Everything posted by wefalck
For a change, I caught one of your logs at the beginning, well sort of, as it has already progressed quite a bit. Looking forward to further instalments ...
- 15 replies
- fishing boat
- small boat
I tend to look not too often into 20th or let alone 21th century subjects, I must admit, so I had missed the build log so far and hence missed to the opportunity to comment. As to the curved separation line between bottom paint and the hull paint: there may be also a bit of tradition into it, not only the already counteraction of the optical illusion of sagging ends, when compared to the upsweeping bow and stern; it can make the ship look going faster than it actually does, giving the illusion of dynamism; in the old days wooden ships often developped what is called 'hogging', meaning the ships' ends actually sagged because of les buoyancy there, painting a raising waterline covered this fault visually to some extent. Concerning the use of wire for rigging: modellers of scale WWI air-craft are catered for by a variety of hard-ware by the model industry, perhaps one could find something interesting there, but I am not familiar with suppliers. Otherwise, this is an interesting and well-executed project of a somewhat unusual subject. I really wonder how those passengers in wheel-chairs cope with a heeling vessel and it rolling and pitching.
Geometric precision in the execution shows the master !
Watched the quoted above video by P Budzik last night and think there is an idea worthwhile trying out: scribing only through a layer of paint to reveal another layer beneath. This is essentially what is know in art as sgraffito (see https://en.wikipedia.org/wiki/Sgraffito). As the covering paint layers will be very thin one doesn't need to worry about creating out-of-scale furrows, such as those moulded into kits or that the laser-engraved wood decks seem to have. It has the potential to create very thin lines that would be to scale in small scales. The art will be to not scribe through to the underlying material. This would probably require a quit thick black/brown under-paint and the paint should be quite hard. I think I will give this a try, when I am getting to the only wood deck on my current project, though I already lightly engraved (using an engravers' graver) the bakelite sheet from which this decking will be made.
Ooops, thinks are going mad in Western Europe. We have been in voluntary semi-confinement as much as possible since the February, knock on wood ... good luck and speedy recovery !
CA will bond planks humid from steaming immediately. After all, CA was originally developed for battlefield paramedics to close wounds rapidly without the need for stiching and is used for the same purpose in civilian context too - guess how I know I was told about 'breathing on joints' by my father, who was a biochemist working inter alia on the application of acrylics in pharmaceuticals etc.
A wire loop will do the same job at virtually no cost. Biologists and chemists have used this technique for decades or even centuries to apply small quantities of liquid. The amount of liquid dispensed depends on the diameter of the loop and the thickness of the wire and so can be modulated to your needs.
Good idea and the results look great on the two examples ! However, it may depend on the type of primer used, which has to take a clean line without fuzzy edges. It also requires priming, which I often try to avoid in order to not build up unnecessary paint layers. Have to watch the video tonight in order to get more insights.
Trouble is, that such 'debonders' break up the cross-linking of resins such as CA. When you use varnish, the solvent would just soften it, allowing you to reposition the part. I have been working for so long with aceton in the lab (we used to rinse glass-ware after washing it to dry quickly), the a few drops here and there now don't shorten my life too much ...
Some people also grind half away half of the eye of a sewing needle, leaving a forked end, and hold the needle in a pin-vice or in a round length of wood. Some people also use wire-loops (steel wire preferred, as copper ions can inhibit the curing of CA). Any cured CA can be burned off with a cigarette lighter flame. Once the needle has been heated to a red-hot it can also be bent to shape to reach difficult places. Personally, I don't like CA too much and use a fast drying varnish to attach small parts. One has to be aware, however, the bond often is less strong. One has to make trade-offs between ease of application (with a fine brush in the case of varnish), the possibility to correct positioning (by using solvent), and the strenght of the bond.
Self-made small horizontal milling machine
wefalck replied to Bitao's topic in Modeling tools and Workshop Equipment
You are right, for certain milling operations the visibility is much better on a horizontal mill, than on a vertical mill, though they would be geometrically possible on both types. -
OK, you are already quite a bit into the project, but otherwise I would have considered to write to Gilberto Penzo, who runs the Web-site www.veniceboats.com, is the historian of Venice boats and has written several books on the subject, to see, whether he can point you to resources. He is a nice guy and speaks English actually. I visited him in his shop or workshop on several occasions. I would have to check in his books, whether there is any information on the brazzera. Good luck with the project.
