JohnB40
Everything posted by JohnB40
  1. Here is my workspace. It is quite small but out of way. This is for assembly. I also have a spot in the garage for my mini table,scroll saw etc.
  2. Very nice indeed. You have inspired me to restart on my buckboard build. It was all complete except for the wheels when when I put it in a sealed box on the shelf to finish in the future....That was 2 years ago!
  3. Looking forward to following your progress. I found your posts on your build of the Confederacy a great help. My build on said ship proceeds at a snails pace (winter project only).
  4. Thank you for the information Mark.
  5. I have been very satisfied with my MicroLux Table saw which I purchased about 10 years ago. Mine was made in Japan,I don't know if they still are. It takes a bit of time to set the fence but once done stays put and keeps within tolerance for as many cuts as needed. I did buy a finer blade that the one supplied.
  6. I'm looking for the right thinner for MM acrylic as it pertains to brush applications. The more I try to find the answer from various forums the answer becomes more confusing. Anything from distilled water,window cleaner,Isopropyl Alcohol and a host of others all contradicting each other,warning of dire results. MM thinners is no longer available.
  7. Thanks for the idea...Headed out to the bench sander to do some peg sculpture
  8. While planking the bulwarks on my Confederacy,I found it difficult to find the right clamp. All had too short a reach,too much tension or just plain junk. I solved the problem with my wife's clothes peg. Just turn them about face and use some heat shrink for the tips for padding.....Works a treat
  9. I had not been aware of this happening. Well worth watching this on You Tube. https://www.youtube.com/watch?v=tccWmr9bZYA
  10. I spent 35 years restoring E Types (and other Jags) 1:1 scale.
  11. Hi Mike, Great research,you are becoming quite an expert on the Japanese Imperial Navy. I'm looking forward to following your build log on this ship., Regards, John
  12. Hi Jerry, The square nuts were stamped on small sheets of black fiber board. If they are missing,Model Expo will send you replacements. They have very good customer service.
  13. Hi Walrus Guy, Instead of painting the letters I have used dry transfer decals with good results. I used Dulcote to fix in place and protect after applying. Make sure you order enough for Confederacy in the right size with some for possible mistakes. These are the ones I used... https://woodlandscenics.woodlandscenics.com/show/item/MG703
  14. Mike, Stunning piece of modeling once again. I find it unbelievable when I reference the scale to the Tamiya jar. I'm looking forward to viewing your destroyer diorama.
  15. Hi WG, I like the colors of your upper works. I posted the painting of the Confederacy on the forum awhile ago. When I came upon it,I had already painted my upper works black or I might have used the color scheme as you did. How authentic it is,I guess we will never know for sure,but it sure looks great on your construction. It looks like the quarter galleries where painted the same. My Confederacy proceeds at a glacial pace,I don't update my log as I live in a remote rural area and our satellite internet is one step above dial-up. A photo uploading is like watching paint dry. Keep up the fine work.
  16. I made this a while ago,works well in confined areas
  17. Mark, Thank you for for posting this,I 'm looking forward to part 2.
  18. I grew up in Dorset,not many miles from Bovington. When we were young my cousins/pals and I would ride our bikes over to the museum which then wasn't so large ,a lot of the tanks were parked outside,especially the great war ones. We could climb on them and if I remember correctly could go inside a MK 4,if not then we had access when they were first moved inside. There was one,I believe a MK 2 used at Arras,which was riddled with AP rounds and small calibre shells. you could see where some of the projectiles went clean through both sides. The MK 2's were training tanks and only their sponsons were armored. During the invasion threat in 1940,the local stories stated these tanks were transported to local important cross roads and used for defense with their 6# guns. Bovington is well worth a visit.
  19. Thank you for your replies gentlemen. With multiple layers of raw sienna wash over the base coat,I got a result I am happy with. Jaager,I'm afraid my carving skills are too rudimentary for the figurehead and transom figures. I wish Syren's resin example was still available. I'm sure everyone who is constructing (or has) the Confederacy would have liked to throw "Marvin the martian" overboard and replace him with Chuck's.
