Everything posted by yvesvidal
Yes, I checked Shapeways and they are way overpriced for custom jobs. Even their parts for submarine kits at 1/48 scale are rather expensive, although beautifully made. I also looked into molding plastic parts. That is a whole new world for me and I am not sure I can do that with success. For the time being I am going to go with my own fabrication and try to disguise it in the best possible way. Maybe Joanna in China will respond one day.... Some progress on the rear compartment. This is how the kit is built: All the good stuff is hidden from view. Very poor design from Trumpeter. Then only one electric motor/generator is provided. That is the parts that are the most difficult to recreate. My implementation will be very approximate for a good reason. I have replicated the three ribs provided in the kit and placed the original parts in the front. The rear part are absolutely non visible, once the compartment is completed. The roof section was presenting a large opening, perfectly visible. It was necessary to remedy to it. Finally, the bulkhead with the electric motor stands and torpedo storage platform: We will see how to go from there. Yves
Yes, I have checked a lot of things on the Internet. It is not a common kit (due to its size and price) and thus the odds are not in my favor. I also have sent three E-mails to Joanna@trumpeter-parts.com with no answer so far. She must be vacationing in Paris or too busy to answer. So, I have decided to move along and fabricate the parts myself. It will not be as nice as the molded parts (far from that), but since they will be behind, it may be acceptable for the time being. If I ever find some spare sprues, I can always rework the rear module. Yves
Folks, I am afraid there won't be much updates for a while. I am debating how to build the rear electric motor compartment and wish to present both motors. Trumpeter really simplified this compartment with just one motor and very few other parts. I suspect that this was their last module and they probably had too much rice alcohol in their system, when designing it. They could have included both motors, both clutches and both shafts but decided to go cheap and not provide them. I am trying to obtain spare parts from Trumpeter and that is a major challenge. Some people have made it, most could not get anything. I have also contacted one person who built that same kit, without the interior and offered to purchase the internal parts. There, again, no response. I may have to fabricate the parts myself, but it will never reach the level of precision of the molded injected parts. So, I am revamping the compartment, to place in the front what would have been relegated to the back of the module (a la Trumpeter). If anyone has a lead to purchase sprues X, Y and V, please let me know. Ideally, and if I could afford it, it would be worth buying two kits, keeping some sprues and re-selling the rest for someone who wishes to build the external hull only. Decisions, decisions...... Yves
Another excerpts of the "Manual", explaining what are the five modes of the propulsion plant. The Support and Buffer mode is particularly interesting and very advanced in its behavior: Inter-operation of the engines and motors. a) General. The diesel engines provide a maximum surface speed of about 18 knots and both E-motors provide a submerged speed of 8 knots. The different working modes are listed below: Diesel engine only drive, E motors only drive, Support and buffer mode, Diesel-electric drive, Charging mode. Exhaust gas from both diesel engines can be diverted and used for blowing out the main ballast tanks and main ballast and reserve fuel oil tanks. b) Diesel engine only drive. In diesel engine only drive; both diesel engines drive the propellers via the diesel engine couplings, E motors, main couplings, thrust shafts and the propeller shafts. In this arrangement the E motors are just a part of the drive train and the armatures are un-powered. The fan blowers of the E motors rotate slowly powered by voltage generated due to the remanent magnetism of the un-powered rotating armature. c) E motors only. With E motor drive only, the diesel engine coupling is un-clutched. The E motors are powered by the battery and work as motors driving the propellers via the main couplings, thrust shafts and the propeller shafts. d) Support and buffer mode. In support mode, the output power of the diesel engines is increased by switching on the E motors additionally. Each diesel engine via the diesel engine coupling and in addition each E motor acting as a motor drives the propeller. The buffer mode is used in rough seas. The diesel engines drive the ship's propellers as in "Diesel engine only drive". The E motor voltage is adjusted such that with normal conditions the loading and discharge current are equal to zero. If the screw runs above