Everything posted by Thukydides
1/1200 Vigilant Class Brig - Sails & Anchors With the rigging done it was time to move on to the sails. For them I used the same paper I used for the cutters. I drew the reinforcements with a 6h pencil to keep the markings light and also used the pencil to mark the reef lines. At this point I also decided that I would go ahead and do anchors. This was the same method as I detailed for the cutters, but much smaller. Steel calls for 3 anchors for a brig, but I dropped one on the floor and couldn’t find it. I decided to just say that one was lost in a storm rather than make it over. You can see the anchors before they were painted and glued onto the model just below the ship. Unfortunately you can also see where I used too much super glue on the sheet for the foresail. At normal viewing distances it is fine, but up close it looks a little rough. Unfortunately not much I can do about it. I tried to remove it, but couldn’t without risking damage to the rest of the model. Once the sails were on I also added an ensign and a penant. The pennant was simply off cut from the sail material painted red. The ensign I printed out and then carefully with a sharp blade sliced the paper in half to make it half as thick. This I then folded over and used paint to reinforce the colours. The model is essentially done at this point. I just need to spray it all with multiple coats of varnish to help make it more durable and then I can turn my attention to finishing the water.
- 39 replies
- Black Seas
- wargaming
Great job, the serving is looking really good. I feel like serving is one of those small things which can really elevate a model. If you decide to serve some of the smaller lines, consider getting some magnification. It helps a lot in getting the serving to lie right when you use smaller lines and thinner serving thread.
- 38 replies
- Alert
- Vanguard Models
Minor update, I have finished rigging. Unfortunately I don’t have any pictures of how I did it as every picture I take in progress just looks like a mess. The rigging I have chosen to show is meant to be more illustrative as everything is out of scale and so if I put in too much it will look crowded. I do actually wonder if I have included too much. I would be interested in your thoughts on this if any of you have an opinion. The only lines left to do are the sheets that will be attached to some of the sails. These I will add after the sails are in place.
- 39 replies
- Black Seas
- wargaming
Nice trick with the ring. Also I like the curved jaws. They do make the model look more interesting.
- 312 replies
- Chile
- Latin America
(and 6 more)
I think it looks much better. In terms of the angle, that depends on the waterline. Cutters had a keel drag so you need to look at the plans and make sure the waterline is level with the base. It looks pretty close to my eye, but without looking at the plans you don't know exactly how much keel drag there was. The mast on cutters is not straight, the exact angle to the keel you need to figure out from the plans. For example you can see below a picture of my alert (an earlier cutter), but you can see how far back the mast is angled.
1/1200 Vigilant Class Brig - Rigging Part I Rigging at 1/1200 scale is a bit of a challenge so I have made some decisions to both simplify and also to help differentiate the lines. Despite being out of scale, I used a larger thread for the main and fore stays as I want them to look beefier than the rest of the lines. Much of my technique is similar to the previous examples, but I have not bothered using knots to simulate blocks as they would be too big. You can see below me tying off the backstays. I actually used the thicker line for the main topsail backstay by mistake and only noticed this as I was working on this log entry. Thankfully it is not really noticeable at normal viewing distances. The picture below shows the current state of affairs. I have all the standing rigging done as well as the main braces and the running rigging for the boom and gaff. You may notice some damage which is inevitable when doing the rigging. Once everything is done I will go back with the paintbrush to touch up any problem areas. I have decided that I will restrict myself to braces and sheets for the running rigging. This is enough to give a taste of things without making them too complicated. I have also been using a trick of painting parts of the white rigging brown to simulate pendants.
- 39 replies
- Black Seas
- wargaming
Good luck. Just remember you will never regret going back to fix something you didn't quite do right, but you may regret not bothering.
