Posts posted by wefalck
  1. I don't do that much sawing with a fret-saw these days, put it seems that a 'standard' (as Otto Frey term it) jeweler's frame does the job to me. As with all fret-saw judicious tensioning adapted to the blade and material to be sawn is required. I don't seem to have a problem fitting the blade to the frame and then pre-adjusting the moveable part of frame before tightening it with the thumb-screw. You may need to play around a bit with pre-adjusting the arm and tightening it in order to not put too much tension on it. In any case it is tool proven in the trade for more than a hundred years.
    Being in Europe, I wouldn't buy from Otto Frey anyway, but too me they always seem to be a bit on the expensive side. One has to always check that such supply houses, like the modellers' ones, don't put a too high mark-up on (certain) tools. Such jewelers' frames are bog standard and one can get them from many different sources. Their 'standard' model seems to be reasonably priced, but they also have titanium-frame ones for the price of which you can get a table saw :o
    I would also support the view that the modellers' supply houses flog-off to modellers a lot of stuff that can be had from jewellers' or dentists' supply houses at better prices and often better quality.
  2. Anatomically, the HO-scale (1:87) Preiser (http://www.preiserfiguren.de) figures are still the best on the market. However, they are meant for model railways and in consequence focus on the 20th century, but with a bit of carving and putty they can be dressed up really in any way you like. They come in packs with large numbers of unpainted figures.
    There is also a small range of HO-scale 17th century naval figures by Artitec (http://www.artitec.nl/index.php/en/kits/item/60006?category_id=121) in cast resin. I have never seen them in 'real life', so I cannot comment on their quality. Their animation seem to be good, but their detail treatment is not as fine as the Preiser miniature sculptures. They are meant to go with Artitec's models of 17th century ships, which in turn are a spin-off from their commercial model building business for museums etc. (see e.g. http://www.maritima-et-mechanika.org/maritime/texel/texel.html).
    You don't give in your profile the country you are residing in, so I cannot make recommendations, where to get any of the above. You will have to check on the Internet.
    BTW, the scale 1:89 is rather unsual ...
  3. That's what I do, if I want to have brass parts look like steel, but rather use a 'self-tinning' solution. This are solutions that precipitate a very thin layer of tin onto the brass. Some model-suppliers sell such solutions. The surface has to be chemically clean, so degreasing (e.g. with acetone) and possibly pickling in acid are needed.
    In fact, if a brass part does not have to look like brass and forms a component of something that is going to be soldered together, I always tin the part before - it makes soldering a lot easier.
  4. Sorry for that ...
    Testing the diefiler in anger requires a suitable power supply with enough ampères and the right voltage. After my large Proxxon transformer blew out, I constructed from mainly scavenged parts a unit that would fit into the worktable. From the estate of my late father I had a large transformer, a rectifier, and a nice 'antique' volt- and ampère-meter each plus various kinds of sockets and a radio knob. I bought an electronic speed-controller and two switches from Chinese sources.
    One switch allows to change between the two voltage ranges and the other is set up as a reversing switch. Depending on the size of leads, I am either using small Japanese-type power-supply plugs or 3.5 mm mono-plugs and sockets for both are provided. In addition, I provided sockets for 4 mm laboratory banan-plugs, one going through the speed-controller, the other directly to the rectifier.
    The power supply is connected via a foot-switch to the mains. This allows to work with hands free and as the transformer is not constantly connected, the energy consumption is reduced and, hence, the waste heat, which is necessary, as the ventilation of the unit in the workbench is not very good.
  5. Clare,
    I was not looking for anything in particular. I am interested in 'vernacular' or 'indigeneous' boatbuilding and noticed that not much seems to be available, at least in western languages. I have seen some scholarly studies on ancient Japanese craft, but not really anything on say the mid-19th (after the Japanese opening) to mid-20th (WW2) period.
    The link to Douglas Brooks is very interesting, thanks a lot !
    I also noticed quite a few more models of Japanes boats in your 'recent builds' list. Are these somewhere on the Internet ?
  6. If you have a lathe, you could turn yourself an end-mill holder that screws onto the thread on the spindle. The holder should be bored out to a tigh sliding fit for the mill shank, which would be held by three set-screws. However, the MF70 runs at speeds of 5000 to 20000 rpms, which might cause some serious balancing problems, so I would be rather not doing this.
  7. I would like to have a toolroom lathe too, could think of some high-class manufacturers, but it is a question of space, when you are living in an appartment, there are limitations  :(
    Most milling machines run too slow for good-quality wood milling. However, I have seen excellent work done with them on hardwoods. There are tiny high-speed mills, such as the PROXXON MF70, that can be used to good effect on wood. They would be some sort of micro-morticing machine and for miling-on flats, dividing work, and similar.
  8. Good point about the Boley/Boley-Leinen 'Reform' lathes. Their bed looks similar to the WW-bed, but is actually smaller. While the spindle tooling is the same 8 mm tooling, anything that goes onto the bed will only work with one or the other.
    Another word on 'collecting' accessories. While they are compatible, headstocks and tailstocks may not be fully interchangeable. They were produced in batches and individual pairs of head- and tailstocks carefully matched to ensure concentricity. In most cases the production was so standardised using fixtures that there are no big problems, but they could be off by a tenth of milimetre. For WW- and Reform-lathes this can be fixed by scraping the foot of either head- or tailstock (if you master the art of scraping). For D-bed lathes the problem is almost impossible to remedy.
