Everything posted by wefalck
We tend to be too 'bookie' about how things were done on the boats or how they should be done. Much of that probably is due to navy traditions that are perpetrated also by yachts people. If one looks over photographs of working craft, one quickly realises that not everything is 'ship-shape and Bristol-fashion' and done by the book. Rigging and other things are arranged to the convenience or fancy of the seaman or the skipper. There is a lot of clutter around too. I think there is room for a lot artistic licence, as long as it makes practical sense ... In this sense, you really capture the spirit of this vessel.
Doesn't the NMM in Greenwich have some cutter models (from the time) on which one can see how it might have been done, so that one can see how to fake it ? Somehow, I have my doubts that these small cutters had bulwarks that were planked on the inside. A very quick search with 'revenue cutter' turned this up: Source: https://collections.rmg.co.uk/collections/objects/86219.html (National Maritime Museum, Greenwich) Source: https://collections.rmg.co.uk/collections/objects/86220.html And this, but from 1822: Source: https://collections.rmg.co.uk/collections/objects/86297.html With some more search, one probably can find more details.
I don't know much about LADY NELSON, but believe that she is a rather small ship ? There are many different ways for arranging the timberwork, depending of period, region and size of the ship. In large ships, bulwark stanchions are pieces separate from the frames. Essentially, the hull ends at upper deck level with which it forms a closed, water-tight spaces (except for the hatches). The arrangements discussed above largely pertain to larger ships. In small(er) ships, every other or every third frame is carried up to rail level and thus forms the bulwark stanchion. In general there is then no interior planking of the bulwark (and therefore no spirketting). In such cases there is a 'covering board' over the waterway that is notched or pierced for the stanchions. Sometimes, there aren't even separate covering boards and waterways, but just one massive plank. In such cases often the bulwark planking leaves a space of an inch or so above the covering board for effective drainage of the deck. Not sure what is known about LADY NELSON, but it would be worthwhile to first check the sources on her and not to rely too much on the building instructions.
Hydraulic Dredge by Steve Harvath
wefalck replied to Steve Harvath's topic in - Build logs for subjects built 1851 - 1900
I am always somewhat amazed at the rough utilitarian look of industrial machinery (including ships and related) in the USA ... you captured that look well, I think. -
What primer?
wefalck replied to Brewerpaul's topic in Painting, finishing and weathering products and techniques
The choice of primer will also depend on what paint you are going to use later. The two should be compatible. -
1:64 figures
wefalck replied to tonyplante's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
If it's just for scale, this is also the scale of the old-time flat tin-soldiers. -
In a different context I just looked over my (xerox) copy of an atlas on the Prussian Navy's artillery material, published in 1861. Although still in a nascent stage at that time, it was technologically quite advanced, being kitted out with the latest Krupp breechloading guns. This atlas has drawings for every single part of the guns, their carriages and accessories. The Prussian Navy at that time had as heaviests guns 68-pounder smooth bores and 24-pounder rifled breechloading guns. Both could be mounted in slide carriages of the same type. There is a drawing also for the tracks and these were 9" wide and 1/4" thick to be screwed down onto the deck with countersunk screws, the head of which had about 3/4" diameter. The screws were set 1" from the edge and 13" apart, being offset by half the distance on each side. I only have a b/w copy of the atlas, but in the original the materials were colour-coded in light washes of water colour. As the track appears basically white in the copy, I assume it was light yellow in the original, indicating brass/bronze (or gun-metal) as material for the tracks.
