marktiedens
Posts posted by marktiedens
  1. Another small update - futtock shrouds done. The chainplates were made by wrapping the deadeyes with .8mm brass wire & soldering them shut. Then the ends were cut off & flattened by pinching them in a vice. Finally,a hole was drilled in the flattened ends. Hooks left over from a previous build were used to rig the shrouds.Smaller hooks were used on the mizzen shrouds.
    001.JPG.58edec899d6241e9eb18e6d0d46007e2.JPG  002.JPG.6d7fa09bc79d392f05c5f3ce11bbf017.JPG  003.JPG.868ee62601c2f0bd5a645921295052ad.JPG  Mark
  2. Looks great,Ken - you are moving at a much faster pace than I did. Those windows are the easier part - the next level gets a little more tricky. All the pieces at the next level need to sit just right for everything to fit together. Pay attention to the angle of the plywood side entry arches - they will determine the angle of the recessed windows. you may notice the recessed window panels are arched more than the deck they sit on,but when angled back at the top to rest against the ply arches they should sit with little or no gap across the bottom.
  3. That is especially true about the metal bands that fit around the transom supports. At first they seem like they are too short,but if the transom supports are shaped right they will fit.After shaping the supports,I actually had to shorten the metal bands  a little where they meet the hull. Patience & a lot of test fitting is the key to getting everything to fit. Pete`s info on this area is very helpful. By the way,don`t throw anything away from the kit until the entire ship is finished - you will probably need to make some items from off-cuts & the sheets that the laser cut parts came out of.
  4. Hi Ken - I was also pleased by the tone of the wood in the kit,so I didn`t paint mine either. The stern will be quite an adventure,so take your time with it. You will be doing a lot of test fitting,filing,& sanding. It will be the most difficult part of the build. I ended up cutting off all 3 lower decks at the last bulkhead - they did not line up with the transom support blocks & the angles were off too. Also,the lower transom support is the most important piece to get right - how everything above it fits is dependent on getting it as close to the correct shape & position as possible. One more thing - make sure the 2 main support pieces match the plans before you start carving them - mine were cut incorrectly as noted in my log. Euromodel was very apologetic about the error,but I decided to just make new ones. As I understand it,only a few kits had the mis-cut pieces,so you should be ok.
  5. Another little update - all the lower shrouds are now done. Also added all the staves to the shrouds - each one is tied to each shroud rope. Glad to get that fiddly stuff done:).Still deciding whether to add catharpins - they are not shown on the plans,but they were in use at that time period.
  6. Thanks for your comments & likes,guys. The eyebolts are really easy to make - just put a small drill bit in a vice,wrap the wire around it,then continue to twist it with a pair of pliers. The nice thing is you can make them any size you want depending on the size of drill bit. I made this one with .8mm wire & a #55 drill bit.
  7. Hi Popeye -  I already have some of those eyepins from Michaels. Unfortunately,the eyes are a bit too large - couldn`t find any that were small enough. I may go back & ask someone in the store if they have any smaller ones rather than try & find them myself. I may also get some more from Model Expo next time they have a sale on supplies.
