Everything posted by Thukydides
So what I mean by not bending up is essentially it is too long. It should terminate a bit earlier, I would guess right at the beginning of the notch. I have drawn in red on your picture what I would guess it should be. In terms of the lengths I don't think it matters that much for the first layer. The process is the same you just do it on a smaller scale.
- 152 replies
- Flirt
- Vanguard Models
Good progress. It is hard to tell from the photo but you garboard plank may rise a little too much up the stem. It should essentially run straight to meet the stem not curve up on it or you will have trouble fitting all the planks in and the run of them won't look quite right. Not a big deal for the first layer, but as this is your first major build you really want to use the first layer as practice for the second. I don't have a good picture of my first planking on alert, but see the below link for the post on the second planking in which you can clearly see the garboard.
- 152 replies
- Flirt
- Vanguard Models
Log #61: Shroud Batons & Running Backstays With the shrouds secured I decided to add the shroud batons before too many other ropes end up making everything difficult to manipulate. To make them I cut off two 40mm lengths of the leftover pearwood thin strips used for the molding and sanded them until they were smooth. Then I gave them a quick coat of WOP. I attached them to the shrouds using clove hitch knots and gave them a coat of varnish to hold them. You may notice that I have not trimmed the ends of the thread yet. This is because it is possible that when I am doing the final tension on the standing rigging there is always the chance the tension may cause the baton to shift slightly. If this happens I don’t want to have to reattach each knot and so with the longer ends I can just pull it tight again if it releases. Once everything is finalized I can cut them short and bend them behind to secure them. I have also been slowly adding to the ropes at the top of the mast. I mentioned in my last log that I had the pendant for the gaff done. For this I used 0.6mm line sized with 10/0 fly tying thread. For the block I followed the kit arrangement and used a 4mm double block. I also got the first of the pendants for the halliards finished. This also used 0.6mm line sized with 10/0 fly tying thread. For the block I used a 3.5mm block (3mm ones recommended in the kit seemed too small). I had wanted to use 4mm single blocks for this, but I was unable to find any (due to these blocks being made in Russia, they are hard to come by these days). I also have completed work on the running backstays. For this I decided to go with a single tackle option for the folowing reasons: It is consistent with the arrangement on the Hawk model. This model is dated to around the time of Alert. Now there was likely a significant variation on cutter rigging, but I figured this was at least a reasonable choice. I liked the look of it better than the double tackle option such as on the Kingfisher model detailed in Peterson. If choosing between two equally valid options, I tend to go with what I aesthetically like. It is less work than the the double tackle option. I used 0.5mm rope to run from the fiddle block through the pendant and secured it to the hull using one of the Syren large hooks. For the tackle I used 0.45mm rope and a 3.5mm single block. Again here I would have liked to use a 4mm block, but I had to make do with what I had. Up next, I need to add 2 more pendants and then I will be able to start assembling the mast and move on to the mainstay and preventer stay.
- 562 replies
- vanguard models
- alert
The faring looks good to my eye, but if you haven't already you might want to use some thinner batons to test that everything lies flat. Not faring properly was one of the errors I made and it caused me lots of grief later on.
- 152 replies
- Flirt
- Vanguard Models
Good luck, take your time, treat every step as it's own project. In my experience I have never regretted taking more time or going back to redo something I wasn't completely happy with.
- 152 replies
- Flirt
- Vanguard Models
What Chris said should work. You could use small amounts of isopropyl on a swab (I assume this is acrylic paint), but the problem with wood is you may still end up rubbing it around more than rubbing it off. you could try putting a few spots on the offcut of the deck and letting it dry for a few days. Then try the isopropyl on it as a test to see how well it works. Maybe a combination of scraping and then a bit of isopropyl might work, but I would test it before using on the model. Did you varnish the deck? If so what did you use. If you used an oil based varnish then the isopropyl will be much safer than it would have been on bare wood. For the CA shine use matt or ultra matt vanish. Just dilute it 50-50 with water and brush it on. When it drys it will get rid of the shine. If the spot of CA is particularly thick you may need a second coat on that area. See the link below, you can get it in much smaller bottles, just look for your local hobby store (the ones that sell D&D figures and Warhammer). https://www.amazon.ca/Vallejo-Ultra-Polyurethane-Varnish-28-653/dp/B09RMTHG9P/ref=sr_1_1?keywords=vallejo+ultra+matt&qid=1699876988&sr=8-1
- 106 replies
- Grecian
- baltimore clipper
(and 4 more)
In Goodwin’s Alert book he shows how a mizzen mast might be temporarily rigged on a cutter (such as Alert) in light wind. The diagram shown is below: What I don’t understand is how the outrigger is attached. I assume it must be run through one of the gunports and the tackle would hold it in to the ship, but I don’t see what prevents it from sliding further in. Does anyone know how the base of the outrigger would have been secured?