- 24 replies
- pivot gun tracks
- pivot gun
Completing the upper carriage 3 Progress in homeopathic doses: I realised that I forgot the the two steps at the end of the upper carriage. So, the parts for the frame were laser-cut, pieces of tea-bag mesh inserted and the assembly attached to the carriage with lacquer. Steps for the gun-layer I realised now that I had assembled so many tiny parts for the gun, that it became difficult to not loose them and to remember what they were for. Some of the parts indeed had been made years ago. Therefore, I will proceed now to paint the parts and to assemble the gun, which then will be placed as a whole into the barbette, once the model is getting close to be finished. Preparations for painting While the paint scheme overall is quite clear, as it had been laid down in an ordinance of 1874, a few details have caused and still do cause some head-scratching. One of them is the exact hue of the ‘yellow’ for the funnel and the two boiler-room ventilators. Unfortunately, no colour recipes seem to have survived, if there had been any. I undertook some research by proxy, reviewing what other navies at the same time might have done. The paint scheme of the French navy of that time is very different, but that of the Royal Navy is quite similar (or perhaps the other way around). For instance, HMS GANNET, preserved and restored in Chatham, is from the same period. Due to the Corona-crisis the reponse from Chatham to an enquiry is still incomplete. I wanted to know what paint was used in her restoration. Looking through artistic representations of the time, one has the feeling that the yellow was paler and more like buff, than the one used later by the Imperial German Navy. It is notoriously difficult to judge hues on computer screens and on printed colour cards. To begin with, I selected a range of possible colours from my stock and also went through the colour cards of Schmincke, Vallejo, and Prince August (the French trade name for Vallejo). These candidates I tried out on pieces of the material to painted. Colour samples The hull will be black outside and white inside, the deckhouse and the inside of the barbette will be also white. The decks, where not wood, will be a dark grey, as they had been painted in tar with sand mixed in to make them less slippery. The gun carriage will be painted green, as evidenced by some contemporary builders’ models and a somewhat later instruction manual. The hue of the green is another issue. It was probably based on chrome oxide green. The barrel of these breech-loading guns was scraped clean, then wiped with vinegar until a brownish oxide layer developed. The process was repeated several times and any loose ‘rust’ wiped off. Finally, the barrel was rub down with lineseed oil, effectively producing in situ a paint with ferric oxihyroxide and ferric acetate as pigment. The resulting colour would be something like caput mortuum. This is the way the barrel of the demonstration model in Copenhagen seems to have been treated. Moving parts and mechanically relevant surfaces were keept clean carefully, of course. I will, therefore, lightly spray the barrel in Schmincke caput mortuum. To be continued ...
Guns were cast frome bronze and the rollers for the guns too ... bronze is elastic and wear resistant. The tracks were screwed onto the deck.
- 24 replies
- pivot gun tracks
- pivot gun
I think they were rather gunmetal (a kind of bronze) or bronze. Although there were surely enough guys to keep them bright on top, they would still rust underneath and begin to discolour the deck planks (kind of chromatography effect). Painting them doesn't make much sense, as the rollers of the guns would peel the paint off quite quickly. I seem to remember that the tracks on HMS WARRIOR were some kind of bronce.
- 24 replies
- pivot gun tracks
- pivot gun
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
I think that at least since the middle of the 18th century they were made from forged iron.- 1,013 replies
- gun dispatch vessel
- victoria
Ad Q1: my gut feeling is that the stops would be perpendicular to the masts. It will always be a compromise and if you look at it from the front, you may see and equal bent for the shrouds and backstays. There are (at least today) rules for minimum radii through which wire rope should be bent, so that it does not split open and loose strength. The parcelling and worming would to some degree counteracting the splitting of the rope. Ad Q2/3: Perhaps one should draw a parallelogram of the (static) forces that act on the different parts. That gives you some idea for where the strenght needs to be and where there is a risk of splitting the wood. When the downward force of the topmast pushes at an angle against the cross-pieces on which the fid is resting, this means that the force that would tend to push forward the heel of the topmast needs to be counteracted somehow. Either there needs to be a notch in the member on which the fid rests, or there needs to be some kind of wedge between the heel and the forward cross-piece. If the fid had a round bottom, rather being square, and the trestletree had a corresponding round notch, this would make it probably less likely that the upper part of the trestletree splits away, compared to the a square bottom and square notch.- 1,013 replies
