Jim Lad
Moderators
Everything posted by Jim Lad
  1. Yes, Ollie, the lower decks would be the same material and finish as the weather deck. John
  2. Spencer, Sorry I was a bit obtuse. QA's explanation of my confusion is correct. The photo below might show you what I mean. It shows my Stag with the deck planking part completed. The red arrow is pointing to the margin plank (the edging). The green arrow shows joggled planks (the planks with the shaped ends) fitted into the margin. The purple arrow simply points to the uncut or shaped portion of the margin plank outside the planking currently fitted. The next plank to go on will have its end shaped and then the margin will be marked using the shaped plank end as a template and then cut to fit the shaped plank end. The trick with this method is to make sure you have a REALLY sharp blade to cut out the margin so that you don't get any torn edges. You can get a larger view simply by clicking your mouse on the photo. John
  3. Brian, Here in Oz you could also try Privet (light colour like Box) or Cherry Ballart - if you can find some and mill it yourself. They're both beautiful timbers to work with. John
  4. Nice to see the Vespucci back in the dockyard, Lars! John
  5. That's a nice overall view of the model, Remco. How do you keep your work area so neat and tidy? John
  6. All small boats would have been painted or varnished (or perhaps tarred if they were small working boats) to preserve them. John
  7. Ollie, It would be usual to step over the coaming and straight onto the ladder. John
  8. Hey! She's coming along nicely, Popeye. You'll be rigging by next week! John
  9. Just catching up with what you're up to, Ollie. She's looking good so far - and, yes, that rectangular opening in the deck is exactly right - it should be the size of the companion over it if it isn't already! John
  10. Thanks, Ron. It may be a little while before she gets a final case as she's currently still in the model makers' case at the museum. John
  11. It's nice to see the first frames erected, Ed - even if only temporarily! John
  12. 11 1/2 inch topgallant backstays? Are you sure that source is reliable, Bruce? John
  13. Looks like this is going to be an interesting project. Think I'll just pull up a chair and watch! John
  14. Bruce, You're building at 1:96 aren't you? Should be able to find ready made threads at that scale (maybe)! John
  15. If it was a fully rigged ship of the line at that scale, Michael, you'd have to build a new house to put it in! John
  16. Denis, I'm sorry but I somehow missed your post back on the 3rd. Oldboy is quite right - all the gear is attached to the furled sail. It can then be set quite simply at any time. John
  17. Bruce, Shrouds were usually, but not exclusively left handed in older ships - it was simply a matter of smaller, right handed rope being laid up again to make a much larger rope. Of course shroud laid rope is four strands laid up right handed around a core. It was often used for standing rigging as it was less liable to stretching. Also remember that wire rope was in use on some ships by the mid 1850's for standing rigging, and that was (and is) almost exclusively right handed. John
  18. The boats have come out well, Mobbsie. Have you thought yet about how you're going to stow them all? John
  19. Well done on the new method of making blocks, Michael. As you've now reached this stage of detail, I assume we're free to criticise if we see any screw, bolt or nail not faithfully represented on your cutter! John
  20. I always lay the margin plank first. As the planking goes forward, I cut the joggling into the end of the plank and lay this over the margin plank and mark the shape of the joggled end with a sharp pencil on the margin plank. The margin plank can then be cut with a very sharp blade to take the end of the plank. John
  21. Crikey, mate, life's all go in Lake Wabumun, isn't it? John
  22. Crikey, Ed! I can cope with milling the frames to the correct siding, but doing it on the sander looks pretty scary. Do you have a stiff drink before or after the sanding? John
