Some Idea
Everything posted by Some Idea
  1. Hi Gerard Thanks for the reply - As soon as I discovered this issue I was quite certain that its a printing issue. I'll wait for Ancre to check their prints as obviously if this part is wrong others could be too. I just need to know from them that the main assembled drawing is correct and I'll use that instead. Thanks again Mark
  2. Oh on the positive side I have remade the sternson and extensions. I corrected all of the errors of my own making so this is far better than the original one that I made. I did have to jiggle the scarfs though probably for the same reason as above I've just not have time to have a detailed look at that. Quite honestly it doesn't matter as this version lines up exactly with the main plan 😉
  3. Hi All I have a problem - or should I say I've found a problem. As you know I'm currently remaking the keel parts due to the stem not being straight. So I remade the stem parts and yet again the parts were not aligned as they should be. So I put it down to my mistake and made them again - yep you've guessed it they were also misaligned. I seemed to have to make lots of corrections on the scarf joints no matter how carefully I machined them. Even then they just were not quite right. I think I was lucky in my first original attempt to get them to line up. Maybe beginners luck! So I checked the plans and I have found them to have errors. The stem on the exploded part of the plan which is marked by "B" on the attached photo has different dimensions to the stem marked "A" on the main plan. Its about 1mm different which has a big impact on the scarf joint dimensions too. I have been using the exploded plan to gain my templates so basically I have been wasting my time and loads of wood too. The obvious solution would be to use the main plan and cut the pieces out of that; but if thats so why have the exploded parts? I'm certain that Ancre have no idea of this problem so I've dropped them an email to let them know. I'll wait for their reply before I do anymore work but I'm sure that they will be surprised. My guess is that the error occurred at the printers and has nothing to do with them. I've asked them to check their drawings and I'll send them detailed photo's if that will help. I'll keep you up to date as things move forward. Mark
  4. I had a similar issue with my last build as I needed some large diameter tube. I used aluminium in the end https://www.speedymetals.com/pc-2442-8368-1316-rd-6061-t6511-aluminum-extruded.aspx
  5. Hi Tony - yes it’s clean but not straight 😂. I’m working on putting this right at the moment. If you look at the back of the monograph you will find the scantlings which give the timber sizes. What it won’t tell you though is the overall quantity that you need. I’ve found this to be unimportant as the time scale required to build this ship is long so if you like just buy what you need to get going. Or do what I did and just buy a load of lumber from your supplier and make them very happy people 👍
  6. I made this today entirely from start to finish (except for the tapered rabbet which was filed by hand) on an MF70. Is it up to the job - damn right it is! The thing that this tiny mill has over its much bigger counterparts is spindle speed. You can get up to 20,000 rpm which on a small cutter virtually eliminates chip out. This is one of my go to tools and wouldn't be without it.
  7. That’s a very nice job vaddoc. In regards to the gaps rather than using filler I would fill the gap with wood glue and then sand the hull whilst the glue is still wet. That may just fill them up and it would also be the correct colour.
  8. Thanks for the nice comments all. I’ve made a start and it won’t take me long. There’s only a few pieces to make and I’m in no rush. I’ll keep you posted as I just want this build to be right
  9. Hi Tony I'm pretty sure now that I pulled it around when I clamped the apron in place. The solution would have been to remove the apron so I left the whole thing in a bath of IPA overnight. This has not even touched the glue and everything is still as solid as it was. So like we do I tried to force it apart and its now damaged. So I'm going to remake it and I'm ok with this, as it needs to be right. I'll pick this thread up again once I get to where I was Mark 👍
  10. Well I guess something had to wrong sooner or later. I was just about to start on the last two rising wood pieces and I thought that I would just check the alignment of the keel again - and its wrong. The angle of the stem has moved by 1.65mm out of alignment and I think this happened when I glued the apron on. I think that I probably over clamped it and pulled it back somehow. I cannot pull the stem into alignment as it then stresses and bends the keel upwards. I think this will have to be a complete rebuild which is a shame but hey ho!