- victoria
Pat, I out something together on these tools: Staking and jewel-setting tools In watch- and clockmaking connections between parts are frequently effected by processes that broadly fall into the category of rivetting, i.e. the mechanical deformation of a part in order to effect its locking with one or more other parts. Watchmakers use for this process a tool that is called staking or rivetting tool. It consists of a body shaped a bit like a pillar drill. It has the purpose of guiding the rivetting punches or stakes absolutely perpendicular to the plane of the anvil underneath it. This tool can be used for all sorts of rivetting, punching, pushing-in, pushing-out and similar operations. To this end a set is equipped with a wide variety of flat, domed, concave, hollow and other, specialised punches. There are also varies types of anvils, flat, domed, with notches for watchwheels and –hands, etc. The anvils fit into a rotating plate and can be centred with a pointed punch under the guiding bore for the punches. The rotating plate has also a set of holes (or dies) that are mainly used to support wheels, while the arbors are being pushed out. There were/are various manufacturers for these tools in Europe and the USA (and I guess now also in China and India). Notable brands are Boley and K&D. The sets were made with different ranges of punches and anvils. Mine shown in the picture is one of the bigger sets. About 25 years ago it set me back the equivalent of 250€, if I remember correctly. Related to the staking tool is the jewel-setting tool. In fact, some manufacturers offered jewel-setting attachments for their staking tools, but these are rare today and to tend to fetch high prices on the second-hand market. In order to reduce friction the hardened steel axels in a watch are set into bearings made from hard semi-precious minerals, the ‘stone’, ‘rubies’ or ’jewels’. The jewels in turn are set into the watchplate and locked into place by friction only or by a light rivetting, i.e. closing-in the metal around the jewel with a pointed hollow punch. Incidentally, the same technique is used to lock watch wheels and pinions onto their axles. The ‘jewels’ are made by specialised companies to standard sizes and tools to make the respective holes in the watchplate are made to the required tolerances. The ‘setting’ of jewels has to be done with great care to ensure that their axes are exactly perpendicular to the watchplate. They are rather brittle, so one has to make sure that no pressure is applied to them once they reached the bottom of the hole into which they are set. To achieve this the jewelling or stone-setting tool was developed. Like the staking tool, this comprises a guide for the punch and a seat for anvils. However, the runner for the punches is fitted with an micrometer stop, preventing the punches from being pushed down too far. The punches in this case are actually inserts for the runner. The body is usually die-cast zinc, rather than steel, as not much force needs to be applied during the jewelling operation. Perhaps the best-know manufacturer is Seitz. Normally, complete jewelling tools with punches, reamers for the holes, anvils etc. are rather expensive. Some years ago I acquired cheaply just the basic body of a Seitz tool with the runner, but without all the attachments. The idea was to use it as a light press to allow e.g. squashing wire to a predetermined thickness with the help of the micrometer stop. The target thickness can be set with the help of feeler-gauges or pieces of wire. Over the years I made various punches and anvils for particular forming purposes. When making the brake-handles above, I should have used this tool, but was too lazy to turn up a 0.8 mm insert punch. Overall, I think these are quite useful tools for the modeller, although I have been using so far only a small number of the many punches provided in the staking set, but one never knows what task comes along.
Thanks to all for your kind words ! @mtaylor, I probably could have made the gear really working, after all, it is about the size of a ladies' wristwatch, but making the propper gear-cutters would have been very time consuming @Bedford, I am not sure, I understand what you describe there. I think, there was a reduction gear-train on the inside of the upper carriage with a ratio that made the indicator disc do perhaps one revolution for the elevating range of about -5° to +20°. It was fed somehow by the elevating mechanism. The disc would have had engraved the different ranges with different charges for the different elevations and different projectiles (solid armour-piercing shot and granates), being some sort of simple circular calculator.
