Everything posted by wefalck
  1. It seems that these pirates really had been a plague in the western Mediterranean until the 1840s or so. They frequently attacked the Spanish and French coasts and had even strongholds on what is now the French Riviera, parts of which are still called Côtes de Maures, after the French term for Moors. Ships from ports with lesser naval powers had to pay tributes to get safe passage, while naval powers such as Britain, the USA or France were able to force treaties on them to give safe passage. The newspapers were full of reports on pirate attacks well into the middle of 19th century, which also prompted the small Prussian navy to launch a first amphibious attack on one of the suspected safe heavens in North Africa.
  2. Will that be built over a former or templates? I suppose these boats had bent-in frames to make the hull light, perhaps with couple of sawn ones as templates? Will make a nice show-off woodworking project I think. And you are right, sometimes we make plans for new projects for years and then we come across something that catches our interest ...
  3. These spacing cards are a good idea, I use them also, when rattling down. Also draw the shrouds, then you will immediately see, when you are pulling them out of shape. Don't fix them with glue until you have finished the whole set - this allows you to make final adjustments. Another practical thing to consider is to position the model so that you can work in a comfortable position on it, this is particularly important for the topmast- and topgallant-ratlines. If you have to constantly keep your arms suspended above mid-chest level, this becomes very tiring and you will get sore muscles in the back.
  4. Quarter-deck v4 While the wooden quarter-deck previously produced (v2) was not entirely bad, it lacked the crispiness I had wished for and also the colour was somewhat murky, more like oak, and not like the teak it was probably made from. In addition, I found a mistake in its shape that could not be corrected. This quarter-deck is somewhat unusual in lay-out, as the planks are radiating with the gun-pivot as centre. This lay-out probably was chosen to minimise the effect of the certainly considerable blast from the 30.5 cm-gun. Apart from the fact that most wood-species would be too coarse at 1:160 scale, it would also be a challenge to produce such deck with tapering planks only 0.4 mm thick. A painted version renders more likely a realistic representation, is technically easier to achieve and more in line with the style of the model. The shape of the wooden deck was cut from a 0.4 mm thick sheet of bakelite-paper and carefully fitted to the hull of the model, which was quite a bit of work given the multiple curvatures. The caulked seams were indicated by narrow engraved lines as described earlier in this building log. The holes for all the fittings were also drilled at this stage. In between, I had tried using black styrene, rather than bakelite-paper as a basis for the decking (v3). The rationale was that I would clear out the engraved lines after painting down to the black plastic. This strategy did not work for two reasons, namely the styrene (Evergreen™ sheet) is much softer than the bakelite and the acrylic paints form a kind of quite soft skin, which tends to rip in flakes when trying to re-engrave the lines, so that I dropped this idea. The wood character of the quarter-decking was to be achieved by giving each plank a slightly different colour, imitating the natural variability of wood. The piece was given a base-coat of Vallejo Model Air 71075 ‘sand (ivory)’ using the airbrush. In a next step single planks were randomly given a light wash with Prince August 834 ‘natural wood transparent’ or Vallejo Model Air 71023 ‘hemp’ (which turned out to be a bit too dark actually). In a next step randomly selected planks, particularly those ‘hemp’ ones were given a very light wash with Vallejo Model Air 71288 ‘Portland stone’. Another very light wash with Vallejo Model Air 71041 ‘armour brown’, toned down with yet another very light wash using Vallejo Model Air 71132 ‘aged white’, pulled everything together. Painted quarter-decking before sealing it with varnish To facilitate the picking out of the caulking seams, the decking was given a sealing coat of acrylic glossy varnish. The definition of the caulking seams was enhanced by running the back of an old scalpel along them, making impressions, rather than cutting through the paint. The caulking was imitated using a 0.05 mm marker with pigmented permanent (hopefully) ink. After each line was drawn, the ink was allowed to dry for a few seconds and the excess wiped off with a barely humid finger. This leaves the ink only in the incisions, resulting in a very thin black line. In spite of the glossy varnish, a haze of the ink is left on the planks, darkening them somewhat, but this effect was calculated in, when setting out the original paint scheme. The surface was lightly rubbed down with an abrasive foam block (as used in mani-/pedicure) to thin down the glossy varnish without damaging the underlying paint. This rather complex procedure was concluded by applying another very dilute wash of Vallejo Model Air 71132 ‘aged white’ and finally a sprayed on coating of Vallejo matt varnish. Finished quarter-decking ready for final installation To be continued ....
