Some Idea
Everything posted by Some Idea
  1. Now I know what I said but this little gap has been doing my head in 🤣 So today my truck decided to breakdown so its a day off from work for me!! So I decided to make the thin little shims to fill the gaps and I'm glad that I have. I've not cleaned anything up yet so the pictures are just the shims glued in and trimmed to length with a chisel. I'm glad to say that I am "gapless" now and the average shim was 0.6mm thick. I only had to put one shim up at the stem. I think it will look better with a good sanding too. At some point I really need to have a good clean up of the entire hull but I'll wait until I've closed the bow and the stern. I can now sleep soundly at night; it can't just be me that dwells on these things - Back to the family now too! Cheers Mark
  2. Hi both and thanks for your thoughts on this. The keelson is now glued in as this was as low as I could get it after many hours of fettling it to fit. I felt that I had reached the point where if I removed anymore material I would make the gap wider rather than smaller. Having slept on this and taking Greg’s point I think I’m going to leave this for the time being. I’ll see how I feel at a later date as after all there is no rush. I have to be honest it actually fitted better than I thought that it would 😎
  3. Thanks for the comments 👍 I've now completed the keelson assembly or the patience tester as its now called in my home 🤣 So many joints on 4 pieces of wood that as I have found have to be spot on or it will just not fit. Making the parts was not too hard but getting them to fit takes literally hours. I didn't have to remove too much material to do this I just had to work out where to remove it from. This was for me one of those jobs where it would be far too easy to remove loads of wood and end up with bad joints. Cutting the notches in the curved part of the keelson was interesting as its so easy to loose the correct angle of the cut. I found that the best way of doing this was to mill out the vertical angles first with a 1mm end mill and then remove the centre afterwards. I was also amazed at just how little glue is required to hold the whole assembly in place. Because its such a high fit I only used a very small amount which was great as there was virtually no clean up to do. I do have one small issue - I just could not get the keelson to get fully down towards the stern. I have a small gap of less than 1mm so I really need some opinions on this. Do I just leave it as it is or should I make up some filler out of PVA and sawdust to fill the gap? Its a bit too small I think to successfully put slivers of wood in but I would appreciate others thoughts. I also still need to make a piece to fill the gap between the apron and the first frame but that's my next job. I cannot do any more work for two weeks as I've got family staying and they need my time but I'll get back on this when I can. Cheers Mark
  4. That's a really nice job and welcome to MSW too. The Cutty Sark is a special ship to me as I grew up in South London and as kids we used to ride our skateboards around her. That was many years before the fire and also many years before she became popular too. We pretty much used to have her all to ourselves.
  5. Hi Dave - I currently use a Bosch Gas20 vac on all of my tools but after a few years of use I've realised its just so noisy. In fact it really gets on my nerves now. It has great extraction but crickey its so loud!!! I've realised that I need something a bit quieter so I'm looking at Festool as a solution. I'm going to visit my local Axminster tools and get a demo so that I know its worth the money. If its quieter and also has good extraction I'lll be getting one.
  6. Hi Allan thanks mate 👍 I wasn't going to document this build as its my first POF but I'm really glad that I have. Not only do I get lots of great advice its actually given me something to look back at too. I've now made a start on the keelson and as per usual I glued the templates to the wood that I had previously made ready. Next I roughed out their outer shape which didn't take too long. I've decided to start on the keelson part that goes over both of the master frames. I milled out the rebates and also cut the scarf joints too. This is not difficult to do - but I took all of my measurements especially the depth of the cuts from the original plans. I find that I get better results doing this rather than just milling to the template lines. The keelson fits - oh boy does it fit in fact I struggled to get it back off of the frames when I needed too. Now it doesn't fit quite correctly at the moment as there is a gap of about 1mm - 1.5mm between it and the frame chocks. I've tracked this down to the frame rebates being slightly too high which also has the knock on effect of raising the final position of the stemson. I don't think that this will be a problem as I just need to sand the high spots lower, but you just know that it's one of those jobs which is going to take ages to get a good fit. I'm going to get this part right before moving on to anything else. Adrian Sorolla has this exact same issue in his book and he solves this issue by packing the gaps with slivers of wood. I may have to do this too but I'll try and reduce it first by sanding. Mark
  7. What a fantastic build your ship is looking great. I really like your attention to detail - I’m in on this one 👍
  8. Hi Pete - I've just measured my bench height for you and it stands at 900mm high. I have found this to be a good height for me to work at building my ship and also for my power tools too. The only tool that I have found that I use lower is my thickness sander. I place this on a metal cupboard that is 670mm high as I like to be over the top of this tool when I'm using it. I'm sure that I'm just talking about personal preference here which we all obviously have. I'm 5' 8" tall and this works well for me. Good luck with the new man cave as we all need one at some point in our lives.