It is looking great. Getting planking done is one of the important milestones in any build.
- 34 replies
- Alert
- Vanguard Models
Log #60: Shrouds Complete With the first two shrouds in place I followed my usual process of moving to mass production. First I made 8 laniards using 20cm of 0.5mm rope. This does waste a bit of rope, but I am unsure of how much exactly will be necessary for the proper tying off and it is much better to have too much than too little. For each of these lengths I tied a knot on one end and soaked it in diluted matt varnish to fix it. The other end I dipped in super glue to make sure it was nice and hard for threading purposes. Then I threaded the laniards onto the deadeyes. One problem I encountered was the tendency for the deadeyes to twist. One trick I found helped with this was to first determine which way they wanted to twist and then to twist them 3 full rotations in that direction before attaching the laniards. This created an opposing force which wanted to twist back and counteracted the natural twist of the rope. I used masking tape to hold the excess rope in place. I will adjust the tension on everything once all the standing rigging is in place. With that the shrouds and standing backstays are done. I also have the pendants for the running backstays and the gaff halliard done. Next up I need to do the pendants for the spar halliards.
- 562 replies
- vanguard models
- alert
One thing you can do is identify the way it is trying to twist and pre do a couple of twists in that direction. That will make the rope want to twist back and may help counteract the forces. That is what I have been doing with the shrouds on alert.
- 106 replies
- Grecian
- baltimore clipper
(and 4 more)
- 562 replies
- vanguard models
- alert
welcome to MSW.
Thanks, I have not decided yet. When I first started this build I was aiming for a more realistic depiction and had planned to add sails. However, as things have progressed I have moved in a more stylistic, artistic direction and so I don’t think sails as I had originally planned would fit. So basically I am trying to decide between no sails or furled sails. I have seen some examples of furled sails that I think would fit with the current theme, but I am unsure if (1) it would look that much better than no sails and (2) if I could do a good enough job not to “spoil” the model. I think I am going to do some more research and make a decision at a later date, but at this point I am leaning towards no sails as my depiction is thematically trying to look like a contemporary model and very few of those had sails. That being said I am open to suggestions of models with a similar artistic style I could look at which did indeed use sails.
- 562 replies
- vanguard models
- alert
@allanyed I have noticed that Lees at times makes reference to cutters as if they are different, but never clarifies if his general statements applied to them. One of the shortcomings of the Alert book is that Goodwin rarely clarifies (particularly in the drawings section) why he is arranging things the way he is. Another great example of this is our previous discussion on the rigging of the cannons. So it is hard to tell if he is just making an assumption or if he read some tibit at some point which indicated that Cutters had their shrouds rigged in this fassion.
- 562 replies
- vanguard models
- alert
Thanks coming from such an accomplished builder that is a real compliment :). For the shrouds I relied primarily on the Goodwin Alert book. In it he arranges them as follows: What makes it complicated is in other parts of the book he refers to the 5th shroud (#s 12 and 10) as the standing backstay. Here he refers to 6 and 7 as the standing backstays and then also has single eye splices for the running backstays as well. I ultimately have decided to dispense with the extra standing backstays and will just be rigging a running backstay. So I will have 4 shrouds and 1 standing backstay and 1 running backstay. Since the running backstay has to be an individual eye splice (due to the angle), I thought going with the Goodwin arrangement of having the first shrouds be done individually since they are seized all the way down made the most sense. In general for better or for worse as this is my first build I have relied heavily on Goodwin. If I was doing the whole thing over again I might question this a bit more.