  5. Ulitmately, its your decision, of course. Personally, I regret short-cuts I took and mistakes made in ignorance decades ago when looking at my models ... don't complete something to just complete it, be patient, until you have the right information - that would be my opionion for what it is worth.
  6. Ball-bearings are a good idea, also, when working with metal. Mechanics of old sometimes made make-shift steadies just from a piece of thick cardboard into which a suitable hole has been punched or drilled. As the diameter decreases, you will have to use a new cardboard with a smaller hole. This makeshift 'steady' could also be screwed to the follower steady.
  7. Wow ! ... even if it didn't get the right results. It's quite impressive, how these stamped holes hold up in the Castello-end grain. I have been, indeed, thinking of making gratings like that, but was afraid that they would just crumble away.
  8. The pictures now make it clearer what the issue is. I thought we are talking about a working-boat, not a pleasure-boat. Is she sloop- or cat-rigged? On a sloop-rigged boat, the forestaysail sheets are often belayed on cleats on the deck near the helm. How is the main-sail boom-sheet led? I suppose there is a block attached with a traveller to the horse and another block to the boom above. Sometime these are double-blocks and the fast part of the sheet is attached to the block on the boom, goes down to the traveller, back up to the boom, down again and from there to a third, single block above the cockpit, so that it can straight down into the cockpit. This avoids chafing on the coaming. However, the boom-sheet on such boats would rarely be belayed while sailing (too risky), only when stationary. If I understood you correctly, you would like to have benches inside the cockpit? I think that cockpit is far too smal for this, there would be no space to work the sails then. I don't know the practice on these boats, but on European pleasure-boats of that kind, there were often slatted seats on the deck outside the coamings, along the cockpit. This would also bring the 'live'-ballast further out.
  9. ... and you can't use normal optics with glass-lenses, they absorb too much long-wave radiation. Not sure that is still done, but 'traditionally' lenses made from salt were used, I believe. What do they use in night-vision optics? Or may be the modern photomultipliers are so much more sensitive than old IR-films.
  10. Not sure what you are actually doing there - colourising/filtering your images in an image processing software with a filter that makes them look like IR images? True IR images would actually be B/W, as IR is not visible. So the software filter just transposes certain colours and deletes others.
  11. I think the first two items are quite useless, as it is difficult to transfer the necessary dimensions exact enough - it is better (and easier) to work in situ. Not sure what the thingies with the blue handles really are, but probably tools from guys working on circuit boards or something like that. I think an useful rule/guidance is to start work with the tools you have and than at some point, you will discover that you would need to do a certain operation, but cannot do it with the tools you - that is the moment to look for the right tool. Of course, it is always a good idea to look left and right how others do a certain job and what tools they use. Many rigging tools one can make oneself. Sometimes insert for pin-vises are sufficient, which is why I have a hole collection of them.
  12. I buy them off jewellers' supply houses and depending how much you push them down, sooner or later they get distorted. For steel ones it takes longer, of course. The wires are essentially clamped between to metal discs, perhaps they are also fused into some plastic in the middle, but essentially it is just friction that keeps them in place, so 'hair-loss' is normal. And yes, I would use gravers/scrapers first on the solder and then finish off with the wire-wheel ...
  13. On small boats it is pretty much up to the owner, how it is/he has it kitted out. However, on specific types local habits may be the prevailing rationale. In this case, not only how it is worked during the actual sailing, but convenience during working fishing gear, sailing when heavily loaded and other consideration that are not immediately apparent, when one does not know how the boat was really handled may be relevant. Also, when having to move a cleat from its usual place, other devices for belaying could be considered instead, such a belaying pin in the rail etc.
  14. Looks really like thing - ignoring for the moment the 'brassy' appearance of the roof.
  15. I think the different aspects of colours and details as a function of viewing distance is an old dilemma for 'realistic' modellers. A modell will be viewed from a wide variety of distances and angles, unless it is set into a diorama-box that fixes these variables. If you design the model to be viewed from a certain distance, it will look cruede, when oberserved close-up. Have a look at e.g. a painting by Caneletto: paintings are normally designed to be viewed from a distance of about the length of the picture diagonal - from this distance his paintings give a vivid impression of life in 18th century Venice. However, when you put your nose on it (or as close as the security measures in the museums permit), you will only see some pretty shapeless blobs of paint. So, we have to build our models to be viewed from close-up or prevent this by the setting in which a model is to be displayed. Concerning the question of ochre vs. gold, this also depends on what kind of model your a building. If it is going to be a 'realistic' one then you will have to take the above considerations into account and also follow the full-scale practice, where indeed parts may not have been gilded, but painted in ochre or a similar yellow paint. Sometimes, just a few highlights were picked out in gold or certain elements were emphasised by using gold. On the other hand, if you are building a sort of 'artistic' model, replicating e.g. the prestigious display models of old, you may well use gilding, as this is what was used then for models.