  9. The Sherline motor and controller units are good buys (at least were 10-15 years ago, when I bought mine). I am driving my watchmakers lathes and one milling machine with them.
    Boley WW-style lathes are compatible with all 8 mm watchmakers lathe equipment. There may an issue with the thread on collets and in draw-bars. However, in recent years taps and dies for these rather special threads have become available again from model engineering suppliers, so that can be solved. You can also buy again collets and chucks originating in China at a reasonable price. They may be at the limit for high-precision watchmaking, but certainly are good enough for model engineering needs. Be aware, that the Chinese have decided to put a metric 7 mm thread on the spindle tooling of their watchmakers lathes, rather than the standard 6.85 mm x 40 t.p.i. thread. Howver, the Chines also make spindle tooling with the 'normal' thread.
    If you are looking at a Boley D-bed lathe (the bed has 20 mm diameter with a flat on top) make sure to stay clear of the ones with 6.5 mm spindle bore. They have been rare at all times (never understood, why Boley and a few other manufacturers made them, considering that the same manufacturers also made 6 mm lathes, which became pretty much a standard together with the 8 mm lathes). Spindle tooling with 6.5 mm diameter is very difficult to find second-hand and virtually non-existent in the modern after-sales market.
  10. I actually find fabric, except perhaps for what is 'silkspan', unsuitable for model sails, except in very large scales. One can indeed hide some of the overscale coarseness by filling the fabric with paint, at the expense of loosing the transparency of real fabric. In the past I have used casein paints and since acrylics became available these. Acrylics have the advantage of staying flexible, so that the sails can be draped within limits.
    I am rather surprised that the 'tanning' process should result in a 'bright red' colour as mentioned above. From what I have seen in museums and other places, the bark solution is a dark brown, resulting in a reddish brown tint, once the sails have been boiled in it. In the traditional process the sail then would be smeared with a mixture of tallow and ochre. There are many different shades of ochre (which is an iron-oxyhydroxide), ranging from a rather bright yellow to a dark rust-brown. Heating the ochre will change its colour due to the loss of crystal water, for instance. I suspect, that some other dye has been added to achieve a bright red colour.
    Below is a tanned sail from botters in the Zuiderzeemuseum in Enkhuizen (NL)
    And my own interpretation of a botter sail in 1:90 scale, made from individual paper 'sail cloths' and painted in acrylics:
    The actual colours, of course, are not reproduced exactly as the eye may see it due to different colours of light etc.
  11. On the images in the previous there are two parts visible that have not been discussed yet: a round cap that will close-off the electrical installations of the motor and a clamp to fix the machine at the workbench. The round cap actually is a bakelite cover for some electrical home installations and which had almost the right internal diameter. I just needed to enlarge it on the lathe by a few tenth of milimetres. It is held by two M1.6 cheese-head screws for which the casting was drilled and tapped. The clamp belonged to an obsolote electrical drill. The reciprocal movement of the filing machine will necessitate some form of fixation, or it is likely to jump around a bit. In addition, the high centre of gravity of the machine would make working with it like this rather unstable.
    Reduction sleeve for fixing the motor and 12V DC electrical installations
    It was now time to assemble the various parts. The ballbearing was thoroughly greased and pushed back into its seat. Next the drive shaft was pushed in and the crank and piston assembled. Holding the motor concentric in the casting initially caused a bit of headscratching, but then I chanced in the scrap-box upon a set of plastic reduction rings from a machine (they may have well belonged to the very jig-saw) and one of them had just the right internal diameter to fit the electric motor. The drive-shaft was secured with a set-screw to the gearbox output shaft. The scrap-box furnished also a rubberised cable complete with kink protector, for which the bakelite cap had been drilled out. When the assembly was complete, the machine was ready for a first test-run.
    Brass guiding plate
    During the test-run I noticed something previously overlooked: the piston did not have a firm guide to prevent it from rotating. It was thought that the crank would give enough guidance, but it still wiggled somewhat during each stroke, which is rather undesirable for precision work. Therefore, a brass guiding plate was added to the cross-head that slides along the crank-plate of the drive shaft and thus prevents the piston from rotating. One could have also made a new crosshead that touches the crank-plate, but I wanted to avoid a steel on steel contact and the guiding plate can be adjusted for wear.
    To be continued ...
  12. Well, the bodies (beds, cross-slides, tables, et.c) of both, Sherline and Taig lathes are, to the best of my knowledge, made from extruded aluminium profiles. The bearing surfaces may well have steel parts screwed on, but my knowledge of these machines is not so intimate. I think though the Taig cross-feed is all aluminium. Both manufacturers seem to use brass gib-strips, so that you have a brass-aluminium or brass-steel friction.
    The surface hardness of aluminium is less than that of cast-iron and steel, though the Sherline machines use an anodisation process that probably make them more scratch resistant. Therefore, the machines may not be as durable as machines made from cast-iron or steel.
  13. Nature is complex and difficult to predict. You never know exactly what you have in terms of these organic acids, unless you did a chormatographic separation followed by mass-spectroscopy. I spent a signifcant proportion of my early professional life trying to model such systems … So you better avoid natural organics and go for something synthetic you know  ;) .
    The colouring molecules in tea and coffee extract in reality come in various variants of different molecular weights. While the molecules themselves may be not so bad, they decompose, when you put energy, i.e. UV-light, into them and you never know what these decomposition product are like and do. Decomposing organic inks are a major problem in the preservation of old manuskripts.
    Synthetic dyes have been developed for over a hundred years know and we have a certain body of experience with them in real time and from accelerated tests.
