marktiedens
Posts posted by marktiedens
Thank you all again. I plan to fight it as much as I can.
- Old Collingwood, mort stoll, egkb and 5 others
8
Thanks for your thoughts - very much appreciated. If all the kind thoughts here could heal, I would be well tomorrow
- Edwardkenway, mtaylor, Ryland Craze and 1 other
4
Thank you all for your kind thoughts - they are very much appreciated.
- Paul Le Wol, GrandpaPhil, Edwardkenway and 2 others
4
1
Yep,some parts of this kit are a bit frustrating
. You`re doing a fine job,though. Hang in there
I built this kit a number of years ago & it appears they have redesigned the kit at some time. Your build photos look almost totally different from what I remember! The chassis looks about the same, but the coach work is almost totally different. I don`t have it anymore - built it for my Sister`s husband, who used to work for Wells Fargo. I will see if I can get some pictures if you would like to see it.
Hi - another small update. All the channels are glued in place along with the fiddly PE support brackets. Extra brackets are supplied in the kit, but none are shown on the mizzen channels on the plans, so I did not add them. The extras may have been provided because the way they needed bending to fit it would be very easy to break them (don`t ask me how I know). Need to make up a bunch of chainplates next. Thanks for looking in
My vote goes to the vintage one - the newer one looks like a cross between a horse & lion
. You would think a newer design would be better, not worse!
- md1400cs, Retired guy, Baker and 5 others
8
13 hours ago, md1400cs said:
I have both kits - this one (green box) is current kit packaging - Vintage kit had a blue box, and all metal bits were in packet trays. Current kit includes eight blister packs - along with excellent part locations images within blisters for actual bit locations. Also all plan sheets were 1:1 with vintage kit - the image looks to be reduced size sheets from curent kit based on how sheets are folded.
I must have got the odd one - my kit was in a green box just like in the first post, but all the decorations were in trays - no blister packs, no etched decks or planking. That was back in the late 80`s if I remember right.
- FrankWouts and EJ_L
2
I believe the Mantua kits actually use bronze for their castings - at least the older kits. Don`t know about the newer kits. As far as cleaning them, you might try a buffer wheel in a Dremel tool if you have one. They use the lost wax method of casting, so the residue may be some of the wax that has hardened. You might also try applying some heat to them - like a hair drier or very hot water - to see if the residue softens up.
- thibaultron, mtaylor and Canute
3
Looks like you have the older version - I did this one a number of years ago & it builds into an impressive model despite the inaccuracies. I`ll be watching also
. I wish that book was available back then.
2
Thanks guys
. I already have pins in the channels - just haven`t glued them in place yet
. Now, I am doing some minor house maintenance, so progress is still slow.
- Old Collingwood, egkb, zappto and 1 other
4
Hi all - moving along at a snail`s pace, the upper gunport lids were glued in place & the ropes added. Then, I thought it would be a good time to fit the channels. After double checking the plans, I discovered that I glued the moulding above the upper gun deck ports too low & there wasn`t room to mount them below the moulding as the plans showed
. So, after assembling one chainplate,I saw I could mount the channels above the moulding & still be ok. the channels are not glued on yet & I haven`t got to the starboard side yet. I still have to blacken the channel brackets & some other brass parts before I glue the channels on. Still trying to figure out how I got that moulding so far off.
Thank you Sjors
. Things are improving s l o w l y.
- FrankWouts, Old Collingwood, egkb and 2 others
5
Thanks for your comments Harbour Dog
. If you are looking for a good place to start, a cross section would actually be a good place to get started,as you would not have to deal with all the intricacies at the bow & stern.
Thanks Frank - progress is being made
HMS Vanguard by marktiedens - Model Shipways - scale 1:72
Thank you OC.