the surface, thus causing unintentional reduction of load on the diesel engine, the E motor works as a generator preventing an inadmissible increase in diesel RPM. e) Diesel-electric drive. Diesel-electric drive allows driving both propellers even if one diesel engine has failed. The operational diesel engine works directly driving the propeller on its side. The E motor whose armature would normally run idle, works as a generator delivering power to the other ship side. The E motor on the other side drives the propeller; the diesel engine clutch is disengaged. The current from the primary E motor can either be switched in such a way that it only drives the secondary E motor or an additional light charge of the batteries takes place. f) Charging operation. Charging operations can be differentiated as follows: Charging with a disengaged propeller shaft, Charging while running on the surface with diesel engines. When charging with a disengaged propeller shaft, the diesel engine drives the E motor via the diesel engine clutch. The E motor runs as a generator and charges the storage batteries. When charging while on the surface with the diesel engines; the diesel engine power drives the propeller. At a constant number of revolutions from the diesel engine, the E motor charges the batteries. In this case, the diesel engine must provide power for the propeller and for charging. Yves
So, the next construction step will be addressing the rear compartment: Torpedo room and electric motors bay. I managed to find on the Internet, a translation of the original German Type VIIc manual that was provided with each submersible. This manual has nothing to do with what was published by the group of military scientists that captured the U-505 (Chicago Museum of technology) and reverse engineered it. It is the real deal that was given to every German commander to operate their vessel in the Atlantic. It is a mine of information and I will try to publish some excerpts as we move along the construction. The manual was written in German (of course) and has been translated in English by Maciek Florek. It refers to Submarines built in 1939 and thus corresponds to our model of the U-552. The following describes the Machinery and Propulsion Plant. You can see the main Diesel engine, followed by the primary clutch, the electric motor/generator, followed by a second clutch, main thrust bearing, stuffing box, shaft and propeller. Motorwelle Engine shaft Schwingungsdämpfer Flywheel Dieselmotor Diesel engine Dieselmotorkupplung Diesel engine clutch E-Machine welle E Motor shaft Schott 16-1/2 Bulkhead (frame 16-1/2) Maschine 2 Motor 2 E Maschine E motor Maschine 1 Motor 1 Hauptkupplung Main clutch Druckwelle Thrust shaft Hauptdrucklager Main thrust bearing Flanschenkupplung Flange coupling Schraubenwelle Propeller shaft Wellenbremse Shaft brake Stopfbuchse Stuffing box Druckörper Pressure hull Vorderes Stevenrohrlager Forward - Stern tube bearing Hinteres Stevenrohrlager Aft - Stern tube bearing Wellenbocklager Shaft strut bearing Schraube Propeller More details soon. Yves
A chaque jour suffit sa peine. Superbe. Yves
- 550 replies
- confederacy
- model shipways
Both "nipples" (that is the plumbing term) have been installed: I think this arrangement is providing for a safe and strong stand, for a heavy model: The menacing torpedo doors: As expected, the nipples will provide easy access to the underneath of the hull, to allow the display of all these beautiful PE parts: The heavy work on the hull mostly done, I can now move to the interesting part of populating the decks, with all the PE parts..... or perhaps the rear torpedo room and electrical motors. Yves
After long hours spent thinking about the best way to present this model, I decided to go to my local hardware store to see what I could find. The Trumpeter stands are not bad but come short for a more elegant presentation. They are perfect to hold the two halves of hull together and provide a nice stand to work on the model, during its construction. The keel locks in place and the support is very sturdy. However, I wanted something more unique and that would provide the onlooker, a chance to see the underneath of the machine. So, I decided to get two 6 inches long piece of brass tubing, which would allow me to pass the electrical wires into the base. The brass nuts are fitting tightly, after carving some of the plastic away, and the anchoring is secured with two components epoxy glue. Only the main hull will be supported, the other half locking into place in the stern and the multiple magnets. The result seems to be strong and sturdy and will be perfect once I get the second anchors in place. I expect the model to weight close to 10 pounds once finished: I am glad that this decision and implementation is almost behind me. That was not too easy. The Trumpeter stands can be used during the construction. Now, I need to find a nice board to present the whole enchilada..... Suggestions are welcome. That stuff will have to be close to 5 feet long and house the wires and a couple of contacts. Yves