  11. Hi Dave - A word of caution as I'm going to encourage you to spend some well earned money!!! Have a look on the Cooksongold website as they sell Foredom tools. I have just swapped over to these and got rid of all of my Dremel gear after this was recommended to me. I was very reluctant to be honest but the difference is like night and day. Loads more control with torque rather than speed and a really decent drill press too which suits our needs. I have a hand piece that accepts 1/4 diameter bits too. I wish I had bought this years ago as the amount of money I have spent on little bits here and there that turned out to be useless. Here's a picture of the drill press and the standard hand piece using a small Proxxon vice. Just another option for you that will stand the test of time.
  12. Hi Clogger its not to far off now but I'm going to make the transom timbers first the same way Adrian has in his book. I will be making a jig so that things are nice and square too. Not much done today as I really needed to give my room a really good clean as I've been making quite a bit of dust. I've tidied up the sternpost rabbet so that it has a better transition. I've also just been going over what I've done so far to make sure nothings been missed.
  13. I got some more done today - you will be relieved to know that I go back to work tomorrow so my updates will be at my usual slow rate of building! The parts that were previously fitted dried OK but.......I do have a bit of a gap between the stem and the apron. I tried to scribe these parts together but it didn't quite work out as I had hoped. Its only a small gap and on my next build I'll learn from my mistake. I've now cut the stem rabbet which is time consuming but also really pleasing. I learn't on my last build that getting the rabbet right makes the planking just that little bit easier. I have noticed that I need to do a little more work on the stern rabbet so I'll have a look at that in the morning. I did make a mistake when I started to cut the rabbet. I marked it out far too wide and luckily realised this after I had cut it about 1 1/2 down the stem. I stopped and inlayed a repair piece and then started again once dry. There's a picture of the repair which obviously only I know about and I'm not going to tell anyone else...............oh hang on a minute 🤣 I feel like I'm starting to get somewhere now - Mark
  14. This is one of these solutions that seems good until things go wrong 1. You cut a thin strip of wood and the one side gets dragged down into the blade and busts through the tape seizing the saw. 2. The tape has drag that a metal surface doesn't. So your piece stops and your finger don't 3. This lulls you into thinking that your saw is set up correctly I think that you have got away with things so far. If you have worked with power tools for a long period you will know just what a nasty habit they have of biting back just when you're not expecting it. I have so much respect for table saws that there is no way I would do this. Just make yourself a proper zero clearance insert and have done with it. Why even think about taking the risk.
  15. Spot on Roger but considering the postage of a Byrnes saw outside of the USA is about $275 I don't think a few inserts will dent anyone's budget 🤣. We then pay 20% VAT on the cost of the item and the postage too when it arrives and before delivery. The UK Post Office put a $20 handling charge on just for good measure. I hope we get a Transatlantic trade agreement as soon as possible 👍
  16. This is great advice - you will need 4 - 5 zero clearance inserts dependant on the different width blades you use and its great to have a spare. I use all of the different blades for different jobs. I imported mine to the UK and the customs charge and postage basically added a third or more again to my purchase. So my advice to you is get as much as you can into your parcel and only pay for postage once. You'll be buying its own seat on the plane 🤣 Get a spare drive belt and spare bolts just in case you loose any. If your budget will stretch to it get the sled too. Its a great bit of kit and so well made. Buy as many spare blades as you can as you will save money in the long run. I know that they are expensive and I saved for two years to get mine - Quite simply its the best tool I have ever owned. I've since sent mine back to Jim to get the bigger table. Great back up too - just go for it and buy as much as you can in the first instance.
