Posts posted by pompey2
I use the bench magnifier as well as the optivisor, both have their place IMHO
And the previous warning is a good one, both can suffer from catching and ripping off something on the model if care is not taken.
For a first model you shouldn't need to consider bench power tools.
However a dremel or similar is often invaluable.
Drilling, sanding, grinding, turning - all possible.
Nick
Hi Paul
Great to see your build log, another Caldercraft Victory is always welcome.
Your Vic is looking great so far keep up the good work.
I trust you are enjoying the hundreds of copper plates
I think your 10 year estimate is a good one, I have been on m Vic for about 13 years (had a break in the middle)
But I'm only a few weeks away from the finish line now.
I will be looking in occasionally, best of luck
Nick
I've been looking at / talking to a great German site you could try.
Put this in Google translate to see it in english
http://www.massiv-holz-werkstatt.de/
They have a huge range and the prices are very good.
It looks like they export to a lot of places also.
I expect to buy some Maple from them soon
Nick
Hi Kevin
She is looking magnificent, great work.
I see you have left the Boomkins off for now.
Let me say that is a good idea, wish I had done the same.
I managed to break one off completely, they stick out at a very 'easy to catch' angle.
It meant a bit of careful knighthead removal and replacement.
I'm curious about one thing (hoping I haven't missed something)
The extended eyes you have on the bottom of the Sprit Sail Yard?
All the best
Nick
A great result Gil, loving it.
Nick
The majority of strakes will be pretty straight.
If you edge bend a few of the easier ones then the need for spiled planks would be pretty minimal.
Also you might find that after edge bending some you can do them all that way
- Seventynet and mtaylor
- 2
Hi Robert
I think my brass tubing was about that in diameter, check the inside diameter.
The wiring was a tight fit and I used very special wires.
I doubt that you will find normal wires to go through.
The ones I used (from work) are Kapton coated wires, the Kapton is a good insulator so is applied very thinly.
A search online should find you a local supplier.
Nick
I was suffering from the exact same problem, lots of clutter.
So I designed and built a trolley on castors that was custom built for my tools and would wheel under my work bench.
It is normally just at my side so within easy reach.
Here was my progress.
Nick
http://modelshipworld.com/index.php/topic/8928-design-and-build-a-custom-work-station/
- Seventynet, EJ_L, Canute and 1 other
- 4
Like Jack, I have these hooks.
I use them quite a lot.
The hook end is good for reaching into the rigging to snag and pull through a line.
And the slot end work the same in reverse, it can be used to push a line through a tangle of other rigging.
And a combination of the tool and tweezers is great for belaying round a pin.
Of course making your own would not be too much of a challenge.
Nick
Hi Rob
Sounds like a good idea.
Plus if anybody notices a slightly different colour on two planks then you get to tell them it is the real thing.
Looking good by the way, great to see you back uo to speed.
Nick
Hi Ian
Your build is looking great, the planking especially.
On the upper gun deck I opened up the clearances around the bulkheads to get it in.
That worked ok but needed a lot of care making sure it was aligned properly before fixing.
Cutting in half sound like a better bet.
Keep up the good work
Nick
Finally
I have decided to hang one or two of the ships boats from the Quarter Davits. That then leaves more space in the waist to allow a better view down into the Gun Deck. Also I like the way a boat on the Davits looks. So before I get into the next round of rigging I assembled and loose rigged both Quarter Davits. I had predrilled for the bracket pins a long time ago and they went on with no real problem by using a pin punch between the deadeyes. I have left some of the rigging adjustable so I can set up the boats later.
And so onto the Braces. Because they are outboard of the hull and might get snagged I am rigging they loose at the moment. First the Fore Yard all run but then loosened off.
Then the same for the Main Yard.
tightened down the Main Yard Braces to allow me to make up and rig the lizards on each side, then slackened off again.
That’s me up to date with photos, it’s getting a bit busy in there now. I really love the way a model starts to come to life as the rigging goes on.
I have also rigged the Crossjack Yard with Braces now.
And I’m starting to make up blocks and lines for hanging the Driver Gaff which is the next task.
Thanks for dropping by
Nick
Falls of Clyde 1878 by GAW - FINISHED - scale 1:96 - iron 40-frame hull center cross-section
Wow, what a great read your site is Gerald.
The ingenuity in your tooling is exceptional, as is the manufacture.
Really lovely work.
Nick
