Wreck1919
Posts posted by Wreck1919
Just a small update (not much time to buil) .deck torpedo tubes were made (no machines, so couldnt make gears etc). Spent time figuring out were the big vent goes (middle of picture) as model plan with which i started the build is very different from builders plans which i got some months ago. Also funnels are painted. As you can see, the colour is different. Shame, because its the ssme brand&code but they must have changed the recipe… annoying for work going forward (eg touch up, corrections). But this will be „crew re-painted on board“😎.
cheers sascha -
Good to hear from you Valeriy. Outstanding work (as usual)👍🏻😎
sascha
- shipman, Keith Black, Ras Ambrioso and 4 others
- 6
- 1
- Rudolf, NavyShooter, GrandpaPhil and 9 others
- 9
- 3
- NavyShooter, wefalck, Roger Pellett and 9 others
- 9
- 2
- 1
Hi all, the past months i had quite some work to do, so not much shipbuilding. Also study of the original builders plans revealed more differences to the model plan i started with. Long story short, i had to re-start with the entire bridge structure (lenght,width, position of supports, upper bridge has addtl deck level, steel girders for support, etc). Some photographs…
still work inprogress, loosely arranged for pics.
Again a little catch-up. Steel cables holding the mast i found to be wrong in my plan. Were drawn as passing the bridge structure, but that would have them blocking the LoS of the 6 in gun. Photo study showed they pass through the bridge…took courage and care to drill the holes without wrecking it. (Mast is just temporary for angle). Also started on the ammunition rails.
cheers sascha -
🤪..yes. By the same logic playing the piano is easy: simply push the key with your finger - and voila - sound 😎
Да , ты всё понял. Спасибо.
and the construction of the plaform is your „usual“ soldering magic 👍🏻😎very impressive.
С.
Как ты построил платформу в мачте?
извини грамматика 😎
саша
Privjet Valeriy, can you share a picture of how you built the platforms ?
cools stuff. Regards sascha -
Thanks for your comments guys. A bit of update: didnt like the capstans, so made new ones (brass/wood) plus the chain deflectors .
Lashing chains (? English?) are now also there. Bit of work that as it required to remove the studs from the first two links of the anchor chain and then threading the lashing chain through it and finally getting small shackles through to fix it to the eye on deck. Will need to touch up some paint as it took uncounted tries.
some progress on the bridge with some interior „decoration“, glass for the windows. Built the 3m rangefinder and made my first piece of railing/handrail.
latest were the first bollards plus fairleads (rollers still missing) . -
Thanks for the interest guys😀
mikegr, through a tip i found a company that delivers (mostly) precision cut wood in 1m lenght. So these are 1.5x1mm pear. Planks then cut to 6cm lenght (knife), caulking applied w black crayon.
Valeriy, no worries j hope. Outside is fiberglass/epoxy over wooden frame, and inside just painted epoxy. Some areas in bow and stern reinforced with fiberglass. wood is btw balsa on (too thick as you mentioned😎) plywood frames.greetings
sascha
- Canute, Mirabell61 and mtaylor
- 3
Thank you for your likes guys 🙇♂️.
Valeriy, the answer is simple and no sophisticated background: i‘ve always built with wood and some brass as i didnt know different. Only learned last year that a company like evergreen exists 😬. With brass i can only do basics since soldering is rocket science for me and no machinery (lathe or mill). Jeweler‘s saw and drill currently. But all - i hope - wooden surfaces inside or out are treated with epoxy or similar so i hope that this works. The wooden decking has a triple cover of clear paint (dont know the exact english term) so that should suffice for occasionally getting wet (not sunk😎).
Watching builds here and on a german forum shows me how much more there is to learn.
cheerssascha
Privjet Valery - always a pleasure to watch you phantastic work.
regards sascha
SMS Karlsruhe by Wreck1919 - 1/100
Moin Eberhard, i dont have the capability /machinery to make these. Those are photo etched stanchions from Saemann. very good quality and service.
cheers sascha