- 55 replies
- fishing boat
- Fishing
- (and 4 more)
That's a pretty big machine ... What is the brass part on the middle of the x-y-slide, a steady to support long parts when milling in the dividing apparatus ? -
Sometimes I have feeling that there is a competition out there for who makes the most complicated and intricate designs I gather this internal frieze is actually hiding the duct for the aeration for which are these turquoise shaped vents on the roof ? The colour of these vents doesn't look terribly nice in my eyes - brass would be more stylish ...
The problem was that the the tactical concept for which they were designed became quickly outdated a few years after they were built. The idea was to put an extra-heavy gun behind some armour plate and then fire from a safe distance at enemies (thinking mainly of the French) that could not get close enough in the tidal waters of the German North Sea coast or in the narrow and shallow sunds of the Baltic. They were meant to be a sort of mobile detached fortress for coastal protection. However, when they went into service, the mobile torpedo was invented and successfully made operational. And then a few years after that QL guns were designed. So they became quite vulnerable and were not particularly seaworthy. They were refitted in the later 1880s with two underwater torpedo-tubes in the bow, two QL 8.7 cm guns in the rear and two Hotchkiss 3.7 cm revolving guns that could be switeched between different pivots. SMS WESPE was the first ship of the Imperial German Navy that was designed to make do without any sails right from the beginning. While the class was commissioned, some other, larger armoured ships without any sails were built, but this SACHSEN-class was also conceived as coastal defence ships, the naval doctrine under Bismarck being entirely defensive. Hence they had a limited range of action, relying on the home ports for recoaling.
The DSM in Bremerhaven is undergoing a refurbishment, restructuring and re-orientation at the moment. It seems that they are replacing the 'S' in their name, that once stood for their mission, with an O, that stands for Ocean and makes them drift into the environmental, sustainability and social sphere. Important subjects in their own, but it is sad to see that another 'technical' or 'historical' museum forgets its original mission. We already have a couple of museum with this 'O' in their mission, so the question is, what is gained. I recently found that their library/archive is still responsive and helpful, which is a positive sign.
Modelling locks or Latches
wefalck replied to jackieofalltrades's topic in Metal Work, Soldering and Metal Fittings
Thanks, but I don't think, my wife would like this ... -
https://www.finemodelships.com/ is indeed a kind of co-operative marketing site, as I understand. I do know its operator Dr. Michael Czytko (he is a member of our German shipbuilding history association), but as I am not interested in buying or selling, I don't know anything about the modus operandi of the site. Some links also point to www.modelships.de. When you do a search for Rainer Wedel on the Internet, a few links pop up. He seems to be a former pilot and to work also for the German Maritime Museum in Bremerhaven as a shipmodel builder. Most of his subjects seem to have been taken from NIELSEN, C. (1973): Danske Bådtyper.- 152 p., København (Høst and Søns Forlag). NIELSEN, C. (2006😞 Danske Bådtyper.- CD-ROM, Helsingør (Handels- og Søfartsmuseet). The CD-ROM can be ordered from the museum Web-site. I don't know anything about the oher guy, a Dutchman, Jan van den Heuvel. However, there are abundant resources on Dutch vernacular craft, if it is that what you are interested in.
Stoves/Ovens on ships in the 1600s and Onward
wefalck replied to acaron41120's topic in Nautical/Naval History
The (digital) archives of the Danish Naval yard in Copenhagen are full of detailed drawings for stoves and baking ovens from the 18th century onward. They became more and more sophisticated also with the view to make them fire-safe. -
Thanks, Keith. I had a look over the oldest known version of the plans and counted 60 rounds in total, not counting the (assumed) two drill dummies. It seems that the barrels only lasted for a few hundred shots, before the powder chamber and some of the rifling was eroded. I doubt that the guns ever fired that many life shots. The shells were also rather expensive. Most of the time aiming practice was done with hand-gun barrels mounted into the gun, but the arrangements for this particular gun are unknown.