  9. Yet another fantastic video - thanks Kevin for going to all of the trouble making these very informative and honest diaries of your build 👍
  10. Thats really nice work Mark I think that it will sand up very nicely indeed. I wouldn't worry about the time taken as it took me 10 months to plank my last build correctly.
  11. Thanks everyone for the tips - I'm glad to say that my hands are feeling much better this weekend 😀 I can't actually do any making this weekend as I forgot to go the the printers and get my plans reproduced for the keelson. I'm no good at drawing or tracing so I'll leave any machining to next weekend when I have a good set of copies. My wife has volunteered to sort this out for me while I'm away at work next week. I've noticed on a few build logs that people would like to see more posts about how things are done by the builders themselves. So today I prepared the wood ready for next weekend. The scantlings tell me that the keelson is 270mm thick and that the stemson and sternson are 243mm thick. So at a scale of 1/24 I need two pieces of wood the first being 11.25mm thick and the other 10.125mm. This is a big model and very wood hungry so I needed quite large pieces of wood to start with. The material I chose was just over 13mm wide so the first thing I needed to do was bring this thickness down on the bandsaw. I machined one piece down to roughly 11.5mm and the other to 10.5mm. Can I just say at this point I'm not going to talk about workshop safety at all. I trust that everyone looks after their own fingers and eyes appropriately. In all of the pictures the machines are stationary 👍 Next they were run through the thickness sander and I only needed to use fine grit paper as I didn't need to take that much more off. Then I ran them through the table saw to give myself nice straight edges and also make them square. If like me you have one piece that has no straight edges, just make up a simple sled using toggle clamps and voila its sorted. So now I have two pieces of wood at the correct dimensions ready for when I get my plans next weekend. The time taken was about and hour to do this including the clean up afterwards. I hope that his has been useful to someone - Mark
  12. Thanks druxey - I've just looked on line and found lots of bronze wool. I didn't even know that this stuff was available until then! In the past I've used fine scotch bright pads but I don't think that they will give the fine polished finish that I would like on this boxwood. I'll order some up and do a few experiments with it.
  13. Hi Everyone I've now faired the inside of the hull which really does take hours. My hands and fingers are killing me they are so sore 😂 I wouldn't mind but I was using blocks too!!! I have learnt not to leave any frame chocks protruding too far into the hull; thats another one for next time too! I didn't have many places where I needed to remove too much material. It was more about lining the frames up correctly - please remember though I do have scale on my side as these frames are thick. How you builders do this at 1/48 scale must make the process so much harder and more precise in the first place. I have to say its a lovely job to do especially when you get down to some finer papers such as 320 and 400 grit. You can just feel that things are starting to be right - it's hard to explain. I've stopped at 400 grit as I'm sure that the interior is going to get a bit bashed around before it needs a final finish. I'm not sure what you all use for a final finish but I'm thinking wire wool is probably the way to go when I get around to that stage. The next job is to make the keelson and I will make a start on that tricky piece next weekend. Mark - BTW I think I should say thanks for all of the likes too its quite humbling to be honest.
