wmherbert
Members-
Everything posted by wmherbert
Welcome. I'm sure everyone here can point out things that they wished they did a little better on a model. I just try to do each one a little better as my experience and skills improve. And the reality is that you will spend many hours building a model that even your best friend won't spend more than a minute or two looking at. So just relax and enjoy the process and try to gain skills as you go along. Bill
Looks great. I'm always amazed at how much difference little last things like line coils make. Bill
- 122 replies
- Artesania Latina
- Pen Duick
I need to do white letters on a black background for my ship's name. I can see how i can print black letters on clear decal papers and I have seen white decal paper but can't see how I could print white letters. I've been searching the forum and I'm sure it's in here somewhere but would really appreciate some help. Bill
Remembering to drill out blocks before installing them and to run a little CA glue on ends of lines before trying to push them through blocks really helped me. Bill
- 152 replies
- Flirt
- Vanguard Models
Stepping the mast with a plum bob...two questions.
wmherbert replied to HardeeHarHar's topic in Masting, rigging and sails
I do glue the masts with PVA while doing the adjusting . And then when glue is dry I tie down temporary shrouds down to the sides of the model to steady them until actual shrouds are installed. Bill -
I first use an adjustable square . I place it on the plans to get the proper rake. Then I place the model on a flat level surface and adjust so boat is level side to side and waterline is level. Then I place the adjustable level along side the model and sight its edge and line up the mast fore and aft. Then a big carpenter's square (18×24 inches) I place directly in front on the boat and sight back along its edge to line up the mast. I have a jig that I made to steady the mast and hold it in position. I can slide the boat fore and aft and side to side to move the mast until everything lines up. Doesn't take that long and I think it gets it as good as is possible. Bill -
One rather late question about your hull plating. I'm starting a scratch 1914 paddle wheel steam tug at 1 to 48 that had a riveted steel hull. I've liked the way your plates came out. Are the individual sheets of your aluminum foil butted together at edges or are they overlapped? And one other question. How did you make the half round rub rail running along the hull? Thanks, Bill
- 330 replies
Have you considered using silkspan? I've used it on my last three models at 1 to 50 scale and I think it's come out very well. I've never felt that using cloth looked so good. On each I got running rigging all done without sails and debated about adding the sails and at the end was very happy I did. Now these were all fishing schooners. Not sure what is best on a big square sailed man of War model. Bill
- 184 replies
- Bluenose
- Model Shipways
Looking very nice. What is the blue cutter in the photos? I haven't seen one before Bill
- 282 replies
- Bluenose
- Model Shipways
Welcome and congratulations on that model. Very nice. Bill
New member with questions about first kit options
wmherbert replied to HeyIwanttolearn's topic in New member Introductions
Welcome. For my two cents I would look at the Billings boats Henriette-marie. I just got it for about $50 as a break from more complicated models. Easy rigging. Planking practice. 1:50 scale. Nice looking boat. Simple deck structures. I think pretty much a perfect first time model Bill -
Trouble with scuppers
wmherbert replied to wmherbert's topic in Building, Framing, Planking and plating a ships hull and deck
On my current model, Puritan, the hull topside, bulwarks, and waterways are all white so no problem. When I run into difficulty is when topsides are black for example and bulwarks and waterways are white. Should the supper going through the bulwarks be white or should it be black? And more than historical accuracy what is visually pleasing? I've never come to a decision for myself. -
And maybe this should have posted under painting section. Oh well....my excuse is that I am just old Bill -
And sorry just realized auto correct changed scuppers to scubbers -
Hi all. I have trouble finishing off suppers so that they look right when painting hull. So much so that for recent models I've just eliminated them. My problem is trying to paint them when hull color is different from the water ways. When hull is black and waterways are white do you continue the white out under bulworks or paint that part of waterway black to match hull. Whichever way I try always just looks jarring to me. Which way do you do it? And which way would be historically correct? Thanks, Bill
