marktiedens
Posts posted by marktiedens
I agree with the previous comments.One thought for the next time - before planking the upper part of the hull I cut the posts about 1/4 of the way through at deck level so they are fairly easily removed with a pair of needle nose pliers.then you can smooth the inside of the bulwarks with a very small chisel & sandpaper.
Karl - I have the Corel plans because I have the Corel Wasa kit.I don`t know if the plans are available separate.The book mentioned by Ulises may be the way to go.
Ulises - is the book available on Amazon or somewhere else?
Thanks again everyone.Watching all your builds progress has has raised the bar for my build.
By the way I am using the Corel rig plans as the Sergal rig plans are awful.The Corel plans seem fairly close.If they are not totally accurate thats ok as neither is the rest of my build.
/Mark
Many thanks to all for your nice comments.The dreaded ratlines will be started soon.I think the rigging really makes the ship start to come alive.
/Mark
My Royal Louis also was short on boxwood planks - didn`t even have enough to do one side.
/Mark
I see that some pictures have disappeared in some earlier posts.Unfortunately I deleted them after about a month so I can`t put them back in.
/Mark
I have decided to add a stern lantern since I have never seen a ship of this era without one.I robbed a lantern from an old model of a dutch ship & modified it slightly.It had some red plastic inserts to represent glass so I removed them & made new inserts out of some clear acetate I had left over from my CC Victory.The separate panes were simulated with some fiberglass screen repair material.
/Mark
I built this kit many years ago - I`m sure yours will turn out much better than mine.I still have it but I`m not too proud of it.
/Mark
I feel for you Salty - having built the old version of this kit a number of years ago it seems as though they have cheapened it up somewhat.Mine had no laser etched decking or balsa & although the instructions were sketchy the plans & materials were pretty good.It was a pleasure to build & made into a nice looking model right out of the box.The first planking was lime & the second planking was a honey colored "walnut".
/Mark
Thanks everyone - doing much better now.You may have noticed that I built the mast with the topgallant section as on the 1:10 museum model.I see that some people omit this.I don`t know which is correct so I went ahead & added it.
/Mark
Finally able to do some light work on my ship.
Slowly working on the masts - foremast finished.Not perfect but neither is the rest of the build.Had to make new mast caps as the kit ones were ugly plywood & didn`t show the metal bands holding the upper sections to the caps.The dowels for the masts are walnut so they are probably a little darker than they should be.Got some of Chuck`s blocks - super nice.
I have built this kit & it does make into a nice model.The biggest flaw is the lower gunport metal frames - they need to be set back farther than the plans indicate or the cannons will stick out too far.Plans & instructions are ok.
/Mark
Frank,
I juat took some semi-gloss black acrylic paint & thinned it about 5 to 1 with acrylic thinner & painted the cannons with it 5 or 6 times.It didn`t darken them all that much but it made the details stand out better.Seemed to give them a sort of antiqued look.Yours may already look similar.You might try experimenting with different ratios of thinner - if using acrylics you can always wash it off before it dries if you don`t like it.
Nice work. I believe the cannons were made of bronze so painting them pure black might be a little dark - just my opinion.I darkened mine with a thin black wash .You might try what Nigel suggested - blacken them & rub with a brass wire brush.
/Mark
Wasan 1628 by Nazgul - FINISHED - Billing Boats Vasa 1:75
Posted · Edited by marktiedens
Great looking ship.Now on to the rigging?
/Mark