Thanks again, gentlemen ! *************************** Completing the upper carriage 2 Owing to the lurking second Corona-wafe we cut our stay in Spain short and returned to Paris early in order not to get stuck at the border. The government were indeed pondering a renewed closure. Whether Paris was the better choice remains to be seen, as case numbers are soaring here too. At least I have my workshop here and I was able to spend some holiday time in it. It continues to frustrate how little I have to show for a few hours of toiling in the workshop, but I keep telling myself that I am single fighter, while in real life large shipyard crews from various specialist trades would have worked on such a project ... The gear segment for the elevating mechanism of the barrel was produced by turning a short piece of aluminium pipe that I happened to have in stock to the correct inside and outside diameter. The teeth then were cut on the micro milling-machine using the dividing head in a horizontal position. Then slots were sawn at the angular distance required and then a slice of the required thickness parted off. The ends of the segments were finally filed to shape. I did not take pictures of this process. Aluminium is a bit bright, but I will at the end tone it down with a soft pencil and it will also dull with age. Below one of the sections of the gear segments for the elevating mechanism For the brackets with which the gear segment was attached to the reenforcement ring of the gun barrel a piece of brass rod was turned out to the correct inside diameter. On the mikro-mill with the dividing attachment in upright position the other faces were milled to shape. Finally, the individual bracket were sawn off with a circular saw at the correct thickness. The parts, which are just over 1 mm long, were chemically tinned to adapt them somewhat to the steel colour of the barrel. As they will not have to withstand any mechanical forces, they were glued to the reenforcement ring with zapon lacquer. Indicator disc for the elevating mechanism on the instruction model in Copenhagen There were still a few details missing on the upper carriage, for instance the indicator disc for the elevating mechanism. How this indicator is coupled to the elevating mechanism I was not able to find out. It is not shown on the drawings, it is not visible on the model in Copenhagen, and the respective parts are missing from the guns in the Suomenlinna fortress. There was probably a gear train on the inside of the carriage. For this indicator disc a piece of 2 mm brass rod was faced off and a mock gradation engraved with a toolbit turned onto its side in 6° steps. There is a steel indictor lever (the function of which is not clear to me, either the disc turned or this lever, probably the former). For this a steel disc was turned with a short arbor and transferred to the micro-mill, where the shape of the lever was milled out. This indicator disc seems to have been fitted only to the starbord side of the carriage. Engraving the indicator disc for the elevating mechanism on the lathe Furthermore the brake-handels for the elevating mechanism were missing. A short piece of 0.25 mm diametre copper wire was flattend in the middle with a 0.8 mm diametre punch in the watchmaker’s staking tool. The resulting round flat part was soldered to a short distancing bushing and turned cap glued on from the other side. The elevanting gear provisionally assembled To be continued ...
A DIY thickness sander
wefalck replied to Kris Avonts's topic in Modeling tools and Workshop Equipment
There is always the risk to over-engineer things, which is alright, if you have large enough precision machinery, to produce all the parts with critical dimensions to the right tolerances. Otherwise it is good design practice to try to limit the number of critical dimensions, even, if the design in the end looks less sophisticated. Guess, how I know this ... Having a stage moving up and down perfectly square to the sanding drum is a manufacturing challenge. With four pillars there are two many degrees of freedom that need to be controlled, particularly, because they are not completely free, but connected by the gearing mechanism. The simplest DIY designs for a drum sander involve a hinged plate, angle of which is adjusted by a simple elevating screw. The angle under the sanding drum determines the clearance and hence the thickness of the material that comes out at the other end. The only critical dimension is that the axis of rotation of the hinged plate is absolutely parallel to the axis of the sanding drum. This can be controlled by having common brackets for both, one on each side, that are drilled as a parcel, tightly clamped together. -
OK, the fishermen were/are tough guys, but how would they have man-handled a 140 lb anchor, an anchor of almost the weight of a man ?
The position of the wheels should be quite well defined by the swing-arms. Perhaps it would be a good idea to drill them through at the car end and pin them to the chassis ... one could make them even working by replacing the plastic spring cylinders with lengths of brass tubing with real springs inside
Gratulations to the completion ! I noticed two things that may have to do with the design of the kit: - the 2CV didn't have an actual dashboard; there was a sort of open 'glove-shelf' stretching across the whole width of the car; close to the box with the speedometer and by the side of the steering wheel the characteristic gear-shifting stick was sticking our near horizontally, with a crooked handle and a ball at the end - the umbrella stick - this seems to have been missing from the kit ? Interestingly, Renault's R4 copied this arrangement, but they inverted the sense of the different speeds, which was very confusing, when you were switching between the two cars, as I did during a certain period. - The front-wheels don't seem to be centered in the wings, they seem to be too far back ... Looking forward to the building of the other kit then.
I believe there are also filled acrylic resins for such purposes, but have no practical experience with them or know of any sources in the USA - just in case you are concerned about the epoxy fumes. Both, acrylic and epoxy, resins can be filled with 'micro-balloons', which are microscopic hollow glass spheres. They can be bought in small bags.
Priming Metal Fixtures
wefalck replied to drjeckl's topic in Painting, finishing and weathering products and techniques
Supposedly ...
