About JohnB40
- Birthday 08/21/1952
Gender
Oregon Coast
Interests
Hiking and ship modeling
WWR4 reacted to a post in a topic:
Work area pictures only
aaronc reacted to a post in a topic:
Bomber_County reacted to a post in a topic:
Tecko reacted to a post in a topic:
JohnB40 reacted to a post in a topic:
Seishu Maru by Landlubber Mike - Five Star - 1/700 - Resin and PE - IJA Crane Ship
Schneider CA - Armoured by RGL - HobbyBoss - 1/35 - PLASTIC
Planking precision and wood filler
Does painting mean covering the mistake?
Renault FT-17 on a Renault FP artillery transporter by RGL - FINISHED - Meng/U-Models - PLASTIC/RESIN - diorama
JohnB40 replied to Johnny Mike's topic in Modeling tools and Workshop Equipment
Here is my workspace. It is quite small but out of way. This is for assembly. I also have a spot in the garage for my mini table,scroll saw etc. -
Buckboard by kgstakes - Model Trailways - 1/12 scale
JohnB40 replied to kgstakes's topic in Completed non-ship models
Very nice indeed. You have inspired me to restart on my buckboard build. It was all complete except for the wheels when when I put it in a sealed box on the shelf to finish in the future....That was 2 years ago! -
Mini Table Saw recommendations
JohnB40 replied to captainscott's topic in Modeling tools and Workshop Equipment
Thank you for the information Mark. -
I have been very satisfied with my MicroLux Table saw which I purchased about 10 years ago. Mine was made in Japan,I don't know if they still are. It takes a bit of time to set the fence but once done stays put and keeps within tolerance for as many cuts as needed. I did buy a finer blade that the one supplied. -
I'm looking for the right thinner for MM acrylic as it pertains to brush applications. The more I try to find the answer from various forums the answer becomes more confusing. Anything from distilled water,window cleaner,Isopropyl Alcohol and a host of others all contradicting each other,warning of dire results. MM thinners is no longer available.
Thanks for the idea...Headed out to the bench sander to do some peg sculpture
While planking the bulwarks on my Confederacy,I found it difficult to find the right clamp. All had too short a reach,too much tension or just plain junk. I solved the problem with my wife's clothes peg. Just turn them about face and use some heat shrink for the tips for padding.....Works a treat
I had not been aware of this happening. Well worth watching this on You Tube. https://www.youtube.com/watch?v=tccWmr9bZYA
Jaguar XK-E by CDW - Gunze Sangyo High Tech Model - 1:24 Scale
JohnB40 replied to CDW's topic in Non-ship/categorised builds
I spent 35 years restoring E Types (and other Jags) 1:1 scale. -
Hi Mike, Great research,you are becoming quite an expert on the Japanese Imperial Navy. I'm looking forward to following your build log on this ship., Regards, John
HMS SUSSEX by KarenM - FINISHED - 1:48
JohnB40 replied to KarenM's topic in - Build logs for subjects built 1501 - 1750
Stunning! -
Outstanding ,Mike. Looks as if my finger would get wet if I touched the base.
- 179 replies
- hatsuzakura
- pit road