  16. I gather this depends on what was used on the prototype. In Valery's case, these are not sail-carrying masts I believe and at that time, indeed, iron bars or wooden battens were used as rat'lines'. In Keith's case this is a traditional sailing rig with (probably) metal-wire shrouds and hemp ratlines. It is rather difficult to tie knots into wire (I tried repeatedly ...) and wire kinks easily, which then are difficult to remove. If anything, I would use twisted wire for the purpose, as twisting two or three wires together makes them more flexible and less prone to kinking. Still, I would look for the thinnest fly-tying yarns that you can get hold of. The thinnest I found was Veevus 16/2. Caenis also makes very thin ones. Avoid the monofilaments, because knots dont't hold in them very well and they look unnatural, because they are smooth.
  17. What thread are you using for the ratlines? On the prototype they would be probably around 1/4" to 1/2" in diameter, so 0.002" to 0.004" mm in 1:120.
  18. When thinking about ratline spacing, I am sure that contemporary books on rigging may have to say something about it, though this is more an artisanal question left to those in charge of rigging. However, if you try to lift your foot, you will find that lifting it in excess of 12" is quite a bit of effort, which is also why the distance between rungs on a ladder is around 9 to 10". So I gather a distance of 10 to 12" is ok. Whether there are ratlines on topgallant shrouds depends on the time and the way how topgallant and (perhaps) skysail yards were fitted. Concerns for safety (and convenience) at sea were certainly less developed until the early decades of the 19th century, which is why one apparently sees topgallant ratlines rarely. Instead, a knotted rope may have been fixed to the top for the men to hold onto. In later years ratlines often also were absent, when the corresponding yards were set flying, meaning that the yard could be lowered to be reached from the topmast top, or even lowered to the deck.
  19. As a matter of fact the transition between varnish, sanding sealer and primer are rather flowing. A primer is a material that interacts physico-chemically or chemically with the surface to which it is applied and thus adheres well to it. In turn, the paint interacts with the primer and therefore adheres well to it. With the exception of certain oily wood species, there is normally no need to prime wood for painting. A sanding sealer essentially is a kind of varnish in which finely ground particles, often pumice powder are suspended. The idea is that the varnish penetrates into the wood and the particles fill up any surface structure and pores of the wood. There are many commercial formulation of sanding sealers available. While they were originally based on solvents, today acrylics based formulations with water as solvent are more and more sold for environmental protection reasons, though they do not penetrate so well, particularly into more resinous wood species. Sanding sealer is applied after a first sanding that has been rubbed down wet to raise the wood fibres. It is then sanded down in preparation for further steps. Sometimes a second application is needed. Rather than sanding, I prefer to either scrape (flat surfaces) or rub down with steel-wool (curved surfaces). A dye or stain is a coloured organic molecule dissolved in water, alcohol or an organic solvent. This means a dye can only applied to material that is capable to soak up the solvent you are using. It implies that you have to apply any dye or stain after a first sanding, but before applying sanding sealer. An ink, conversely, is a liquid, usually water or alcohl, in which finely ground solid particles (e.g. soot) or coloured organic partciles are suspended. The ink also contains a binder, that may be either water soluble or not - in the latter case it is referred to as permanent ink. A varnish is a lacquer dissolved in an appropriate solvent. A classical example is shellac, which is dissolved in alcohol, which gives it a good penetration into wood. Other lacquers and solvents may be used in commercial formulations, such as acrylic or polyurethane varnishes. The varnish would be applied to the surfaces prepared with a sanding sealer. One has to pay attention that the solvent of the varnish does not attach the sealer, otherwise you may destroy the effect of sanding. A paint essentially is a varnish that has a pigment added to it. Again, paint is applied on top of the sanding sealer and the same provisa as for the plain varnish applies, i.e. sealer and paint have to be compatible. In general, water-based acrylics are compatible with almost anything, as water is not a very agressive solvent.
  20. Cast metal in most cases does not need to be annealed, because the cooling process is so slow that the metal atoms have time to disorder themselves. Having said that, non-ferrous metals cannot be hardened by heating. Therefore, what you find in a cast piece is usually the softest state. Non-ferrous metals work-harden by beating or rolling. Anealing softens them. I suspect that the cast piece you are referring to is white metal, an alloy containing inter alia lead, zinc, and bismuth. Compared to the pure metals it is quite hard and has a low melting point (which is why it used for such castings). Also, the temperature range for the transition from the solid to the liquid state is quite narrow, so rather than becoming soft as many other metals, it quickly melts.