- 8 replies
- America
- Model Shipways
Log #20: Bolts, Joints & Corrections Thanks @AON for your suggestions. I have done a bunch more research on the subject of tapering the knee of the head and found some interesting things. I will post some of my findings next time. As research is ongoing in the background, I have continued to work on the bow and the keel. When I last updated you all, I had almost finished assembling the knee of the head. The next step was to glue the last piece in place and then make corrections to the overall shape. Overall the process has been better than anticipated in terms of wastage. I have only had to remake around half of the pieces. Most of these remakes were due to silly errors (I didn't think before cutting) as opposed to improper fits. I had purposely left some leeway on the outer edges to allow for corrections once everything was glued together. As I am clamping at high pressure to make the joints as tight as possible, I anticipated there might be some slight bending of the pieces and so stuck a template of the overall shape in place to make adjustments with my drum sander. Once those adjustments were done, it was time to drill the gammoning and bobstay holes. I stuck templates of the individual pieces onto the finished piece to get the positioning right. Then I drilled the holes with my drill press. For the gammoning hole I simply drilled the two ends and then used a combination of min chisels, scalpel, files and sandpaper to open of the rest of the hole. Using my mini chisels I cut out the various joints. For the keel joints I am not scarping them correctly as no-one will actually see any of those joints except the ends butting against each other. I considered simply just butting the ends together with no joints (where you can only ever see one side at once, but my OCD rejected that. You can see how I have written the part number and the direction that faces forward on the top of the pieces. Remember when I mentioned having to redo pieces because of silly mistakes? As previously noted I glued pieces together using a 50-50 mix of heavy body acrylic paint and wood glue. Then I glued the lower stem into the fore piece of the keel and then clamped and glued that assembly to the knee of the head. The order here is important because I need a square surface for drilling holes and so as I add thicker pieces I need to be aware of what holes need to be drilled where. For the bolts I discovered that the black 18lb fishing line that I had left from when I used it for bolts on alert was pretty much the exact right size for the 7/8 in bolts called for by the contract. So I drilled the holes with my drill press and glued the line in place using super glue. Note that I just drilled half way and then flipped the pieces over and drilled with a new template from the other side. Any small deviations could potentially be really noticeable so I figured safer to do it this way. You can see below the line sticking out of the holes as the glue dries. Note that I have not completely cleaned up from the gluing process as there is lots of sanding to come which will fix any glue residue still on the outside. The final thing to note is a realized something today that I am glad I caught this early (before it became a problem). The plans I bought seemed to indicate that the waterline on the model was parallel with the keel, but when I went back and checked the various sphinx class plans, I realized that all of them show the waterline as having a small keel drag. At first I thought this might be a distortion issue, but it is remarkably consistent and pronounced across all of the sphinx plans. This does create some future problems for attaching the model to the base as I made the screws perpendicular to the keel, but the slope of the waterline is only very slight and so I figure I can probably come up with a way to adjust for it. Thanks for stopping by and for all the encouragement.
Good job on the planking. I don't think your bulwarks look too high, they are meant to vary in height along the length of the deck. What I did is just planked starting from the bottom and then when I got to the top I let the planks go over the top. Then once everything was glued in place I sanded / filled it all down to match the height of the inner layer.
1/1200 Vigilant Class Brig - Painting Part II After painting the hull, the next step was to paint the seascape and attach the masts. Before glueing the masts in place I painted the bottom masts as accessing this area will be hard once they are in place. The seascape I painted in a similar manner as previously discussed. I first laid down a thick layer of may darkest colour (dark sea blue) and then started wet blending in increasingly lighter blues to create contrast and the illusion of depth. I focused the lightest colours on the tops of the swells, the area around the hull and the wake. At this point the sea is done until I varnish the miniature as I don’t want to add the final water effects until everything else is in place. My tying of the yards to the masts has done a really good job of securing them as being clumsy I keep bumping them, but so far nothing has snapped off. You may also notice in the above picture that I added royals as I had forgotten them when I first constructed the masts. Next up was painting the masts and yards and then finally attaching the lower shrouds. This is a very fiddly process and a lot of touching up is required due to paint rubbing off. As the shrouds I am using are oversized, I can’t use the deadeyes and lanyards that come with them (they would look really out of scale). So instead I simulated lanyards by painting the bottom vertical segments of each set of shrouds a pale cream colour to give the impression of lanyards. Though the shrouds are not the correct scale. At this small a size, like the planking on the deck they actually do a pretty good job of selling the illusion of the model. Next up I need to start considering what rigging I am going to show.
- 39 replies
- Black Seas
- wargaming
I like to work up as I go. So have everything built but not glued together. Then I do the mainmast and all the associated rigging then the topmast etc. The main advantage of this is it lets you make the shroud eyes (and serve them if that is what you plan to do) off model and then slip them over the top of the mast instead of having to try and seize them on the model. For the yards I rig as much as I can on them (this would include the furled sails) off model. It is much easier to do things off model. Then you attach the finished yards to the mast. If you are pinning them, make sure you drill the holes for the pins in the mast before adding it to the model (again much easier to do off model).
