforced polystyrene „😎 . Another case of available tools and my skills. The ones toward the bow also had loading cranes for torpedoes but i left those away and only built the mounting for them. This because a) they would have been stored somewhere when sailing and b) they would likely be the first thing to be ripped off when sailing the model. -
Then my first try with making a linoleum flooring. The pieces were max 2x5m and held down with brass pieces. That translates to a puzzle.. (again thanks martin for the tip).
then it was time to throw my machinery 😎 at making the portholes. Sometime i‘ll get a power-tool for things like this . Brass tube, then filled with epoxy. Just 120 …took me a while but its a hobby not a job. Oh and yes, (quite) some of them are not aligned. With practice that might improve.- chris watton, gieb8688, lmagna and 11 others
- 14
The second try . As its a little known ship, i include a picture of the original.
once the hull was done - having built it twice as the first one had a messuring error 🙁 - i started with the superstructure. As you may guess, i did it twice too.. first in aluminium then in wood. Mainly because the area for access to the rc ewuipment is so small, i had to go back to the drawing board. Still not ideal, but now it seems a good combination between access and being water tight.
the next big thing was the wooden main deck which is made from pear (?) 1.5mmx50mm planks. That took a while but i am happy with the result. So here next try with pictures, hopefully right way up.
cheers sascha -
Hi all, hope i can get this to work. (The post).
Some years ago i started building this one. Hull is wooden frames, balsa planks and epoxy (w mats) coating. My toolset is a bit limited so all „handmade“ - as you will see with the missing accuracy. Better with next one. Also am trying how to post, so will stop here and try attach some pictures for starters. Will put one more later if this works.ah, on the ship: light cruiser, built 1916 and scuttled 1919 in internment . It will be RC, so i have to build lightweight as max is 5.5kg. So far with engines, batteries, servo etc it will reach a calculated 4.5kg , so plenty of reserve.
so here the first pictures from when it began 😎mmh sorry two are upside down . No idea why nor how to turn them around.
- druxey, mtaylor, chris watton and 6 others
- 9
Hello everybody, new joiner from good old europe (CH) . My interest is scratch building 1/100. am looking to find tips and will be asking lots of questions 😬. First will have to get used to the forum , but once i manage that i ll share my current build, a german light cruiser from WW1.
look forward to exchanging thoughts and learn from experts.
- JeffT, mtaylor, Ryland Craze and 1 other
- 4
SMS Karlsruhe by Wreck1919 - 1/100
Thanks yves, i have to match with my skills (no forms making, no soldering etc) and machinery (fretsaw, drill).Both of which are somewhat basic. But someday i will upgrade 😎 .
