Everything posted by SaltyScot
BR-18 Locomotive by Greg Davis - OcCre - 1/32
SaltyScot replied to Greg Davis's topic in Non-ship/categorised builds
That brass work looks so nice in the background there, Greg. I am enjoying seeing this come together. -
I know there is some substance in the fact that the English found the American vessels to be a bit "top heavy" for European waters. Maybe that had something to do with it anf they changed the rake?
- 257 replies
Joachim, Chapelle's book is a great help to me right now for the Lynx build. I got the Marquardt book from the library and am slowly going through it. It has some great information on masts and rigging at the back of the book and several chapters on variuous types of schooners. I am still trying to decide if I want to buy it for myself or not. We will see. Danke, das Du reingeschaut hast.
Dang, that sucks, Vossie. Here's hoping those few weeks fly by and you are back at the table soon and good as new!
- 714 replies
- lady nelson
- victory models
You could offer me that for free and I wouldn't drink it, too acidic for my taste. I had a good friend from Glasgow who swore by the stuff. For me it smells and tastes like a "cure all" medicine my dear old departed mother used to spoon into us whenever we got sick
- 167 replies
- Norwegian Sailing Pram
- Model Shipways
I am beginning to see how this will come together, Trevor.
- 167 replies
- Model Shipways
I decided to measure the mast rake. I was surprised to see from the Musquidobit plans taken from Chapelle's book that the angles were different. I measured using a horizontal line drawn beneath the foot of the masts and a center line going through the middle of the masts: By my reckoning (and please correct me if I am wrong here), the fore mast has an angle of 14 degrees and the main mast 11 degrees. Is it normal for a schooner to have different angles? (Newbie question).
- 257 replies
Now there's a man after me own heart. What is your particular poison? This one is mine (also sadly just about empty )
- 167 replies
- Model Shipways
When I started and was planning to build the Endeavour, that is what I put in the search box "Endeavour". That way, anything related to that name popped up and I could select the build logs that were appropriate at leisure.
- 47 replies
- La Nina
- Artesania Latina
I am glad to see you back at it, Greg. I am going to hop on board and follow along with this as well, sir. -
I totally agree with Bob here, don't get bogged down and frustrated, reach out to those here who are ALWAYS willing to help a newbie (I am quite new myself). What he said about looking into other blogs is also important. Find other builds of your model on here (use the search option top right on the homepage) and read through them. That way, you can perhaps find mistakes that were made or tips that the other builders dropped in to help out at a certain point. These are true words. I found my first build to be a very steep learning curve but it was also very enjoyable. Stick to it and, no matter how it goes, you will be proud of what you turn out which will then inspire and motivate you for your second build. Good luck!!
- 47 replies
- La Nina
- Artesania Latina
Well here's hoping you got a good nights sleep, Trevor.
- 167 replies
- Model Shipways
Builds like this inspire me. I am a lot slower keeping up with the maritime vernacular, me being a newbie and all, but some of it is beginning to become familiar
- 332 replies
- Harpy
- Vanguard Models
Should be done by, hmmmm let's say, Christmas, Glenn? 🤣 🤣
- 241 replies
- Vanguarrd Models
- Harpy
I am an advocate for that, Glen. I fully intend to enhance my next build, the Endurance, with 3D printed parts!
- 301 replies
- Constitution
- Bluejacket Shipcrafters
Friday March 7th A productive day in the shipyard today. I fixed the issue with bulkhead #11 first making sure it sat nice and square on the dry fitting: It will be glued into place later once the rabbet is done, that’s next up. I got a good line for the rabbet using a planking strip from another build and the dry fitted bulkheads: Once I had marked my line I chiseled and sanded in the rabbet: I did a test dry fit of the lower deck into bulkhead #2 before going any further. Some adjustment was needed. It was an easy fix: There is a piece that sits on the nose of the lower deck. The piece itself has a slot in it but there is no slot or any reason for one being there in the plans: Because I will be covering the lower deck, I filled in the slot to prep it for planking. I also dry fitted the transom (that will need shortening by 10 mm to comply with the correct length of the vessel: Now I was ready to start glueing the bulkheads in place. I started at the stern and, after placement, made sure each bulkhead was nice and square: With them all in place and dry I then dry fitted the lower deck to check the fit: She looks pretty square to me.
- 257 replies
Langsam aber sicher nicht war, Wolle? We know it is not a race to the finish line, don't we
- 35 replies
- Britannia
- Mountfleet Models
Wow, that is a LOT of prep work and execution for that one piece, Trevor. That being said, it is a key piece in the build (at least that is what I gleaned from reading through your text here) and messing it up would naturally have a negative effect on what follows. Thank you for this. Funnily enough, as soon as I saw the word "pram" yesterday, my mind went back to the big boxy "pram" my brother and I (we are twins) were carted around in as toddlers (our mum took a lot of pictures and kept them for years). Looks like I wasn't far off after all
- 167 replies
- Model Shipways
Herzlich Willkommen, Joachim. Glad to have you aboard, sir. If you have any questions AT ALL about this fine hobby, there are plenty of resources and good folk here to help you answer them.
Glenn, I truly wish you both all the very best in this and a speedy recovery back to healthy normality for your good lady sir.
- 241 replies
- Vanguarrd Models
- Harpy
