yvesvidal
Everything posted by yvesvidal
  1. Congratulations on the progress. You may actually end up finishing it in time....😊 Yves
  2. Superb work. Now, don't take this as a criticism as it is more of a pet peeve for me, but is there any way you could fix the gap between the bridge walls and the wood planking on the deck? I know that sometimes, the fitting is not perfect and perhaps you have not glued the bridge to the deck yet. Your model is so beautiful, I would hate to see those big gaps. Yves
  3. Jack, We are all so pleased to see you coming back. Ciao, Yves
  4. The construction continues, unabated. Details of the cabin: The coupler works with a rubber band to keep it closed. A small ladder extends from under the chassis to allow access to the engine cabin. Now, look at the precision and ingenuity of this roof: A piece of flat plywood laser cut in such a way that it can be bent and rolled like the rook of a steam engine: Quite incredible. The fitting is perfect: Yves
  5. What a beautiful model. Truly, a source of inspiration. Yves
  6. We area at a point, where this assembly starts looking like a steam engine: The crown of the boiler is very well rendered with no less than 21 wood parts. It is now time to try if all the gears are working. Wax helps a lot in that case and you have to be generous with it on these mechanical parts. I got to a point where, all the gears located inside the boiler are spinning with the rubber engine. This was done with the lever in Neutral position. In forward position, the rear main drivers are also turning well and freely. It is a good sign for what is to come. I love this kind of little details: The fire box can be closed or opened with that lever to the right. Very cute and astute. We even have a shovel for the coal. It is going to be an impressive engine when finished. I wonder what the scale is? Probably Scale 1 or 1/32nd. Yves
  7. The engine is almost mechanically completed. I installed the drivers after quartering them (not too difficult on this kind of assembly). That will hopefully allow the rods to work smoothly. Lots of additional gears and belts.... I am not too sure what they will be for yet: And a close up on the steam engine...sorry the rubber engine: Yves
  8. Very nice set of Citroen Traction Avant 15CV. My brother (who lives in France) owns a fully restored 15CV (like your left side model) and a more modern 11CV with the larger trunk. Great cars to drive and use for back roads trips. Yves
  9. The main engine is starting to come together: Thanks to the lever, you can reverse the direction of the locomotive: Very ingenious.... Yves
  10. Some major progress: We are now assembling the axles for the wheels and all the gears that will be used to move the main drivers of the locomotive: I kept being amazed by the quality of the fittings. For instance, parts that are supposed to insert into another one, have this delicate middle (or triple) laser cut that basically creates a spring effect, making sure that the axle will fit into the wheels, tightly. These Ukrainian engineers are quite wizards in that domain, and I am in awe in front of the engineering that goes into these kits. Yves
  11. There is an excellent book by Bob Ballard that depicts the wreck of the Bismarck. There are a lot of underwater pictures too. Yves
  12. I am sure, she would prefer that you start the Trumpeter kit in 1/200 scale, instead of these old Revel kits..... 😉 Yves
  13. A little progress..... lots of gears and levers..... for now: At this stage, it is essential to grease/wax all the gears and make sure that everything runs freely. Yves
  14. I built the old Matchbox kit in 1/72, when I was 19 years old.....40 years ago. It was great kit, although full of inaccuracies. I think I may get it again, with the Revel Platinum version. I will be following your 1/144 version with a lot of interest. Yves
  15. Well, if the Theatre took you just an afternoon, this locomotive is another story. I started assembling the kit, by following the instructions very closely. I have to say, their instructions booklet is a little marvel of precision and explanations. It is like a Lego kit or an IKEA kit: all is done with drawings and icons to guide you. The quality of the cuts is amazing. I had no idea such precision could be attained with a laser and plywood. When I compare these cuts and what some model ship kits are offering, it is like night and day. Those Ukrainians have really done their homework and their products are near perfect. So, we go..... We have no less than 16 rubber bands and that assembly is very tight. All the parts are locked with tooth picks. No glue. The fitting is perfect, just tight, very well designed. Now, the insanity starts: A roller bearing made of wood..... The parts are lubricated with some excellent Wax, that I use for the playfields of my pinball machines. At 78 Degrees, the wax is almost liquid and lubes the wood very well. And this is where we are: the engine of the steam locomotive is almost completed. Overall, this does not start as an easy kit. I suspect that the most delicate phase is the implementation of the rubber engine, with its levers, locks and clicking mechanism. We will see how it goes in the next phases. Yves
  16. Petite Manche en toile de la pissotiere: Basically" Small tube of fabric, used to pee". A "Pissotiere" in French (slang) is a device or a place to urinate. Was that for the mates or to eliminate any water that may have flushed the inside decks? I let you decide. Yves
  17. I admire your persistence at trying to get a decent model out of these old Revell kits. Yves
  18. Absolutely beautiful!!! Your BLOG will be my reference when I decide to build the kit I have. Yves
  19. My son Michael recently offered me for Father's day, a new product that he got from Ukraine. It is all made of wood, laser cut and uses rubber band for a propulsion system. It took a long time for this kit to arrive in the good old states of America and the custom office kept it for a quite a while. I suspect they wanted to assemble the kit but did not find the time or patience to do so. Anyway, it looks like some of the products offered by uGears (Ukrainian company) are now imported by Model Shipways, which should hopefully ease the transit through our customs bureaucracy. I have not started the kit yet, but intend to do so, as soon as I am done with the restoration of a Bally Mata hari pinball machine. In the meantime, I wanted to show you in pictures, what this is all about. The offering from uGears is quite impressive with tons of models for different tastes. Most kits are capable of moving or have some kind of mechanical system built in. My son picked that beautiful locomotive as he knows my very intense passion for trains, and specifically for steam engines. The quality of the cut is amazing and extremely precise. All kits are assembled with absolutely no glue and use wax (from a candle) for lubrication of the mechanisms and gears. It is truly a kit taking you back in the old times, when creativity and resourcefulness were the necessary qualities of hobbyists and do-it-yourselfers and when materials were simple and had to be found at home. From an environmental point of view, this is a kit that is perfect, uses renewable materials (wood, rubber), no chemicals and will last a long time if taken care of. The instructions is comprised of a very thick manual, explaining the various phases of assembly. All is very precise, and tells you exactly where to find the parts on the various sprues/plates of wood. Stay tuned as we will be starting the construction in a few days or a couple of weeks. Thank you Michael, for this beautiful gift. Yves
  20. Anthony, I hope you will be documenting your large Mayflower build on this forum. Yves
