captainbob
Gone, but not forgotten
Everything posted by captainbob
  1. Michael, Do you do the drawings for all the small parts or are they provided with the plans? Bob
  2. The Littlemachine X-Y table looks great and has oil catch tray which the Proxxon does not have. But watch out for those dimensions. I once bought an X – Y table that had a vice on top that you could angle upwards only to find out it was too big for my drill press. Bob
  3. Thanks to all for the comments on the boat and birthday wishes. It was a great day. Bob
  4. Martin, It all depends on what you want to do with a “mill”. If you want to be able to cut slots or shapes, then save up your money and get a good mill. If, on the other hand, you just need to drill holes in a straight line or drill one hole a precise distance from another, then the dermal stand with an x – y table, like I have, works very well. So you have to decide what you need not what you want. I've wasted lots of money buying what I wanted because it wasn't needed. Bob
  5. Toly, Those stoves are simply amazing. Bob
  6. Hi Walt, Sorry to hear of your problem, but as Michael said it seems that you have it sorted out now. Bob
  7. Sherry. Just found your build. Your framing looks good, it's not easy working at 1:96. Nice to have another scratch builder aboard. Bob
  8. Russ, Michael, Popeye, Thanks for stopping by and the good words. The square of wood on the seat is a cutting board. With the knife, (brown handle to right of the cutting board) the fisherman would cut up the mackerel for bait. Bob
  9. Danny, I've never sharpened mine. I use it for wire not wood but the sand paper sounds good. As you said the holes would all enlarge the same. Maybe someone should ask Byrnes. Bob
  10. Thanks to everyone who has been watching this build. I sorry it’s been so long since the last entry. I’m going to call this one done for now. I hope to do something else and use this dory then but for now this is it. The gear shown is: a Line bucket, a bait bucket, a lunch bucket, oars, a club, a bailing scoop, a cutting board and knife, on the thwart and a coil of rope. There is a divider about in the middle of the boat. The fisherman is in the bow with all the gear and he loads the fish into the other end. You will notice there is no sail. Use of a sail was up to the fisherman. The way I heard it stated is. The schooner is the dormitory and kitchen but the dory is the fisherman’s home, (he in it about 12 hours a day) and he modifies it to his liking. Here are the pictures for now. The admiral saw a picture of a sweet little gaff rigged yawl and said “That would be a nice model”, and what the admiral wants. . . Bob
  11. For larger work, get a square fan and attach a furnace filter in front of it, so the air goes through the filter before the fan. The over spray is drawn to the fan and sticks to the filter. I’ve seen this used successfully in a kitchen. Bob
  12. A drawplate is a jeweler’s tool that has been adopted by some model makers. It is used to reduce the size of wire. First the wire is annealed and tapered on the end. It is then put into the large end of a hole and pulled through this is repeated until the wire is squeezed to the proper size. My jeweler’s plate does not have a sharp edge at the holes because in sizing wire it is not necessary. In dowel sizing you pull through from the small side of the tapered hole and shave the wood. This can only be done if the edge of the hole is sharp. And like all cutting tools it needs to be kept sharp. Bob
  13. Rebecca, Just found your build log. It’s coming along nicely. Minwax has stain sticks, similar to magic markers, in many colors for covering scratches on furniture. I use them frequently on my boats. Bob
  14. Rebecca, Because paddlewheel boats had steam power most capstans were powered by a small steam engine below decks under the capstan. The capstan was used for many things, from the grasshopper td get them off of a sandbar to cranes to lift things onto the boat to . . . you get the idea so the rope would go to whatever the need was. Bob
  15. You must read the whole set. The part I like best is: Flying is not hard. It is simply a matter of throwing yourself at the ground and missing. Bob
  16. Michael, I like your new saw. I have a saw like your old one and am tempted to make a new one like yours. But I can’t figure out how you hold the end of the blade without the thumb screw clamp. Help please. Bob
  17. I found this on the web a couple years ago. Be sure to test it first. Bob Tannic acid does not produce a blue black color - that is a combination of tannic and ferrous acetate. Ferrous sulfate I have being toying with either painting or staining the oar because I didn't care for the finish. Then I saw a pin titled "how to make new wood look old" from Frugal Farm House Design blog and I thought I'd give that a try. She gives an awesome step by step with photos to see it go here. I will just tell ya the basics. Step one: take some steel wool and put in a jar and cover with vinegar. Let it sit at least 24 hours, the longer the better. (I expected the vinegar mixture to turn black or something but it didn't.) after 24 hours Step two: make a strong cup of tea. I used Chai. brush the tea on the wood and let dry. Step three: brush on the vinegar mixture. The before pic above is after the tea was brushed on & it was still wet. I expected it to happen instantly and it didn't. I walked away and came back an hour later and it had worked.
  18. Popeye, If you were to go “normal” the joy would be gone and I might as well put on my bathrobe and hop the next passing spaceship. Bob