  14. Thanks druxey for the encouragement 👍 I know that my next build is at least a couple of years away so I can get lots of experience and advice in the mean time. The fairing of the inside is going well; in fact I think its starting to look really beautiful inside. I've been sanding for hours and I've got quite a few more before its done. I'll try and get some pictures up tomorrow but wow are my fingers sore from all of the sanding 😂
  15. I've now roughed out this piece and glued it into place. It will get its final shape when I fair the outside of the hull. I'm not entirely happy with it but its my fault for not thinking ahead. A very small additional triangular piece had to be made for both sides to make the transition from the block to the sternpost smooth. I did have difficulty recessing the inside of the piece because it was difficult to hold due to its shape. In hindsight what I should have done was put a couple of screws into it where it wouldn't notice and then clamp onto the screws. They could have then been simply removed before gluing. I'll save that one for next time! I think my build will slow down for a bit now as my next job is to fair the inside of the hull. I think that this job is going to take quite a long time to get right but I'm looking forward to it. Once the hull has been faired inside I'll have a go at making the keelson, stemson and sternson. Cheers Mark
  16. Hi Hubac's Historian, Mark and Greg; thanks for the comments 👍 I hadn't even made a wooden scarf joint until I started this build as my other two builds were both POB kits. Before that I had no real experience using wood. I did a tool room apprenticeship many years ago which was all metal work which I now see has stood me in good stead for model ship building. Everything back then had to be machined extremely accurately or it went in the bin which would not have pleased the foreman. This was before CAD or CNC so everything was made manually by hand. Would you believe that back then titanium was so rare that if we were given a small piece to machine, we had to collect the swarf and hand it in at the end of the working day 🤣
  17. Hi All Things seem to have gone ok with the making of the solid piece that fits under the transom. I did the usual of cutting out templates making sure that the grain was correct before roughly shaping the parts and gluing them together. The angle between the transom and the last frame is slightly under 90 degrees; I don't know how everyone else takes the angles from either the ship or plans but I use a sliding bevel. I transferred this angle to a face sander and cut the top edge first but I forgot to take a photo of this step. I then I had to think about how to cut the taper at the rear keeping it square to the face. In the end I used double sided tape and fixed it to a metal block. This did the trick nicely and worked out the shape by taking measurements from the plan and scribing it as I went along. It's made now but I just need to rough shape it a bit first on the outside and also cut the recess on the inside. Cheers Mark
  18. Wow your work is so inspiring - you are so precise its just lovely to see you progress. I'm watching this for tips and something to aim for in the future. Good luck moving forward.
  19. Hi druxey and Beef Wellington 🙂 Thanks both for the really nice comments and I'll try and post some more of how I work my problems out. I have created myself a real problem now; I should have filled the gap underneath the transom and behind the last frame before I installed frame 32. I was so focused on getting the frames in correctly this stage completely slipped my mind. So I now have the unenviable task of shaping this block to the correct shape and then sliding it into place. I'll give it a go and post my progress. Cheers Mark
  20. Hi Matt and thanks for the comment mate 👍 I've now finished raising the frames to the stern so thats all 32 frames installed. All was going well up to frame 28 but when I put the last 4 frames in I could see that they were leaning slightly over to the starboard side. Once again this was my fault as the aperture that I had cut on the assembly board was incorrect. So they all came out with some alcohol and I did what Greg suggested and started at the transom and worked my way forward. This produced a much better result. I'm glad to say that they all seem to be nicely vertical and square! I did have to make a couple of small wedges to fit between the last frame and the fashion pieces. There was a small gap due to my incorrect shaping of the mating faces. I can live with that though if I'm honest. Cheers Mark
  21. Just read your whole build - fantastic job on this ship it looks really nice and clean 👍 I'm looking forward to your updates - BTW - best forum name ever 🤣
  22. I actually managed to get some more frames in today which wasn't planned but you've got to take the time when its available! I've now raised frames 16 - 23 and they seem to have gone in nice and straight. There were no real issues it was just a case of repeating what I have already done. The floor chocks with the limber channel start to rise at frame 20 so there are a lot of bespoke pieces to be made. The rise starts off very slight and becomes much more pronounced as you move towards the stern. These chocks also rotate their limber channel 180 degree's at frame 23. I missed this until it was too late so mine will have to rotate at frame 25. Some you win and some you loose I guess. Cheers Mark
  23. Hi Marc thanks for the really nice comment mate and I have to say I'm very surprised by the overall reaction to this build. I just try my best and thats pretty much all I can say. Please remember that I have pretty much built this ship twice over so far with the amount of things that I have made incorrectly. I think that the choice of ship for anyone's first POF build is critical - I chose Le Rochefort after much research and also have messaged people like Mark Taylor for advice. It would be so easy to try and build something bristling with cannon but that would have been far too much for me. I have in my building arsenal a fantastic book by Adrian Sorolla which is basically a step by step building guide. I also have Gerard Delacroix on this forum who made the fantastic monograph that I work from - oh and the many fantastic builders on this forum who give me the best advice. It's not one of those things that you do on your own and making mistakes is just part of the process it would seem. Typing this out has made me think that I really ought to join the NRG if only to put a few coins in their coffers.