1/1200 Vigilant Class Brig - Painting Part I To help with the problem of painting something so small I decided to use my airbrush to spray on the deck colour. I found in my 1/700 models that it was actually hard to get a smooth coat for the deck with a brush given the hard to reach areas. You can see that even though they are out of scale, the upper shrouds look fine at a distance. One advantage of painting at this small a scale is you don’t really need to get your placement perfect as at normal viewing distances it will not really be noticeable. I have the base colours down for the hull, but given the small scale very little will be necessary in highlights. Essentially I will be just picking out the upper faces with a lighter version of the base colour. I recently got some dentist loupes off of amazon (the cheap ones). These are a big improvement on my previous magnification glasses, but they take a bit to get used to as they are designed for proper posture (so I don’t need to bend in close), but I have to unlearn all my previous habits regarding where my hands go relative to my face. To give a sense of scale, the squares on the matt are 1cm and the entire base is about 4cm long. Zoomed in this close you can see some of the printing layers, but they are not really visible with the naked eye.
- 39 replies
- Black Seas
- wargaming
I second @wefalck's suggestion. I find template really helpful. I had not noticed you started another build till now. Great job so far and I look forward to seeing her progress.
- 139 replies
- ancre
- Bateau de Lanveoc
That is a clever trick. I will need to remember that one. The ship is looking great. She really is a lovely model.
- 332 replies
- Harpy
- Vanguard Models
Log #19: Beginning the Knee of the Head, Stem and Keel I have begun work on the knee of the head, stem and keel. Step one was to cut the parts out using my scroll saw which I have now found I can be pretty accurate with if I go very slow and use magnification. I also discovered that it is best to glue the pieces as I go. This allows me to adjust the fit of every new piece to match what I had previously cut. As previously indicated, I am gluing the pieces together with a 50-50 mix of heavy body acrylic paint and glue. You can see in the below picture how the glue spills out, but due to it being so thick, it does not stain the surrounding wood. The lines still look a little rough, but that is just due to the fact that even very small discrepancies in the alignment when clamping can lead to the lines looking untidy. Once I start sanding they will look much more neat. You can see how I have used darker glue up to the waterline and white above that. As it is impossible to be super precise with the glue placement, I erred on the side of having dark glue above the waterline as I can always paint in the white line if necessary. I have also cut out most of the other pieces though many of them need final shaping. You can see the current state of affairs below: Once I am done shaping and am sure everything fits properly I will drill the necessary holes. Then I can give thought to sanding and shaping. As I am preparing for final assembly and shaping I have been giving some thought to the thinning of the knee of the head. I have a few questions which I am wondering if anyone is able to help clarify for me. Due to measurements given in the contract I know that the thickness of the knee of the head at point A is 7.5 in (matching the width of the standard which is given in the contract), 15 in at point B (given in the contract), at some point below point C the stem thins to 13 in (the thickness given in the contract “below the hance”) and then finally thins to 11 in at point D matching the width of the keel at the fore end. What I am struggling with is the following: How quickly should the upper stem (part I) thin from 15 in to 13 in below point C? How quickly should the lower stem (part II) thin down to the 11 in given for the keel at the fore end? The thickness of the knee of the head is given at 11.75 in. Where the stem meets it, does it look like option A all the way down until it matches the thickness of the knee of the head, or does it ever become like option B? How thin should I make the leading edge of the knee of the head? There is no indication of the relative ratios in the contract. The fore end of the keel is given at 11 in, does this mean that the leading edge of the gripe would be thinner still?
1/1200 Vigilant Class Brig - The Yards My work on the smaller scale continues and today I am going to discuss the yards. Unfortunately I don't have much in the way of pictures because taking them in the middle of building is really difficult at this scale. So instead I am going to use some diagrams to demonstrate and then show a picture of the finished product. First I took a look at some maritime paintings to pick a sail layout. It is important to plan out exactly what you are planning to do as this will impact the position of the yards and we want to produce a coherent model. After cutting the various thicknesses of brass rod to size, I filed a notch in the middle of each yard to help hold it in the right place. For the gaff and the boom, instead of a notch I used a pair of plyers to squeeze flat one end. I then super glued the yards in place and tied them to the mast with 10/0 fly tying thread. Though this is not a perfect solution, I have found that this is the best way (where I don't have access to soldering) to secure them to the mast and better to do it now then have them constantly falling off while painting. As you will see in the final picture, it is not really noticeable. I first do a single knot at the front and then run the thread under the opposite sides of the yards from which it came and do a single knot secured with super glue at the back. Then after it is all dry I cut off the ends with a fresh scalpel blade. For the gaff and boom I used the flattened area which was now a bit wider to tie on with a single knott (and secured with glue) some more 10/0 fly tying thread. The ends of this were then tied around the mast and both the connection and the knot secured with glue. And here is the finished product ready for basing. The masts are only loosely in place as they will be painted separately before being attached once I have finished painting the deck details. I have chosen to depict her broad reach with the wind on her larboard beam.
- 39 replies
- Black Seas
- wargaming
This is a very cool construction method. It is looking like it will turn into quite the model.