  17. Hi Michael and thanks for your comment - Now it may look perfectly accurate in the pictures but just like everyone else I have to jiggle all of my joints around a bit to get them to fit. I also have to make loads of adjustments to make the parts fit the master plan as I have found that photocopies have much thicker lines. This may seem like no big deal but a few slightly thicker joints on a model that's a metre long adds up to a 3mm problem at one end or the other. I check against the plan more times a day than I care to admit too. I do quite a lot of machining but I always finish my parts by hand. I prefer to use small Villorbe engineers files as they really rip through the wood if need be. I can also get a very flat finish on the wood using these too which is another reason why things look on face of it smooth and precise; trust me they are not. I don't like using sand paper as it just rounds of the edges which makes good joints look sloppy even if they are not. I think I'm trying to say that I try and keep things flat and as square as possible. If I could recommend one tool to master its a flat file. When I do use paper I use fine silicon carbide paper. Its very thin and seems to last for quite a long time. What you don't see is the amount of pieces that don't make the cut. If its not going right - it's going in the bin. I've spent literally and entire weekend making a part only to destroy it accidentally at the last minute. I hope this answers your question - Mark
  18. So far so good mate! Today I had to first correct an omission on my part. I forgot that the floor side of the frame has a narrower fitting on the rising wood and I had forgotten to do this. So I cut the 3 affected notches which luckily was easy enough. Next I made the lower apron and the apron. Another tricky part to get right but I've done the best that I can. Its now clamped onto the keel waiting for the glue to dry. I'm going to concentrate on the stem rabbet next so I need to put some thought into that.
  19. Hi druxey 🤣 Thanks for the comment - Maybe one of the mods can give me a new screen name I'll leave it to them to choose 🤣 Today I made the sternpost knee extension which turned out to be quite tricky to make. It has many notches at differing angles and then it has to be tapered towards the stern. Not only that it tapers downwards too and then the sternpost knee and the false sternpost have to tapered to match. I found the best approach was to fully mark out the tapers in all directions on all the pieces to that I could envisage how it should look after it was completed. I think this job took me about 9 hours today but I'm quite pleased with the results. It's not quite perfect as its about 0.5mm out in a couple of places but I think its about as good as I can do at the moment. There is a picture below showing it on the keel - since this was taken I spent about an hour making it fit really nicely and now its glued onto the keel. I'm looking forward to getting the clamps off in the morning. Tomorrow I'll have a look at the bow parts and see what needs to be made. Thank you all for the really nice comments they really have blown me away Mark
  20. This is what I would try
  21. I'm glad to say that the sternpost has turned out ok. I did forget to put a tar line across the bottom of the false sternpost but I'll correct that with a line of paint probably in 2023 when I'm nearly finished 🤣 I now have a nice and straight keel which exactly aligns with the plans. I've made a start on the stern rising wood and also the part that holds the transom parts. All of the parts need finishing off at a later date but so far so good. I did make the mistake of drilling the rising wood with 3mm holes - I put 2mm holes in the frames! Oh well its no big deal I'll sort it out when the time comes. I think I'll enlarge the frames to suit the rising wood. These pieces also require tapering so I need to put some thought into how I'm going to do that but tomorrow's another day.
  22. Hi Clogger - I've cut the rabbet using a V carve tool simply by hand. As I got further down towards the keel I swapped to a flat hand file to blend it in. I've put a picture here for you
  23. Thanks clogger 👍 Thanks Greg thats very nice of you to say - would you believe I chose my screen name due to the first time I visited this site. All of the terminology and expert work that was going on made me realise that I had "no idea" what I was getting into!
  24. Hi Shipmate 69 I use the Proxxon MF70 mill and its quite a good little machine. The spindle speed is very fast and its quite accurate but it is tiny. Its designed for modellers work and is not designed for large pieces. I only have machined wood and brass which it has handled ok for its size. Could it do 1mm mild steel that you want to machine? I think that it probably could .........but you would need some really good tooling and also take extremely fine cuts. How you would apply cooling I am unsure about but there are bottle fed cutting fluids that maybe could be used. I have thought about upgrading my mill to something bigger and have considered Sherline and the larger Proxxon machines. But none of them have the spindle speed that I want for cutting wood cleanly and the size of them seems to be exponential if I moved up even a little. I have little space where I live so I am learning to make the most of the machine that I have. I buy the best cutting tools that I can and use my imagination when it comes to fixing the item for cutting. Sometimes I win and get the job done and at others I just have to accept that my little machine is just not up to the job. I don't think that there is a mill that does everything but mine does 85% of what I want and the rest I'll just have to get the hand tools out. I hope you find your solution - Mark
  25. Another quick update The keel parts dried very nicely overnight so I drilled and inserted the treenails through the scarf joints. Next I made the stern post and also cut the mortice and rabbet in it. The false stern post was also made and its now all being glued to the keel. Tomorrow I'll clean it all up and move onto the rising wood hopefully.
