Everything posted by wefalck
So the fore-mast sits in a kind of tabernacle ? How is it going to be locked against the 'baulk' ? Did you pin the cleats to the bearer ? Nice job overall !
When there is a deck-load of (sawn) wood, the shrouds would also be points to secure the load. On such quite small boats they probably would not have transported the kind of long logs and planks that came from Sweden and Finland on old barks, brigs and schoners to ports in Germany, the Netherlands, the British Islands and other European ports.
We probably don't know what the practice was at the end of the 17th century. On small scales I used a cow hitch as surrogate for the sewed-on eye-splice. Looking at your threads, I think it would be quite feasible to make a fake eye-splice and sew this on with a couple of turns of fly-tying thread.
Another Rigging Clarification Needed - Lifts
wefalck replied to BANYAN's topic in Masting, rigging and sails
I think John is right. The lower yards would not normally be raised and lowered, unlike the upper yards, where both, lifts and falls may be needed to move the heavy yards up and down. -
I didn't realise that the chocks are wood. So, yes, you would have to have something metal and if its turning it doesn't have to be so heavy.
Yes, that could be. Some kind of glutin glue kept from gelling by adding salt. Or it could be a thick shellac solution, one with lots of shellac and little alcohol.
Every organic solvent has a smell and some of them smell quite nicely (no, I am not a 'sniffer' ...). It depends on how big the area is to which you apply the glue. The main point is, whether the glue does the job. And: traditional hide glue does not necessarily smell very nice either.
That could be. In Germany the classical polychloroprene glue is Pattex and in my youth it was sold in tins. However, it was much for 'stringy' thatn the stuff in the video.
Paint or blackening
wefalck replied to Bill Hill's topic in Painting, finishing and weathering products and techniques
As always, the answer to the original question depends on what kind of model you are thinking of (and on the scale): for a model that shows off your artesanal skills, blackening is probably the way to go, while for a model that depicts the real life appearance of the prototype, painting may be more apropriate, as this is what would have been done in real life. I agree with 'grsjax', that blackening provides a better key for paints, particularly also acrylics, than the bare brass or copper. And: if the paint chips during subsequent handling, this will not be so visible. -
Keith, how is the attachment lock into the T-slot of cross-slide ? I don't seem to see any screw that pulls the fixed part down onto the table, against the T-nuts.
Ah, someone else, who got out the ball-turning attachment. Will be showing some results in my log soon. Would you mind showing your attachment to satisfy my curiosity ? Very nice anchors, indeed ! Will they stay in brass, or will you blacken them ? If the prototypes were galvanised, chemically tinning would also be an option.
Harriet McGregor by Boccherini
wefalck replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Just discovered this log - beautiful wood- and metal-work indeed. Will keep following further progress ! -
Matching paints from different manufacturers really will be hit and miss. Not only will pigments be different, but as binders and solvents will be different, their levels of sheen will also vary. I think really the best strategy is one you already used, namely to decant a bit from the spray-can into a container. If you can find one with a tighly closing lid, then you may be able to store it for weeks or months, making the procedure less wasteful.
- 4 replies
- Flirt
- plasti-kote
Well, I am actually an expat from Germany, but my wife is French On a ship like that the helmsman would standing besides the tiller, not in front of it, as you may do on small sailing boat, in order to be able to steady the tiller with the whole body weight. So I would think that the tiller should be a tad longer than drawin on the plans, but not so long that it would touch the bulwark, when put over hard.
I think we had this topic somewhere else before ... Anyway, there are extremely fine silk fabrics for silk-screen printing. I gather one can get them in art-supply stores, but also in the famous bay. Haven't tried them myself yet, but I believe this was the main use of the fabrics also used for covering model aircraft.
Also did some googling and realised that my chemical/mineralogical knowledge crossed with what are marketed products. Today, TiO2 pigment is produced mainly from a mineral called rutile, which apart from being crystalline TiO2 can contain significant amounts of iron oxide. The iron oxide is removed by an acid leaching process, depending on how effective this process is, traces may remain, giving the pigment a slightly yellowish stain. It appears that some artists like this pale beige colour and it is marketed as such, as 'unbleached' TiO2. The purification process has actually nothing to do with 'bleaching', which is an oxidation process.
This wanders a bit off-topic, but I wonder what is meant by 'bleached' vs. 'unbleached' titanium ? Titanium oxide (TiO2) is one of the whitest pigments that we have. Also, due to the production process it is very pure and then very stable as a chemical compound. So, I wonder, how it can be bleached.
Hide glue is normally used warm, isn’t it ?
In the video below on the assembly of SHIPYARD laser-cut blocks the guy uses a liquid, honey-like glue, that seems to set quite rapidly. What kind of glue may this be ? Wrote to the guys a week ago, but no response yet ...
As I am currently working in 1/160 scale and struggling to produce blocks, I gather I know what I am talking about: you have two issues to tackle here, namely - you need sources on both ships that provide you with the necessary rigging information, such as LONGRIDGE, C.N. (1933): The Cutty Sark.- 440 p., Kings Langley/Herts. (Model and Allied Publications, reprint 1975). MARQUARDT, K.H. (1995): Captain Cook’s Endeavour.- Anatomy of the Ship Series: 136 p., London/Annapolis MD (Conway Maritime Press/United States Naval Institute Press, Annapolis). - you need to find a way to manufacture the hardware in quite large quantities. McCaffery, quoted by Allan above, works in really small scales, perhaps half the size of your scale and uses wire for the standing as well as the running rigging. He essentially simulates blocks and dead-eyes with paper discs. For blocks he uses oval punches he makes himself. I am currently experimenting with laser-cut paper, but these experiments have not yet had the desired results. Building up the blocks with styrene sheet the way other people build up them up with layers of wood strips could be an option at such small scale. Styrene has the advantage of not having any grain and texture that would make small pieces fragile and be out of scale.
