Sjors
About Sjors
  • Birthday 06/29/1956
  • Gender
  • Location
    Bleiswijk, Netherlands
  • Interests
    Fishing, traveling, reading, photography and meeting new places and people….
8,276 profile views
  1. Thanks Mustafa. That helps a lot. Holliday’s are over for you? Sjors
  2. Because i'm waiting for copper plates ( Kevin has send it to me ) i was looking at the Conny again. There is one thing that I need some help with. All the measurements are in inches and I try to convert them into mm or cm but I get strange measurements So my question for you are: How much is 1/18 inch = mm or cm? 1/16 inch = mm or cm? 1/32 inch = mm or cm ? 3/16 inch = mm or cm ? 3/32 inch = mm or cm ? I know there are rulers with cm and inches and I have one but if you don't understand how it works you can seek till 2050 🙂 I know someone will help me. Thanks in advance. Sjors
  3. Congratulations Robert. It’s a real beauty and you can be proud of what you have done. A great example for me. Difficult for me to get close of what you have done! Sjors
  4. That goes quicker then the Conny 🙂 It’s a nice little one. I will be follow you 😀 Sjors
  5. Hi Tom, I have take a look at all the build logs. But a lot of builders are away after the beginning. Maybe to difficult? I also had all ready problems en re do a lot. But that’s building. The drawings are more difficult then OcCre or Caldecraft. And the measurements are in inches and not cm. But with the help of other builders i can manage it all. But for this month the Victory and September back to Conny. Sjors
  6. It was just a joke Peter. And I only have one each month. This month the Victory and next month the Conny. The Duyfken stays on hold. Sjors
  7. Sometimes you have to do something else otherwise you gonna get crazy 🙂 So I paint the sternfacia. And now i can go on with the copper plates..... Sjors
  8. Congratulations! It’s a real beauty and you can be proud of it! Sjors
  9. How an 18th Century Sailing Battleship works I thought I'd share this one. Beautiful 3D animation and explanation of how the whole ship is built and how everything works.
  10. I have seen it Peter. But the bow is closed and the top gun ports are in it. Next thing are the lower gun ports but i’ll becwaiting for you 😀 So i’ll be back with the Victory. Glue copper plates. Every month i’ll be doing something else. Next month the Duyfken and then the Conny. So hurry up and i can see what i have to do 😁 Sjors
  11. Hoi Peter, I have take a look again but i don't have that parts in my kit. I was looking that earlier but can not found it so i thought i have to make it by myself. And yes, i'm building straight out of the kit. Maybe there is still one sheet of wood in Norway so I have to ask to see. If there is I will not remove everything for that. It is as it is. Sjors
  12. Then i’m on holliday to 😄😄(not) Enjoy your vacation. Where do you go to? Sjors
  13. Finf your build 😀. I have a little problem with the kit and you build it from scratch…… I will go on at the follow stand. You are a little behind me so i will be slow down so i can see what to do. Sjors
  14. Thanks Mustafa, I can only find” on sheet 6 that at the left bottom you can find the measurements of the mizzen,main and fore mast.” But no bowsprit. Now i have one ,i can search better to see if it’s there. Thanks again. Sjors
