marktiedens
Posts posted by marktiedens
Thanks popeye - taking a break from the rigging to work on the ship`s boat.
Thanks,Ken. You are doing a splendid job with yours also.
Wow Pete,that`s one nice figurehead!
Thanks Mike - your kind words are much appreciated.
Thanks also to everyone hitting the like button.
Thanks Pete - yes,a bit tricky. There is some deflection as it is nearly impossible to rig the backstay without a little deflection.
I decided to fix an error - the cleats on the fore & main masts for the preventer stays should have been just one on the forward surface of the mast instead of two on the sides,so I removed the ones on the sides & added the ones on the forward sides of the masts.
Thank you very much,Edwin - your thoughts are appreciated.
Thanks,Michael - yes,I am using Chuck`s rope for all but the smallest lines. I am using sewing thread for those. Nothing really wrong with the kit rope - just too fuzzy like all kit rope. All the kit rope is light tan & I was having trouble darkening it consistently & once I did,it got too stiff to work with. I already had most of what I needed anyway.
Thanks,Pete - you are too kind.
Hi mates - another update.
The main stay & preventer stay are now done,as well as the snaking. The fore & main top crowsfeet are done also. 2mm rope was used for the main stay & 1.6mm rope for the preventer stay.
As always,thanks for looking in.
- zappto, piratepete007, md1400cs and 8 others
- 11
Thanks Frank - getting better every day.
Another little update - I thought I would take a little break from rigging & add some nails to the wales as Ken did on his RW. The nails I used are from the railroad area of my local hobby shop. They are called track pins & the nice thing about them is they are already blackened .
Thanks Pete - yes, it is starting to come "alive" now. I`m trying not to rush through it & mess it up.
Hi mates & thanks for looking in. A little more progress made - I have finished installing the main & mizzen mast back stays & the mizzen stays. The crowsfeet at the mizzen top are also done. The shroud cleats provided are really nice,but looked a little large on the mizzen stay,so I had one a little smaller that I used. I will use the kit ones on the other areas where they are needed. Just about time to install that fragile bowsprit & hope I don`t snap it off while turning the ship back & forth.
Thanks,ragove - happy to have them done.
By the way,I think I forgot to mention the ratlines are standard Coats & Clark sewing thread & the spacing was done by eye.
Thanks Pete & everyone else looking in. One more picture of the topmast & futtock shrouds -
- NMBROOK, Beef Wellington, fmodajr and 7 others
- 10
Royal William by marktiedens - FINISHED - Euromodel - scale 1:72
Update - I thought it would be a good time to take a break from rigging & work on the ship`s boat. The kit supplied boat is molde from resin & with some work it can be made to look presentable. The first picture shows the boat as supplied - the casting is very thick,so the first thing I did was thin it down with my dremel & sanding drum. Then I added a little sheer to it. The frames were added - only down to the bottom of the casting. Floor boards were then added - they hide the fact that the frames don`t go all the way down to the keel.A cap rail was the made along with a rubbing strake. The inside was painted yellow ochre along with the space between the cap rail & rubbing strake. The bottom was painted with a Floquil color called aged white.The rudder was then made with the hinges simulated by installing a couple of pins,then some black card stock was cut & glued on next to the pins & the pins were then glued to the added strip on the transom. Finally, all the thwarts,foot boards.& thole pins were added. I did not make the masts or oars - didn`t want to hide all the work I did by filling up the inside of the boat with them. If anyone asks,they are stowed below decks.