A few little progress. Fine tuning of the torpedo doors and time consuming details. I found an old can of primer Plasti-Kote TR-253, in light gray. This stuff is fantastic and I remember using it years ago on brass. It covers very well, remains supple, is easy to feather and sand delightfully. Yes, the Vallejo is okay for plastic, but I had to peel it on all my brass PE parts before applying the TR-253. The primer is very matte, lacquer based and will likely accept acrylic Tamiya paints with eagerness. What a difference: The main hull is pretty much ready. The link between main hull and stern is almost invisible: Some primer was over-sprayed on the deck. It really sticks. All the details of the stern, propeller shafts and PE parts have been sprayed. It looks harmonious and ready for painting: So, the next problem is finding another can of that product. The new packaging with the high-tech nozzle does NOT work. There are many people complaining on the internet about the new stuff, and I need to find the old style can. Why do they have to change a working recipe? Yves
I like the contrast between the very rough stand and the perfection of this model. Yves
- 306 replies
- schooner
- la jacinthe
You are going strong and radical. No coming back. It reminds me of the butchering of my U-552. Yves
I worked on the torpedoes doors. Not an easy task. Keep in mind that a few parts have to be fabricated as nothing is provided in the kit by Trumpeter. Once again, the PEs from RCSUBS bring a nice addition to that delicate part of the Type VIIc submersible: Using brass rods, I fabricated 4 commands to link the door mechanisms to the front bulkhead: Once painted: Yves
Very nice and so unusual model. Another masterpiece for your collection. Yves
- 345 replies
- graf zeppelin
- trumpeter
Wow, you are moving along!! This model will be finished before you know it. Yves
- 550 replies
- confederacy
- model shipways
I just received a parcel from Oto (RCSUBS). Shipping goes fast, less than a week. This contains the rear bulkhead for the pressure hull, the torpedo doors set and some brass to finish the model and its stand (in some remote future): And the associated instructions to assemble the doors: More work in perspective.... Yves
So, no checker-board floor in the officer cabin? Yves
- 550 replies
- confederacy
- model shipways
I have to say that this PE deck from RCSUBS, changes the model considerably. It brings a different flavor to this huge model, by shifting the dominance of plastic to metal and turning a simple (although big) plastic model into something a lot more valuable and unique. Despite the enormous amount of work to properly install this PE set, I just cannot imagine having that beautiful submersible with the simple and so grossly molded plastic deck, provided by Trumpeter. I see a lot of very beautiful models of that kit on the Web, but very few people takes the energy and time to install this specific PE set. In my humble opinion, it is today the best PE set one can find for the Trumpeter kit. I am always pleased with the precision and accuracy of the different parts and how they fit together. Now another question for the PE experts: I noticed that the Vallejo Primer tends to flake and peel on the brass parts, when you lightly sand it. I wonder if the Tamiya primer may work better or if I should go with an automotive primer. Any suggestions? Also, what kind of stands do you guys use to present such a model? Where do you find the brass or other metal parts used to display our models ? And NO, I am not going to use the ugly plastic stands provided by the Trumpeter. Yves
Et voila! All PE decks have been glued with epoxy: This reinforces the "laced" plastic deck considerably. And our typical claustrophobic pictures: I should get some ordered PEs from Czech Republic tomorrow and it will allow me to resume the work on the front torpedo doors. I also need to think about how I will present the model and design the anchoring points for the stands. Yves
This is a fabulous work of planking for a beginner. I would not even do a second planking as the model looks so much like those real fishing boats that you can see on the southern coasts of France and Spain. The real boats are beat up of intense usage and your model is just perfect as it looks. Finish it, some nice weathering and you will have a fabulous piece to show in your home. Yves
This is incredible. It is exactly like being on a real boat. How do you make it so perfect ? The patina, the color of the woods, all the details are there. I hope your models end up in Museums where generations of people can enjoy watching them. Yves
- 306 replies
- schooner
- la jacinthe