  21. What scale ? Ideally the fingers should be bent to grab either the ratlines or the shrouds, depending on how the hands are oriented in the figurine. Of course legs and arms need to be properly positioned, so that they touch the ratlines. Remember that the ratline would sag under the weight of the man. When the fingers are bent around the shrouds/ratlines then some matt varnish should be sufficient to secure the figurine to the rigging.
  22. My library comprises hundreds of books - you never know, whether you may need/want a book (again) at some stage. Ordering through inter-library loan is a good strategy. I used to do this extensively with newly published books, as there is a system whereby a central German library has to buy a new book, when it is somewhere ordered in Germany through inter-library loan. Otherwise, it would have been not so easy to look at new English-language books, if you didn't have a suitable bookshop nearby. Not sure what the rules are in the USA, but in the EU a publication normally becomes public domain 90 years after the author's death unless someone else acquired the rights. Which means that most pre-WW1 publications are no free to copy or to distribute as ebooks. The amount of digitised books rises by the day and many small libraries are doing actually a better job on this than Google (which nor normally unfolds tables and such things, thus missing the key information). So before looking in antiquarian bookshops or physical libraries, I am checking whether a book is available as PDF somewhere. As to 'how to do it'-books, I have only a few and decided not to buy any other, because they mostly just copy from each other or repeat what is more or less common knowledge.
  23. An isue with most of the books quoted is that they combine proposals for resolving technical problems with some historic context. In most cases they dive not deep enough into the historic context to be really useful. Underhill is an exception as he deals specifically with the last half century of commercial deep-water sail and clearly states so. Hence, if you are interested in a specific period, you certainly will need addtional literature in order to understand what was going on. This is a point perhaps not made clear enough in these books. BTW, we didn't mention Frölich, B. (2002): The Art of Ship Modeling.- 303 p., Nice (A.N.C.R.E.). yet, which is both useful and aesthetically well done. He doesn't say so in the title, but his subjects clearly span the mid-1700s to early 1800s, a period short enough to provide a reasonable amount of historical detail. Plus the book uses contemporary models from the museum in Paris for illustration. @SaltyNinja, what country/region are you looking at? There are quite a few in-depth books on fishing vessels around.
  24. In the German-speaking world, it was the translation from Italian of Orazio Curti's book that was most widely available and that covered the subject in breadth, using also many contemporary illustrations. The first rudimentary books specifically on ship-modelling, however, were already published in the years before WW1. I also have a small and probably not widely known German book of 1948, that already describes many of the 'standard' techniques. Most books I know, are concerned with simplified methods, rather than describing methods to reproduce parts as closely to the prototype. Unfortunately, it seems that such methods then were perpetrated as 'this is how things are done'. Instructions in kits also often follow this idea.
  25. Honestly, I do not believe too much into 'grand masters', teachings, schools and such. There are few basic carpentry, metal-working and similar techniques applied to a specific subject, that is ship models. Each of the authors quoted uses different short-cuts for one reason or another, such as what they tried to achieve, what tools where available to them, their respective manual skill level, etc. It's a long time since I read Davis and I did not check again before writing here, but seem to remember that his objective was to indicate to the reader techniques that would allow an averagely skilled person to turn out a ship-model without getting too desperate. I seem to remember that the book was written in the early 1930s. At that time most of the speciality tools (hand and machine tools) were available in the UK in principle - Clerkenwell Road in London was a dream of precision tool-shops and -manufacturers at the time, but it would have been much more difficult for the average person outside London at the time to put their hand on them. By coincidence I just finished re-reading Underhill's volume on rigging. He wrote his book just after WW2, when again it was not so easy to find tools and machines (and money) as the UK was recovering slowly from the war economy situation. Underhill is much more pre-occupied with accurate reproduction of the 'real' thing, but also with showing ways to do this without a big tool-kit. His focus is, as stated in the titles of his books, on later 19th/early 20th century ships. This does not mean that many of the techniques he describes would not be applicable to other periods, though there would be less emphasis on iron-work, of course. When looking at such books, one has to make a distinction between the artisanal techniques they describe and their description of representing actual shipbuilding techniques. Underhill, does not claim to be an universal text book - unlike some more modern publications, who make such claims and then fail, because the authors just do not have apparently the necessary breadth and depth of knowlege and the space provided by their publisher.
