Everything posted by Jim Lad
Nicely done, Ollie - your square drill obviously worked a treat! John
- 803 replies
- colonial cutter
- modellers shipyard
Just catching up, Toni! Thanks for your update of more delightful joinery work. John
- 1,449 replies
Not what one would usually expect for gun ports, Popeye! Logically, with the ports open there must be a small coil of rope - as you say, on deck if it doesn't show in that photo. With the ports closed, there may well have been just enough rope to make to make fast on the cleat (no point in wasting expensive rope). John
Good progress, Andy. Are stern anchors ever actually used in the lakes? I was on one ship that had a stern anchor, but it only left its hawse pipe to run the cable out for survey in dry dock. John
- 382 replies
- stadacona
- sylvan scale models
That Blackbean looks a nice timber, Ollie. John
- 803 replies
- colonial cutter
Ollie, Go to the National Maritime Museum website (the Pommy NMM); go to 'collections' and search on 'windlass'. You'll find several photos of windlass models including a few early ones - all the ones you want are on the first couple of pages. As for the square holes, use a square drill, of course! I drill a small hole and then square the hole out with the tip of a very small square escapement file I have. In case of a lack of square files small enough, try filing down a small length of steel to a square point; drill the hole; then ease the hole out to square by pushing the squared steel spike into it. Try on a piece of scrap of the same type of wood first just to check that it works OK. John
- 803 replies
- colonial cutter
Ollie, I think your windlass would be more likely to look like this one from a contemporary model of the 'Harriet' in the National Maritime Museum at Greenwich, with the holes for handspikes to operate it, although from King's sketch of the 'Mermaid', it would appear that her windlass had the crossbar as well. Also note that in that photo you posted the port anchor cable is incorrect - the cable should lead over the windlass drum and not under it as shown so that heaving on the handspikes from behind the windlass will heave the cable in. John
- 803 replies
- colonial cutter
SS Vinal Haven by TBlack - FINISHED
Jim Lad replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
That certainly looks the goods, Tom! John- 326 replies
- vinal haven
- steam ship
The keel and stem make a huge difference, Ollie! John
- 803 replies
- colonial cutter
Just gets better and better, Piet. I can't wait to see the conning tower taking shape! John
Just send me the tickets and I'll be there, Andy! John
- 382 replies
- stadacona
Tom (and Andy) - sailors swear, but officers use occasional expletives! I can see I'm going to learn a lot about North American shipping by the time this build is completed. John
- 382 replies
- stadacona