- 562 replies
- vanguard models
- alert
Log #59: Finishing the Mainmast As noted in log #57 I have been working on finishing up the shrouds in preparation for attaching them to the model. The final thing that needed to be done before I could begin putting everything in place was to finish the Mainmast. First up was to attach the boom and the gaff. The kit provided parell beads seemed a bit small for my upsized boom jaws so I ordered some matt black beads form amazon. In theory they were meant to be all the same size, but in practice they came in a fairly wide variety of sizes. Using my calipers I measured and categorized them using the smallest fore the gaff and the largest for the boom. Then I removed the mast from the model for the last time to finish the painting. This could be done on model, but it is much easier when you are able to move it around to get the best angle. The process was similar to previous painting explanations. I will note that it is important to make sure all of the highlights are consistent and any reflection points match all over the model. So for example I made sure the reflection points on the round part matched those on the pumps. With that all done it was time to attach the first of the shrouds. These are only loosely in place for the moment with just enough tension to hold the lines straight so they start to get used to the position they will be in. I will be going through and retensioning everything once all the stays and shrouds for the lower mast are in place. I have not previously shown this, but I did size the cleats to the shrouds before fastening the shrouds to the ship. The two first shrouds are now done and I will be sequentially adding the remaining ones.
- 562 replies
- vanguard models
- alert
That is really interesting, great find
Thank you very much. It is always nice to hear that people have found the log helpful.
- 562 replies
- vanguard models
- alert
Thanks @mugje and @jpalmer1970 and everyone else for all the likes and encouragement. I am still plugging away on the lower mast and hopefully will have more to show soon. In the meantime see below for a preview of coming attractions.
- 562 replies
- vanguard models
- alert
What is the brand and how do you like it? Is it very precise? Like you I have limited hobby space and so no room for a large tool shop so I am always interested in smaller versions of these tools.
- 122 replies
- Artesania Latina
- Pen Duick
Log #58: Revisiting the Rudder and the Windlass I seem to have a bad habit of deciding not to do something and then some time later, when it is much harder to accomplish the task, decide I want to do it after all. Inspired by @dunnock’s excellent job with the rudder cover, the more I looked at Alert the more the omission bothered me. And so I found myself attempting to install a cover on the tiller and the rudder. I sketched out the rough shape for the horseshoe on an off cut of 1mm pear and then carefully cut it out and sanded it till it was approximately 0.5mm thick. I then attached a bit of the same material I previously used for the mouses (a bowling alley sock similar to tights). This ultimately proved to have too pronounced a weave which I had to correct for later with many layers of varnish and paint. I then glued it to the lower counter and folded over the excess to tuck inside to give it bulk. This ended up not being quite enough and so I slipped an extra bit into it as well. I then glued it in place with wood glue and manipulated it to get the appropriate shape. Then came many layers of paint and varnish to give it a sort of tarred look. I also painted the horseshoe with a bit of a metalic look to give the impression of metal. This is a similar process to how I have previously described, just for metal you make your transitions much more dramatic and the reflection points more pronounced. The only thing on this I will note is when painting reflections it is important to make sure they all line up and so the reflection points match where the highlights on the counter background are. I also made a quick tiller cover using the same tissue paper I used for the rope ends. This time I just painted it the mix of black and dark brown that I used for the mouse to give it the impression of being tarred. I have long been looking at the windlass as the kit arrangement (though much easier) does not look quite as nice as the Iron bars laid out in the Goodwin drawings. So after looking at it for a while I decided to attempt to modify it. This involved very careful sawing and then sanding and painting the area. The painting did not take long and most of this area will be covered up and not be visible once the bowsprit is in. I mostly painted it a darker red to accentuate the shadow the area will be in. I do think the effect of these two changes really adds to the look and I am pleased I went back. Also I am pleased that nothing broke of fell off when I flipped it over :).
- 562 replies
- vanguard models
- alert
Great progress Glenn, it is looking good.
- 587 replies
- Indefatigable
- Vanguard Models
