Everything posted by chris watton
OK, I have just competed the hull designs for Harpy (1796), now onto masts. Here are a few pics of the (sacrificial) 'pre-prototype', again, used only to check fit of designed parts, so this has really been taken apart and put together a lot. (And is in fact the third of my builds for this) Again, the only planking required will be at the level below the main wale down, with everything above this all pre cut/engraved, including the main wale (this is why they take so long to design) Armament is absolutely typical of this vessel, 16 x 32-Pounder carronades and 2 x 6-Pounder long guns. 64th Scale, as I am sure someone will ask, and a hull length of around 545mm, with a lot of detail.. ETA - The hatch coamings sit on the deck beams and carlings, and not directly onto the deck, and the deck sits directly onto the deck beams, instead of ply sub deck and lime deck, for better scale appearance.
3D Longboats in Blender
chris watton replied to 3DShipWright's topic in CAD and 3D Modelling/Drafting Plans with Software
Funny you mention copy and paste renders in films. If you pause on a certain shot in the film Midway (the newer one), you will see they pasted half a dozen or so Yamato class battleships in an overhead shot. -
I have always wondered if they put the ladder there specifically for that occasion, for the ladies benefit.
- 319 replies
- Sovereign of the Seas
- Airfix
In all honesty, you do not need edge bending tools - the first planking is only 1mm thick, you can wet it and induce the curves you want using your finger and thumb
- 60 replies
- vanguard models
- cutter
Page for the launches are now live: 24′ and 26′ Launches (3D printed hulls) – VANGUARD MODELS 26 foot – 123 long x 37 mm wide - £29.00 24 foot – 112mm long x 34.5 wide - £27.00 Each mini kit has three 3-d printed parts and one sheet of 0.8mm pear laser cut parts. I am very happy to have started to produce these, and the forthcoming boat types. I remember the choices always being pretty slim (to put it mildly) for pre made hulls, usually having to settle for some generic type that was always too much of a compromise - and I also know that many have trouble, or do not like the plank on bulkhead mini kits. I am hoping these will help fill a gap...
Little update. I will soon have a new 24 and 26-foot launch for sale later today. These have 3-d printed hulls, windlass and stern davit, and a 0.8mm pear laser cut sheet containing knees, thwarts, oars etc. Both in 64th scale for now. I have also commissioned a 22- and 24-foot cutter, 22-foot yawl, 28 and 32-foot pinnace and another launch, so ultimately, I shall have complete pre made hull sets (along with the laser cut wood parts to go with them) for all of my kits, including future developments, as an alternative to the plank on bulkhead versions. Also almost ready are the new Nelson figures. This will be available in 72nd, 64th, 48th, 32nd and a few in 1:16th scale. These have a separate base.
I would never ever use white metal castings in any of my kits again. The whole lot for Alert were thrown away and I was happy to take the finacial hit.
- 562 replies
- vanguard models
- alert
I have commisioned a second figure of Nelson using a new carver with more accurate facial features: These are a work in progress with a little more tweaking required. The render showing Nelson on the plinth was the first. I asked, based on previous feedback, to have dowels on the bottom of the feet and holes to take the dowels in the plinth, if people want to display the figure either on the plinth, or on the deck directly.
No filler blocks required. There are 17 bulkheads with a space of around 13mm between each one. Skeletal assembly is rock solid and virtually impossible to have the banana keels of old.
- 60 replies
- vanguard models
- cutter
You can give the wheel a few coats of spray primer, white or red oxide. This does help round off the edges. Wooden wheels are always way too thick and out of scale for 64th, metal ones almost as bad, and 3-d printed versions too fragile. (in my experience, at least - same applies to belaying pins)
- 96 replies
- Sphinx
- Vanguard Models
Masts and Bowsprit - Glue or Not?
chris watton replied to Coyote_6's topic in Masting, rigging and sails
I always add just a drop of PVA to the bottom of each mast, as they will twist otherwise, and you'll be forever trying to twist them back into position - unless of course the mast is keyed into place. -
Very well done, BE, they both look stunning!
- 648 replies
- Indefatigable
- Vanguard Models
